Question about Toshiba SD M1712 Internal DVD Drive
Toshiba DVD ROM SD-M1912 Tray Opens Intermittently or Partially
This DVD-ROM is used in my KiSS DVD player. The problem is opening the tray. Sometimes it opens; other times it doesn't. Sometimes it opens a bit then suddenly the tray is withdrawn into the drive. It may be difficult to find another DVD ROM that fits properly into the player which I reslly like because it has an Ethernet port and plays DivX and XviD. Any ideas?
    Master:
  • Toshiba Master
  • 306 Answers
Yes... we do get attached to our toys.
Sounds like your tray slides (left and right) have some kind of contamination?
Best if you can remove the drive so you can CAREFULLY clean the tray rails and slides. Don't be tempted to lubricate with anything because the oils (etc) may serve to capture even more junk... a common Q-Tip should do the job.
Most drives have a tiny hole in front to extend the tray manually? If not, open the drive door and HOLD IT OPEN as you power-down for easier service.
INSPECT the tray 'gears' inside. IF they have a paste-type lubrication on the gears just break off one of the ends of the used Q-Tip and reapply the paste (usually) to the SAME GEARS it came from... DO NOT put the lubrication anywhere else!
Finally use common rubbing alcohol on a Q-Tip to clean the drive tiny belt.
Below is a YOUTUBE video that may help you!
Anthony
How to With Chad 360 Stuck Disc Tray Repair
Posted on Nov 29, 2017
techman
  • 3130 Answers
SOURCE: Toshiba SD-M1202 Schematic
You may be out of luck As most toshiba drives are made by a differant division of toshiba then what the computers are and most of these drives come as a whole part and the computer divsion at Tosiba dosent even have the schematics for them as like I say they dont fix them they simply replace them as a part in whole. All differant drives will have the same pinout as the drives are interchangable. But before I spent alot of time experimenting I would make sure the drive works in a puter. Good Luck
Posted on Apr 12, 2006
  • 158 Answers
SOURCE: DVD tray keeps opening and closing?
this sounds like the take up motor for dvd player the band maybe streached have you got it serviced latley as this maybe the cause of problem this is due to heat from dvd player and vcr comby drives please have it looked at by an expert in this field as my sony dvd player and vcr does the same as you've described
Posted on Aug 13, 2007
SOURCE: Toshiba sd-c2512
can this SD-C2512 write DVDs and CDs? Kindly answer this to pnsrao@gmail.com
Thank you.
Posted on Jan 30, 2008
ctf1800
  • 4402 Answers
SOURCE: DVD tray WONT OPEN
unplug it and try it again, if that doesn't work see if theres a pin hole where you can push a paper clip in by the tray area.
Posted on Feb 26, 2008
marked
  • 6487 Answers
SOURCE: Toshiba SD-5000 DVD Player - disc tray stuck
Try first turning off the player and turn it back on and eject it using the eject button on the unit and also try to eject it using the remote.. IF still wont eject this can be a mechanical function on the ejecting part of the unit that you may need to open the unit and check for that..
Hope that helps.........
Posted on Aug 07, 2008
I have a toshiba dvd player model sd-k600, i need change of zone 1 to mutiregion o zone 4, can you tellme how te change, tahnks
Press Open button on your remote control to open the drive tray
and remove any disc
Press 2403960
Press Enter button on your remote control
Press 9 for multi-region playback
Press Open button on your remote control to close the drive tray
Power OFF the DVD player
Power ON the DVD player
Jul 16, 2011 | Toshiba SD-K600 DVD Player
My sd-k770 loads a dvd and then opens the tray backup without ever playing. Basically doesn't seem to want to keep the loading tray shut.
Most likely the laser pickup needs cleaning. It is not seeing the disk. If cleaning does not help, the pickup itself is probably bad. These are usually not feasible to repair as the pickups cost as much or more than the whole unit. Thanks
Oct 29, 2009 | Toshiba SD-K770 DVD Player
Toshiba DVD player doesn't retract or load media. DVD carrier is stuck in the out position
There is a rubber band on the motor that opens the tray out to load the disc, somehow that must of slip off the motor. Or the motor itself went bad.
Oct 11, 2009 | Toshiba SD-5700 DVD Player
DVD tray in SD-V296 will not open
Hi!
Thank you. Yes, we did solve the problem; in fact, it was the way we had solved it one other time, even though I had believed it a fluke then:
we simply disconnected the unit for a couple of hours, plugged it back in and, just as last time, the tray opened easily.
Sincerely,
Dean Hunt
Oct 10, 2009 | Toshiba SD-V296 DVD Player/VCR
Toshiba sd 4800 dvd plater not opening and playing
There is a small belt that has become worn or has broken. Open the DVD palyer, press the open key push on the silver disc, the tray will open, . On the tray pul the two tabs up gently, remove tray. Belt is located there
Oct 04, 2009 | Toshiba SD-4800 DVD Player
Tray Will Not Open To Load
Sound like the belt has broken on it from the gear that opens to motor that opens the tray.
Aug 11, 2009 | Toshiba SD-3980 DVD Player
DVD tray won't open
Look for a small pin hole in the front of the DVD player. Insert a pin into the hole to open the tray.
Also try right clicking the DVD icon, click 'eject', then insert the pin into the hole.
If the door only opens partially, grab it and pull it open. Then insert a blank DVD into the tray, then see if the tray will open automatically with the disk in the tray. If so, then keep a DVD in the tray at all times.
May 27, 2008 | Televison & Video
Upon trying to remove a disk, disk remains in player and tray opens empty
This is caused be the "lift" part of the mechanism not functioning properly. A fix may be inexpensive or not, depending upon what is needed to make it rise and lower properly....accordianman
Mar 29, 2008 | Toshiba SD-3980 DVD Player
DVD player tray will not open
Maybe this will help someone look in the right direction. A friend gave me a KISS DP-1000 with the same problem: The TV showed the 'Eject' graphic, and nothing happened. There is no little hole that you can poke a paperclip in, like on a PC. I opened the player, and still could not find anything. Then I googled the model of the actual tray mechanism (DSL-710A). The datasheet said that it did have an 'emergency eject' machanism, operated by a Philips screw at the bottom of the tray. There are no holes at the bottom of the DP-1000, only a dimple that dead-ends. I broke through the bottom of the dimple with a small, flat, screwdriver, then enlarged the hole. I felt around with a medium Philips and it fitted into something. I twisted gently, and the tray popped out. Why KISS covered the 'emergency eject' screw is anybody's guess, but I am not buying any of their products.
Feb 25, 2008 | Televison & Video
Trouble with the disk tray
clean the tray, or replace the belt open the cover of your dvd
Jan 19, 2007 | Toshiba SD-3980 DVD Player
Toshiba SD M1712 Internal DVD Drive Logo
131 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
