Question about Creative Labs ZEN SLEEK MP3 Player
Can't create playlists on my zen x fi
I can't seem to create a playlist at all! I have playlists in my library in the creative software, so why are they not transferring? I have tried to create one on the device itself too. I hit the "save as playlist" in the play mode index and all it will do is save that one song, after it asks for me to type in the name of the new playlist. If I try and add another song under that name it asks me if I want to replace the existing playlist, enabling me only to save one song on the system! Could you tell me step by step, how to make a playlist on the device, while I am listening to music? Thank You so much!
  • 4 more comments
  • Anonymous Dec 22, 2008
    Yeah, I have that same problem - I think you have to choose 'Add to selected' for every single song you want in a playlist BEFORE you choose 'Create Playlist'. Once I've done that I can't seem to add more songs.
    I don't know if I'm 'doing it wrong' but I fear that a good amount of stupid was applied when making the software
    (16 GB Zen X-Fi)
    PS: Crappy headphones, they fall out constantly
  • joannemc83 Jan 05, 2009
    Hi
    I have a similar problem, I can't seem to make a playlist song by song, it ends up adding entire albums or even the entire list of all tracks. Driving me mad.
  • Anonymous Mar 02, 2009
    I am using Windows media player and seems that sync works but when I disconnect the Zen and look on it manually, there is no playlist
  • Anonymous Mar 13, 2009
    I know this isn't really a fix for your problem, but I use mp3tag to put the songs I want into the same album.
    It sucks and you can't use the songs in more than one 'playlist' but the creative centrale is worse than useless...
    Why the Creative people refuse to support products is beyond me.
  • masmith22 Mar 14, 2009
    I agree, creative centrale is worse than useless. You can not create playlist in the order you want. Tried to force the order of the mp3 files, the software chops off numbers off the beginning of mps files. The software takes control of the mp3 tag information. Which I can not control. The player does see the folders of mp3 files copied to the device using explorer. Called several time to tech support, NO help. The orginal ZEN player is great, purchased the ZEN X-FI for the improved sound. The software with the ZEN is great, work perfectly, the way I want. Tech support could understand.
  • bongobingo44
    bongobingo44 Dec 29, 2012
    my music on the en xfi 3 wont play its saying i need i licence any ideas anyone
  • 12 Answers
I tried some suggestions posted here, and after some testing, I can now give you step-by-step instructions to create a playlist on your Creative Zen.
First, you need to think of the NOW PLAYING list as the "selected songs to be added to a playlist".
So, to start clean, let's empty out the NOW PLAYING list as follows:
1) from the MUSIC menu, select NOW PLAYING
2) when a song is shown on-screen, click the context menu
3) select REMOVE ...
4) select REMOVE ALL
Now, the NOW PLAYING list is empty.
Now, you need to select (mark) the songs you want to add to your new playlist:
1) go to an individual song
2) click the context menu, and select ADD TO SELECTED
3) go to another desired song, and do step 2) again
4) repeat until done
Now, to create a NEW playlist, go to the MUSIC menu, then:
1) select NOW PLAYING
2) it will show you the first song that you selected
3) press the Right button, to scroll through all of the other songs you selected
4) when any song is shown on-screen, click the context menu
5) select SAVE AS PLAYLIST (this refers to ALL songs in your NOW PLAYING list)
6) type the name for your new playlist, and click checkmark
ALL of the songs in the NOW PLAYING list are now saved as your New playlist.
From the MUSIC menu, select PLAYLISTS. You will see the name of the playlist that you just created. When you select that playlist, you will see the list of songs you had selected.
Please note that these songs are still in your NOW PLAYING list also. To create a another New playlist, you will first need to empty out the NOW PLAYING list as you did above.
I hope that helps.
Enjoy!
Posted on Jan 24, 2009
  • rk98 Jan 24, 2009
    FOR YOUR CREATIVE ZEN:
    To ADD a song to an EXISTING playlist:
    You first need to bring that playlist into the NOW PLAYING list:
    1) from the MUSIC menu, select PLAYLISTS
    2) select the playlist you want to change
    3) you need to play any existing song in that playlist (this transfers the list of songs in this playlist to the NOW PLAYING list)
    4) now, go to the new song that you want to add to the existing playlist
    5) click the context menu, and select ADD TO SELECTED
    6) go to any other songs that you want to add to the playlist and do step 5) again
    7) repeat until done
    Now, go to the MUSIC menu, and select NOW PLAYING. The list of songs here now contain the original playlist and the extra songs you added.
