Question about Dell Inspiron 6400 Notebook
Touchpad problem My touchpad and other mouse keys will not work at the moment unless i hold down a keyboard key at the same time. However once i hold for example the shift key they work perfectly. I am not aware of a setting i have changed and any help will be much appreciated. Thanks
  • 191 Answers
Run a diagnostics
turn off your system
press and hold Fn key ,power on the system, leave fn key
it will start running a diagnostic
it will give you an option to press any key to continue
press any key and you will get 4 options
express test
custom test
extended test and
symptom tree
choose symptom tree
you will get list of devicec
choose keyboard run test
it will highlight some keys you have to press
if everything works fine here
hardware is working fine
then you have to take the system back to day one or use Operating system cd to reinstall the operating system
if you are in United states call 1-800-624-9896
Posted on Jun 05, 2008
  • 624 Answers
Hi Stores, First off check to see if you have the Synaptics touchpad driver installed on your laptop. Go to the control panel, then add remove programs and look for touchpad. If you have it AND if you don?t configure the pads sensitivity or take advantage of the software?s ?features? I would suggest you uninstall it. My users (and I) have nothing but problems on the laptops that have it. Windows has default support for the device and it does fine as long as you don?t need any of the special features the software driver provides. It may be a good idea to make sure you have the software to reinstall it if you don?t like the results. If this doesn't work for you let us know and always please don't forget to rate this solution once we're done.
Posted on Jan 22, 2007
I can't click on anything on my home screen. Gateway N522 series. Won't tab or do anything. Helpppp!!!
Try ensuring that the touchpad hasn't been accidentally disabled (Hold down the '[fn]' key and press the F6 key on your keyboard to toggle the touchpad(mouse) to be enabled or disabled.
Have you tried using an external keyboard and mouse?
If the external keyboard and mouse work then we know it is something to do with the built in keyboard and touchpad on your laptop (likely - but not positively a hardware issue). If it does not work then we know that the issue is likely (but again not positively) software based.
Jan 20, 2015 | O4Jelectronicswarehousecom Wireless N...
My mouse pad doesent work
Locate the function key on your keyboard (F1 through F12) that has an icon of a touchpad. This is often a rectangle with two smaller rectangles below it, representing the touchpad and its two buttons.
Press and hold the "Fn" key, usually found in the lower left area of your keyboard.
Press the touchpad function key and then release both keys.
If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
Shortcut Key Method
Press the Windows icon key on your keyboard and hold it down until the Start menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl-Esc" at the same time.
Use your arrow keys to locate the Control Panel and press "Enter."
Navigate to "Mouse" with your arrow keys and press "Enter" to open the mouse control dialog box. Then, press "Alt-F" together to access the tabs at the top of this box.
Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter."
Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter."
Your touchpad will be re-enabled.
hope this helps
Nov 28, 2012 | Acer Aspire 7741Z-5731
How to unlock keyboard and mouse pad
Shortcut Key Method
hope this helps
Oct 07, 2012 | Samsung Computers & Internet
How to open unlock mouse pad
Click the Windows "Start" button in the bottom-left corner of your desktop.
Scroll up and click "Control Panel."
Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner.
Click the "Enter" button and then click the "Mouse" link.
Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have.
If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button.
If you are under the touch pad tab, click the enable button.
Click the "Apply" button and then click the "OK" button
or
Press the touchpad function key and then release both keys. If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
Shortcut Key Method
Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter." Your touchpad will be re-enabled.
hope this helps
Sep 22, 2012 | Computers & Internet
Describe your HP Pavilion dv9000z 17" Notebook Laptop PC PC Notebook Problem my internal mouse is locked, I dont know why and dont know how to fix it (I dont use an external mouse or keyboard). ...
Hi melissamhahn..
Try this solution to your problem
To fix an unresponsive touchpad on your laptop, reactivate it by using the Function key on the keyboard and the Fn key.
This process is different for each computer manufacturer.
If unsure which Function key enables and disables the touchpad, try each one at a time and then
attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard.
The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Note: Mac computers use "F2" to enable and disable the touchpad.
D. Sony Vaio Users: Start>Settings>Control Panel>Double click the Mouse icon.
Look at the top left hand side of the page, at the top and make sure that the "Tapping" box is unchecked, if it is checked then, you will uncheck it.
Please take time to rate me thumbs up
Sep 17, 2011 | HP Pavilion dv9000z Notebook
My mother just gave me a toshiba laptop and she had a wireless mouse for it before. I do not have the mouse on it now and the mouse pad is not working. How do I restore it to the original setting?
Hi parothead91...
Sep 05, 2011 | Toshiba Computers & Internet
Have deactivated mouse on acer5520G how do i reactivate it
Support Solutions from Acer:
Product
Notebook Acer Aspire 5520 G
Issue
Mouse / Touchpad not working
Solution
If the mouse/touchpad is not working, ensure that it is turned on. Press and hold the blue "Fn" key located in the lower left hand corner of the keyboard. and tap the "F7" key one time.
Fn-F7
A message should flash across the bottom center of the screen stating "touchpad enabled".
If this does not address the issue, the notebook may need service.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 17, 2009 | Acer Aspire 5520-5579 Notebook
Acer aspire one touchpad mouse does not work. USB mouse works. Also FN F5 stopped working
Aspire D250.....
Hold down function key fn (lower left on keyboard) and tap F7 key once..
May 02, 2009 | Acer Aspire One PC Notebook
Mouse touchpad, keyboard, and usb drives will not work
One thing you can try (for the touchpad)
Acer have got a function key to turn it on and iff (i thought mine was broken for a year). Hold the function key, which is located bottom left of keyboard, and then press F7. It should be F7 anyway.
Hope that helps for your touchpad
May 05, 2008 | Acer Aspire 3000 Notebook
Dell Inspiron 6400 Notebook Logo
363 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
