Question about Refrigerators
How do i disconnect the door alarm on a Philips fridge/freezer combi 16M that won't stop going off
  • 833 Answers
The problem is a stuck or shorted switch in the door frame.  Better to replace that switch since it generally works fans/lights when the door opens and closes.
Posted on Dec 04, 2008
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
My Miele Fridge Freezer Keeps Beeping Although there is no issue, how do i remove the alarm?
I bet the light is also staying on inside even if the door is closed. There is a switch inside that turn the light on and off when the door is open. If the (Door Switch) is working then the light inside should shut off when the door is closed to save energy. It also tell the computer the door has been shut in case you forget then it will notify you. The switch may not be working. Look for a door with on ebay or sears. Need your model number and brand of the unit.
Sep 20, 2016 | Miele KFN8762SDED Bottom Freezer...
LEFT DOOR OPEN OF FREEZER. CLOSE3D DOOR FOR 24 HRS. nOW LIGHTS FLASHING ON SUPER COOL AND SUPER FREEZE.
You will need to unplug and defrost the fridge for a few hours then replug the power. Leaving the doors open allows moisture to freeze on the evaporator while compressor continues to run confusing the control board
APPLIANCE911
Apr 10, 2016 | Hotpoint Combi FFFL1810G Graphite 297 l...
How to disconnect or isolate door open alarm for fridge & freezer
Disconnect the door switch, this will stop alarm but light won't work
Dec 20, 2015 | Refrigerators
I have a GE Profile bottom freezer that door alarm will not stop. How do I fix it. I turned off the breaker for 30 minutes, and the alarm was silent when I powered back up, but the started to repeatedly...
Open freezer door. On top You will see 2 or 3 switches. Push all of them, if light in the freezer did not go off - you have bad door switch, if it did go off try same thing with fresh food door. Door switches do go bad once in a while on this fridges. Thanks
Mar 23, 2015 | GE Refrigerators
My Westinghouse freezer has an alarm beep that goes off every now and then and the only way to stop it is to turn off the fridge completely. In the fridge section the temperature panel flashes the...
Often these have door alarms. If the door isn't completely sealed shut then it will alarm and cause the temperature/thermostat to blink to warn of "warm" temperature inside the fridge
Mar 04, 2015 | Westinghouse Refrigerators
Why my fridge freezer keeps beeping four hort beeps
Temperature alarm
If the temperature becomes too warm, an alarm will sound and the temperature display will flash. The temperature the appliance is set at will determine when the alarm is triggered.
The alarm will sound and the display will flash under the following conditions:
  • - whenevertoomuchwarmairflows into the appliance, for example when food is being loaded, re-arranged, or taken out.
  • - wheneverlargeamountsoffoodare being frozen at once.
  • - whenevertherehasbeenalengthy interruption of the power supply. Door alarm
    If the appliance door is left open for longer than approx. 60 seconds, the alarm signal will sound.
Switching the alarm system ON
The alarm system is always active. It does not need to be switched on manually.
Switching the alarm OFF early
Once the set temperature has been reached in the freezer section, the alarm signal stops and the temperature display stops blinking. If the alarm signal bothers you, it can be switched off early.
^ Press the alarm off button. The alarm signal will stop. The temperature display will continue to blink until the set temperature has been reached. The display then stops blinking, and shows a steady reading. At this point, the alarm system is ready again if needed.
Aug 15, 2014 | Miele KFN12923 SD-2 Fridge Freezer, A...
Fridge freezer door alarm continuously beeping
make sure gasket is sealing also make sure light is going out.
Jul 17, 2008 | Freezers
Refrigerators Logo
300 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
