Need Philips Magnavox MAT965A101 Web TV Manual or Setup Info
SOURCE: need to find a code...
I HAVE PHILIPS MAGNAVOX TV AND I AM USING THE UNIVERSAL REMOTE RCU300T and i lost my manual where the codes was.
Posted on Sep 22, 2008
SOURCE: Default settings for Philips Magnavox TV
I bought another TV
Posted on Nov 12, 2008
  • 4 Answers
SOURCE: i need a pdf manual for this
I think you can find that here.
http://www.usersmanualguide.com/philips/tv__plasma_large_32-42_inch/ftr9965_17sb
Posted on May 04, 2009
SOURCE: Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Posted on Oct 19, 2009
  • 10 Answers
SOURCE: Philips Magnavox 2783 c101 - will not auto program tv channels
Ya what you got to do is Grab your tv, and throw it out your window. Garbage tv with built in problems made to be fixed. I had the same tv and i had many problems with it before. Just buy a new one boss.
Posted on Feb 17, 2010
My Magnavox smart tv remote doesn't have a smart button how do I search the web? I have wireless internet
Smart is a word often used to suggest a device does more than other devices. It does not imply it can go on the net by just pressing any button. You first have to setup everything, as the manual will explain. Don't trow away the manual and ask someone else you don't know, to write the pages you need to setup anything.
Jan 12, 2015 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have lost the manual for my Crest model Po5094-2 remote. I need the code for Philips model 29PT468A TV. Can you please help?
Hello
four digit remote codes for Philips are:-
0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141
Four digit remote code for Magnavox are:-
PHILIPS-MAGNAVOX ..... 0062 0204 0207 0183 0226 0288
Three digit remote codes for Philips are:-
003/ 004/ 006/ 008/ 062/ 068/ 069/ 074/ 075/ 076/ 086/ 087/ 089/ 133/ 163/ 183/ 184/ 205/ 206/ 207/ 208/ 212/ 213
Three digit remote codes for Magnavox are:-
PHILIPS/MAGNAVOX Codes: 183/ 184/ 208/ 213
NB: Switch OFF and switch On the tv with its front panel power switch each time before gointg to an other code.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Ok
Jan 15, 2011 | Philips Universal PH301S Remote Control
I need the owners manual
Well you can please follow the below link to get your TV manual -
http://tv.manualsonline.com/manuals/mfg/magnavox/mwr20v6_1.html
(Just copy and past the above link in your web browser, ans follow the download procedure)
Good Luck!!
Mar 31, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox 55P8288A Picture is cloudy
You can purchase a factory one from www.remotes.com. and for you manual you can download it here just click on get manual http://www.retrevo.com/s/Philips-50ML8105D-TVs-review-manual/id/277ag615/t/1-2/
I sure do hope this helps you and thanks for using fixya.com
May 24, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My Remote and TV do not communicate as such I need the Manual to resolve the problem
There is no copy of this manual on the Phillips USA website. You can try and ask other users on the web or on this website with the same model television to make a pdf copy for you. They can e-mail it to you. You can purchase a copy of this manual on the following web link. http://www.online-owners-manual.com/mx2778b.html I Hope this information helps you with your problem.
May 14, 2009 | Philips Magnavox 27MS343S 27" TV
No manual need help with hook up
You can find a copy of the manual at this web link.http://tv.manualsonline.com/manuals/mfg/magnavox/mwr20v6_1.html Use the print function and make a pdf copy for your use. I hope this information helps you with your problem.
May 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I can't see my tv
You likely need to select channel three or four on the TV itself if you have any kind of box between you and the signal source (cable, antenna, satellite). Magnavox is a name owned previously by Philips and now by Funai. They may not have all the info from Magnavox and Philips but you could check their website to see if they have the instruction manual for download.
Look under 'Support'
Funai
Jan 20, 2009 | Philips E-Box FTR9965 DTV Receiver
I require an Instructiion Manual for a Philips Azur Excel Plus 515 HI515 Steam Iron
It is available on the Philips web site. Just do a web search for "Philips Azure Excel Plus".
Jul 16, 2008 | Philips Magnavox 27MS343S 27" TV
Need number for gci remotecontrol so i can use it I have a philips/magnavox can you help.
I own a One-for-All universal remote (model URC-4220), and my booklet says the setup code for a Philips/Magnavox TV is one of the following numbers: 0030, 0054, 1944, 1963, 1268, 0593, 0000, 0821.
Hope these numbers help you out. Please take a moment to rate this info, by using the rating system below. Thanks.
Jul 13, 2008 | Televison & Video
SETTING CODES
Feb 03, 2008 | Philips Magnavox Learning Universal Remote
Televison & Video Logo
163 people viewed this question
Top Televison & Video Experts
