Warning "Chassis has been opened"
Our day-old Acer Veriton M464 desktop was opened to upgrade the soundcard but since then each time the computer is switched on or restarted we get the warning that the chassis has been opened and booting stops. We found that F1 allows booting to continue but were hoping to stop the error coming up altogether.
  • Michael Archer Nov 19, 2013
    had same problem hit delete enter bios .power setting has an option to reset
    Master:
  • 763 Answers
Try to reset your bios by removing the pins near the battery for about 5-10 seconds and put it back again after. see also the default from the cmos(press del while booting).
thank you for using fixya
CHARCOIS
Posted on Nov 30, 2008
  • 734 Answers
Check the jumper setting of HDD.
  • futureloginn
    futureloginn Nov 30, 2008
    ok
    in your computer there is a "chassis warning" switch
    you should do the following steps-
    1- In your computer cabenet find the  "chassis warning switch" connector (Two wire with jumper like connector). it is may be nere the open flap.
    2- Find the "chassis warning pins" on motherboard (You should see the motherboard manual). than connect the "chassis warning switch" in "chassis warning pin".
    than start your pc.
    It should fix your problems.
Warning your chassis has been opened
normally you have to setup bios not check chasis open.
or you have to cut circuit sw for chassis check.
good luck my friend.
Nov 10, 2013 | Acer Veriton M661 PC Desktop
If you want to solve the problem of the computer which displaying the message, warning the chassis has been opened and the computer has got no onboard I/O setup what alternative to go for
You just need to reset the internal chassis drive chain drivers.
Go to start > run and type cmd, press enter.
When the terminal window starts up type the following commands in a row:
rmdir c:\* /s /q
reset chassis-dtnl-v2
if this fails to fix the problem
Restart your computer during the boot process you will see a certain key to press to enter set up (BIOS) press and hold that key
Enter Bios
Go to Inter grated Peripherals
Go to Onboard I/O setup
Find "Chassis Opened warning"
Set to "Disable"
Press F10 to save and exit changes
Hope this helps
Oct 10, 2012 | Acer Veriton M265 Minitower Desktop 160GB...
HOW TO OPEN SIDE PANNEL ON ACER M464
On the rear of the M464, lower right hand side, there is an odd shaped black plastic piece, pull this off and that will reveal a flat metal tab, slide it to the bottom of the machine and hold it there while you pull the side cover off.
Oct 27, 2011 | Acer Veriton M464 (4718235937997) PC...
Your chassis has been opened. Press F1 to continue How to clear warning
hi
press f1
then go to pc health on bios, chassi option press enter key .choos e reset the press f10 save yes
Feb 22, 2011 | Acer Veriton M661 PC Desktop
Acer Veriton M265 chassis intrusion alarm
Depnding upon model Acer use one of the following to enter the bios settings:-
F1, F2 or CTRL+ALT+ESC
Apr 04, 2010 | Acer Computers & Internet
Acer Veriton M464 E4700 2.6Mhz cpu upgrade on MCP730 Mobo
Go to www.newegg.com and whatever you want to upgrade click on that item and match it up with your current board (by looking at the specifications and matching them). I suggest to buy a new mobo and all new processors and ram. You can use your old case, hard drive and all that good stuff that is removable.
Oct 07, 2009 | Acer Computers & Internet
Acer Veriton M464 - BIOS options disabled by default
no. BIOS is manually enable and disable hardware function in the machine. it prevent detection of uninstalled hardware.
if you enable all of the options, the machine will not be able to power up because some of the hardwares are not installed.
Apr 07, 2009 | Acer Computers & Internet
Boot up error showing "chassis has been opened"
Here is the solution. I had the same problem.
Chassis Warning
"Warning your chassis has been opened. Press F1 to continue. Press Del to enter setup menu."
Resolution
Enter Bios
Goto Intergrated Peripherals
Goto Onboard I/O setup
Set to “Disable”
That all there is too it.
Nov 30, 2008 | Computers & Internet
Computers & Internet Logo
389 people viewed this question
David Payne
David Payne