    While in NOW PLAYING, save the changes to the playlist:
    1) when any song is shown on-screen, click the context menu
    2) select SAVE AS PLAYLIST
    3) type the SAME playlist name and click checkmark
    4) select YES to over-write the existing playlist
    The existing playlist now has the extra songs you selected.
    To REMOVE a song from an EXISTING playlist:
    First, bring that playlist into the NOW PLAYING list:
    Now, go to the MUSIC menu, and select NOW PLAYING. The list of songs here now contain the songs in your playlist. Then:
    1) scroll to the song you want to remove from your playlist
    4) select REMOVE TRACK (the song is removed from the list)
    5) do the same for any other song that you want to remove from the playlist
    6) when done, click the context menu
    7) select SAVE AS PLAYLIST
    8) type the SAME playlist name and click checkmark
    9) select YES to over-write the existing playlist
    The existing playlist now does not have those songs you removed.
  • rk98 Jan 24, 2009
    When I say "go to a song" in the previous postings, I mean WITHOUT playing the song and just clicking the context menu.
    FYI: Whenever you play a song, the entire list of songs in that ALBUM/PLAYLIST is transferred to the NOW PLAYING list.
    Thanks!
Great solution!!
it's incredible Creative don't show this in their FAQ's..
Posted on Mar 29, 2009
I have an another solution for those who want to add folders from windows explorer to a new playlist... just make new playlist in creative centrale... then open the Zen X-Fi hard drive in windows explorer and find the playlist file... right click the file -->properties--> References... then just drag and drop the folder and files you want to be in the playlist!
That saved my day! :D
Posted on Jun 03, 2010
  • Osgu Jun 03, 2010
    olkaa hyvät!
Huge thanks for this advice, you really are a saint. If I was a kid I would have thrown my Zen across the room by now, so glad to be older lol.
Can you answer why hardly any of my album covers show up? Its really hard to know whats on offer with just the album title rather than the title and artist, but the pic would help this.
Cheers
Posted on Jan 22, 2010
Finally a solution that worked for me! Thank you very much.
Posted on Jan 06, 2010
Yay! It worked now! Thanks rk98! Now is there any other way on how to modify the arrangement of the tracks in a playlist? (^_^?
Posted on May 24, 2010
Just tried this out as well... saved my 'Now Playing' list as a playlist, then proceeded to look at it in 'Playlists'- and, surprise surprise, only two songs show up. I'm really annoyed with Creative at this point.
Thank you for the solution though, even if it didn't work for me :)
Posted on Mar 13, 2010
  • sabduggan Jul 27, 2011
    Hi, has anyone been able to edit playlists with the centrale software...To change the order of songs I need to create a new playlist.
    This MP3 player is really doing nothing to get into my good books! :)
1. choose a song that you want and it will lead you to the "Now Playing" segment.
2. While it's playing, go to your albums/genres/all tracks menu and select the songs you want to add in your playlist ONE BY ONE.
3. Select each song and select the scroll down menu, click on "Add to Selected"
4. The song you selected when then be added to your "Now Playing" segment.
5.Once you've added all your songs to the "Now Playing" segment, go back to "Now Playing"
6. Select the scroll down menu and click "Save As Playlist".
Posted on Oct 20, 2010
Hi, I recently purchased a Creative Zen XFi2 (big mistake). The packaged software Creative Centrale is slow and not very user friendly - I can create a playlist using the software but cannot edit the...
You can use iTunes or iMesh instead for creating a playlist and moving files, but first you will need to copy all the audio files you have from your MP3 player to your computer then use either one of the 2 software I mentioned to sync your audio onto your MP3 PLayer.
Also make sure that the Firmware of your Zen is up to date.
I hope this helps.
Jul 27, 2011 | Audio Players & Recorders
How do I create a playlist to play different kinds of music instead of my music being alphabetical
the device software that came with it should have an option under edit or file where it says create new playlist. however if it doesn't you can use winamp free from winamp.com to create one
Feb 16, 2011 | Creative Labs Zen Digital Media Player
Creative Central reads that mozaic is there, but wont transfer anything to player.
Creative support for Zen Mozaic on this site, showing how to
transfer audio and video in the Knowledge Base Solutions:
http://support.creative.com/kb/ShowArticle.aspx?sid=54748
The ZEN X-Fi supports the following Video and Audio Formats:
  • Video: MJPEG, WMV9, MPEG4-SP3, DivX3 4/5 and XviD3
  • Audio: MP3, WMA, AAC4 (.m4a), WAV (ADPCM), Audible 4
You can also use Windows Media Player 11 for music transfers.
