Panasonic PT-51DX80A Flyback
Do you know where I can find a replacement flyback or a sub for KFT7AQ228F.
Please help if you can and thanks for your time I need one badly and vance baldwin along with parts store do not carry them anymore.
  • 8,617 Answers
You should be able to get one at the following link.
https://www.ued.net/ued/addItems.do?itemCode=MSCKFT7AQ228F
Posted on Nov 30, 2008
The only problem with it is that there is a curved line on the bottom third of the screen
Thi is the electronic component equivalent of the Flyback transformer failing. It is not a DIYir c quick board change type of operation.
Please rate my help++++Thanks for using FIXYA
May 19, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic pt-47wx53g horizontal outout transitor short whit new transistor flyback voltage are all to low the tv does notlight up the crt
Hello oncle_jc,
You may have a problem with your flyback transformer, I would suggest that you perform a ring test to see if any of your windings on the flyback are shorted. In addition You may want to also check the input to the Horizontal Output Transistor, to see if the driver pulses are of the proper amplitude. Besides these two things the only other issue colud the the high voltage trippler (if this is not part of the flyback). Check these things, you will need the following equipment:
1) oscilloscope
2) voltmeter (multimeter set to DC volts)
3) High Voltage probe
4) A test set that can perform a ring test (My shop uses the Sencore LC102)
Or what you can do is take the flyback out and take it to a TV shop and for a small fee they can run the test for you, (My shop usually charges $20.00 - $30.00 for this
I hope this helps
Shuttle83
http://www.electron-age-technologies-llc.com
Feb 24, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-53WXD63G Flyback, H.O.T., and Triper
The small wires are disconnected at the focus and screen control block, and the large HV cable is disconnected from the HV splitter.you may have to reuse the large red wire if the new flyback doesnt have the HV lead attached. The Hot is the horizontal output transistor its mounted to a aluminum heat sink near the flyback.
Jul 24, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Ge d52gw12 rear projection tv
Thats the error code for a bad flyback. Its a very easy an ixspensive repair. You can get a new replacement flyback at the following link for under 50.00 and free tech support so you can install it yourself. here is the link you need flyback 265409 for your model.
http://servicemanuals.vstore.ca/
Jun 28, 2008 | Panasonic PT-47WX53 47" Rear Projection...
R517 Burnt D" board
you will need the flyback as thats way to low. The HV splitter will only direct the HV to each of the CRTs it doesnt change or regulate the HV in any way just directs (splits) it. Let me know if you need any more assistance.
May 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic 52'' Rear projection Tv
Sounds like it could be a flyback problem. Are the ends of the picture tubes lit? Do you have audio and or onscreen menues?
Apr 09, 2008 | Panasonic PT-47WX49 47" Rear Projection...
I replaced the bad capacitor and now!?
Are you sure the flyback was clicking? Usually it arc's inside or externally to metal chassis. There is a relay that clicks on & off , which could be what you are hearing. Your bad cap, is it in the power supply or near the flyback? A regulator is more of a possibility than the flyback.
Jul 21, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
