I have a DVR-DX600 Sanyo that suddenly wont scan the television stations anymore. I think my son wrecked it somehow. It has been working fine. I can get the tv stations on the television fine, but when i put it through the dvd excatly how I have done before and go to the intial setup again, it says there are no chanels found. Any help would be good.
  • teamcameron Nov 30, 2008
    I have the areial in on the dvd and the other part of the areial is in the wall outlet. I thought thats how I originally had it but. I couldn't get the tv stations without using the dvd. Now I can't get the tv stations on the dvd or tv unless I take the areial back out of the dvd and put it back into the televison.
  • teamcameron Dec 01, 2008
    I am taking it back. It is only 4 months old. thank you for your help. it looks like it is faulty.
    Cheers
    Scholar:
  • 107 Answers
Is your arial cable insert right and properly into the arial in on your DVD recorder and the out arial from DVR go into your TV or you have 2 arial for each unit
If your installation were correct you might got the problem in the tuner pack on your DVD recorder it require a Technician to repair
Or tell me exactly how are your arial cable goes from where to where
Thank
Posted on Nov 30, 2008
  • Quang Viet HUYNH
    Quang Viet HUYNH Dec 01, 2008
    Look like your arial cable connected correctly I Thing the problem is in your DVD recorder. Try 1 more time unplug AC lead from your DVD recorder for about 1 min then hook up the arial cable to arial in on your DVD recorder use composite output or component output to your video input on your TV make sure select same input on remote control now plug in the AC lead from DVD recorder and initalizer the setup select auto turning if you see same messaged as no channel found on your TV that mean the tuner in DVD recorder defective, let me know how you go
The other day my plasma was on and everything was fine. Connected to it is a charter DVR. Suddenly the picture and sound went out. I have a PS3 also hooked up to it and it displays and sounds fine. I...
Most likelly it is your DVR that has a problem. Their are a lot of issues with those DVR's from the cable or satellite companies. I would recomend swapping it out.
Jun 08, 2011 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Sanyo DVR-DX600 dvd recorder
remote does not work even when new battries
Jun 26, 2008 | Sanyo DRW-500 DVD Recorder
Sanyo DVD recorder DVR-DX600
I don't know about where you guys are but when I went on to www.sanyo.co.nz and went into support and insturction manual searched DVD recorder it came up with english manuals for all their DVD recorders, just cick on the one you need
Jun 09, 2008 | Sanyo DRW-500 DVD Recorder
Sanyo DVR-DX600 Region Code
Could you pls try:
1. Remove DVD or video from the player.
2. Press the ‘Set-up’ button on the remote control.
3. Select the ‘System Info’ mode from the on-screen menu.
4. Using the remote control 10-key type in ‘1101′
5. ‘Region code’ should appear as an option on the ‘System Info’ menu. Initially the region code will be set to 2. Press ‘0′ on your remote control using the 10-keys to set to multi-region.
6. Press ‘OK/Enter’ on the remote control.
7. Finish by pressing the ‘Set-up’ button once more.
This was actually intended for a Sanyo DVR-V100E &HVRDX610 but I was made to understand should also work for DVR-DX600. This was originally posted here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 08, 2008 | Televison & Video
Sanyo Plasma Tv Black screen
I've had the same problem main board went out it's a 100.00 part fixed myself.
May 03, 2008 | Sanyo DP42746 42 in. Plasma Television
32" TV Screen Problem
This is a pin cushoning fault. The failure is in the pin amp, and also most likely in the scan amplifier sections. The scan amps and pin amp in part of their functions work together to control the paralax of the picture scanning. They also control the dynamic focus.
To service this, you will need the training, service information, the testing tools, parts availability, and the necessary tools to follow up.
These types of faults can be complex to service, and can be a chalenge to even an experienced tech.
Jerry G.
Jan 04, 2008 | Sanyo DS32224 TV
Archos 604 not recognizing DVR Station
Check the power pack for the DVR station and see if theres a green light still lit. I've had two power packs for the DVR station fail. This will cause the syptoms your seeing.
Oct 29, 2007 | Archos 604 Digital Media Player
Sanyo Flat Screen (DS27910) "Grey" Screen
dont know for sure but i think that the tube is going bad. Have one in my shop doing almost the same thing.Taped on the tube and it does strange things. My tube tester wont test this kind of tube that is in these sets.Not much help but it is a start.
Sep 17, 2006 | Sanyo DS27910 27" TV
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