1. Make a "new playlist" (left side) in the Library or Sync modus
When you enter the name the listname moves to the right side.
2. Putting music in the list
2.1 method 1: right click in the top of the WMP11
screen: File > Open...
2.2 method 2: Reduce your WMP11 screen: right click in the top of WMP11 screen:
Tools > Options... : select "Keep the player on top..." and
<apply>. Now you can explore your maps in Windows having
the player always on top.
Drag and drop files into the new playlist on the right side.
3. Save playlist
4. select Sync in top of the WMP11 and "Start Sync" on the right of the screen; the transfer is executed.
Aug 23, 2009 | Creative Labs Creative Technology Zen MP3...
Need Creative Zen user manual. No longer on the website. I really just need to know how to create playlists if you can help me with that.
  • Creating playlists for Creative Zen MP3 player
  1. Step 1 Turn your Creative Zen MP3 Player on and add music to its hard drive if you haven't already. Without music on your player, you won’t be able to select tracks for a playlist.
  2. Step 2 Select "Music Library" from the Main Menu. The Main Menu should appear as the first menu when you turn your device on.
  3. Step 3 Select "Now Playing" from the options available, then press the Options button.
  4. Step 4 Select "Save as Playlist" from the list of options. This will save the tracks you have listed currently as a playlist that can be reloaded later.
  5. Step 5 To play a playlist back, go to the Main Menu, select the playlist and click
Jun 16, 2009 | Audio Players & Recorders
How do you add songs to a playlist on the ZEN Mozaic?
Don't really know, but this works
Browse music library adding tracks to 'add to selected'
go back tomusic lib and goto playlists
select the playlist you want, add to selected
save selected as playlist, give it the same name as the playlist youeant to add the tracks to andchoose overwritewhen prompted
I'm sure there is a quicker way way, but hey, it works
Mar 08, 2009 | Creative Labs Creative Technology Zen MP3...
Changing file names and creating playlists
Changing the filename won't change to artist, title, album ext... The easiest way I know of to change this is with MediaMonkey, a free media player. Click the link and install and open Mediamonkey. Find your MP3 player on the left side to browse the music. Highlight the music that you want to change the artist for in your MP3 player, right click>Properties.
You can also create playlists with MediaMonkey.
Feb 16, 2009 | Creative Labs Creative Technology Zen MP3...
Zen Touch mp3 player isn't able to play tracks in windows media player 11
im not sure but i think you have to create the playlist first then transfer to mp3
Feb 20, 2008 | Creative Labs Zen Touch MP3 Player
Creative zen sleek playlists
yes, go through the tracks that you want, and press the menu button, then select the add to selected option. Once you are finished with this, go to the now playing list, and select make playlist. It is alot easier if you connect it to your computer with the software though.
Feb 05, 2008 | Creative Labs Zen Touch MP3 Player
MP3 ZEN V PLUS
Download winamp (www.winamp.com/download)
You can create edit/playlists and sync your zen with it
Jan 02, 2008 | Creative Labs ZEN V Plus MP3 Player
Trouble Filing Songs into Playlists
ok, sounds like a problem I had when I was working out the software! The easiest way to create a playlist with the Zen, is doing it over your PC, if you don't have the software it is available for FREE download at the official creative Zen site, just choose your model and region then hit download- simple! (You won't need Zencast with sleek photo model) ok! install your software blah blah blah, once it's gone through that process, restart your pc and then plug in your zen. the software should instantly recognise that your player is connected, so now, you can open up the software via desktop shortcut or start menu. From here, you've got a whole ton of options, whether to add to your library, create playlists etc etc. Choose create playlist and the process is easy. Left side of the screen is navigation of your Library, right side is navigation of current playlists. Create a new list, then name it. From the top left of the screen, select a folder on your library to open, the lower left displays what's in the folder you are viewing. move tracks over accordingly, holding down ctrl while you click is a fast and easy way to select more than one track at a time. hit add in the center of the screen to move stuff over to your new list. when you're done, save it. when you exit the software and unplug your zen, it should take a minute to update itself, sometimes you may need to restart Zen also to get the playlists updated. I hope this helps!
Apr 19, 2007 | Creative Labs ZEN SLEEK MP3 Player
Creative Labs ZEN SLEEK MP3 Player Logo
11,204 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
