Boot up error showing "chassis has been opened"
My boyfriend opened our day-old PC (Acer Veriton M464) to upgrade the sound card. Now each time the PC boots up this warning comes up. He found that pressing F1 allows normal loading to continue but each time the PC is switched on or restarted it happens again. Everything else is working perfectly. Is there any way to stop this permanently?
  • 1 more comment
  • gcooney179 Apr 01, 2009
    I have the same problem but cant find the disable chassis stuff in the BIOS - i've looked EVERYWHERE!!
  • hate compute Apr 02, 2009
    Same problem, but onboard I/O setup has no "chassis opened warning" option.
  • gcooney179 May 11, 2010
    I've tried all of this - still cant see the disabling bit in the BIOS - and I've been into EVERY section!
  • 7 Answers
Here is the solution. I had the same problem.
Chassis Warning
"Warning your chassis has been opened. Press F1 to continue. Press Del to enter setup menu."
Resolution
Enter Bios
Goto Intergrated Peripherals
Goto Onboard I/O setup
Find "Chassis Opened warning"
Set to “Disable”
Press F10 to save and exit changes
That all there is too it.
Posted on Mar 06, 2009
In the BIOS go to the BIOS Security Features section and either dissable or clear the warning for Chassis opening - just worked on this machine
Posted on Aug 28, 2010
  • Rajakumar
    Rajakumar Dec 29, 2013
    Thanks it was working me
Press Del Goto PC health status and just enabled the Reset Case Open Status
Posted on Sep 25, 2009
Simply go into the BIOS and hit return to factory default, that’s it. Hit save and reboot..
Posted on Nov 03, 2009
Follow what SteveS1013 said but go to the PC Health Status screen instead.
That should help.
Posted on Jul 23, 2009
Go to bios security then disable "open case"
Posted on Jun 05, 2012
  • abbonani
    abbonani Jun 05, 2012
    go to bios security then disable "open case"
I had the same problem, if however pressing del or f1 doesn't get you into the bios you may need to clear the nvram. To do this just open the cover again, find the battery on the motherboard, there should be a jumper beside it thats on 2 of 3 pins, move it to the other 2 and power on. It should come up with the same error but this time del or f1 will get you into the bios. From there just go and clear/disable the sensor and save. power off the machine and put the jumper back in it's original position and close your case. You can then power on as normal.
Posted on Nov 10, 2012
  • 4 Answers
Easy Solution go to PC Health and. DISABLE PC Health Save and exit
Posted on Jul 11, 2010
Same here - I'm fed up with it!
Posted on Dec 30, 2009
I had the same problem, but going to PC HEalth and clearing did not work. DISABLE also did not work. However, RESET did work. Thanks
Posted on Dec 08, 2009
Take note of stevoS1013 directions and instead of using integrated peripherals.. use the pc health screen as rock014 said and choose the option "clear". This should solve your problem.
Posted on Jul 24, 2009
I can'i see the Onboard I/O setup
Posted on Nov 11, 2011
    New Friend:
Keyboard not detected so if I press f1 or del to enter bios ,it won't work . how to solve this?
Posted on Jun 01, 2017
    New Friend:
I selected "clear" from the PC Health Screen within BIOS and it did the trick
Posted on Apr 06, 2015
In addition to SteveS1013's solution you can also use "Clear" option, in the future you will get the notification again. Could be handy if "somebody else" has opened ur computer.
Posted on Jul 25, 2009
I've tried it also, no option to turn off warning in the Bios..
Posted on Jun 25, 2009
  • 519 Answers
Either the PC case has not been closed properly, thereby not closing the "open case" switch, or you can disable the "open case" detection in the BIOS. To enter the BIOS, press Del when the PC starts up. If Del doesn't work, try pressing F2 or F10 when the computer starts.
Posted on Nov 30, 2008
My acer veriton m464 goes to black screen with a flashingline in top left corner please help
This symptom usually means a hardware problem. Remove any and all external devices plugged into the various ports, like USB devices, etc. Remove all the removable plug in devices...like the hard drive, the DVD/CD drive, and PCMCIA cards. Remove the battery.
Plug in the AC, and then power up - do you see an error screen?
Aug 21, 2016 | Acer Computers & Internet
I had a problem with my acer veriton M464 motherboard, i had a power outage which shut the computer down, i tried booting it but i see no display on the monitor,i open the system unit and take of the RAM...
Hello try to download a user guide here:
http://us.acer.com/ac/en/US/content/drivers
By selecting your pc model.
Try to renew the power supply, or try to boot with one ram stick at the time.
Was it a lightning that cause the problem ??
If so the mainboard could have died.
Good luck
Jan 09, 2013 | Computers & Internet
HOW TO OPEN SIDE PANNEL ON ACER M464
On the rear of the M464, lower right hand side, there is an odd shaped black plastic piece, pull this off and that will reveal a flat metal tab, slide it to the bottom of the machine and hold it there while you pull the side cover off.
Oct 27, 2011 | Acer Veriton M464 (4718235937997) PC...
Acer Veriton M265 chassis intrusion alarm
Depnding upon model Acer use one of the following to enter the bios settings:-
F1, F2 or CTRL+ALT+ESC
Apr 04, 2010 | Acer Computers & Internet
Acer Veriton M464 E4700 2.6Mhz cpu upgrade on MCP730 Mobo
Go to www.newegg.com and whatever you want to upgrade click on that item and match it up with your current board (by looking at the specifications and matching them). I suggest to buy a new mobo and all new processors and ram. You can use your old case, hard drive and all that good stuff that is removable.
Oct 07, 2009 | Acer Computers & Internet
DVI output problems with Acer Veriton M464
If you are comfortable with opening the case, you can try this: Unplug the power supply, make sure are constantly grounded (touching metal)remove add-in video card. Locate the "Clear CMOS" jumper (usually 3 pins in a row with two shorted via a plastic jumper). Remove the jumper and short the other 2 pins (if originally pins 1-2 with 3 open, short 2-3 with 1 open) for a few seconds. Then replace on original pins. Plug monitor into motherboard video port and power on. If it works, you can leave as is or try to re-install your video card following the same precautions when opening the case and probably changing BIOS settings to utilize the add-on card.
Sep 12, 2009 | Acer Computers & Internet
Acer Veriton M464 - BIOS options disabled by default
no. BIOS is manually enable and disable hardware function in the machine. it prevent detection of uninstalled hardware.
if you enable all of the options, the machine will not be able to power up because some of the hardwares are not installed.
Apr 07, 2009 | Acer Computers & Internet
Computers & Internet Logo
30,139 people viewed this question
Alun Cox
David Payne
David Payne
