Can't get the timer to work!
I have two 7 fin Kingavon oil filled radiators but don't have the instruction manuals. They work fine but I don't know how to get the timers working. I know how to set the timers but at the moment the timer wheel isn't going round in conjunction with the time so it won't come on when you want it to! There is a little button with a symbol on it on the inside of the timer wheel that moves around - don't know if I have to do something with this to start the timer going round? Please help, it's cold in the mornings! Thanks.
  • 4 Answers
SOURCE: honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Posted on Nov 16, 2007
  • 45 Answers
SOURCE: Delonghi DR18T Timer Replacement
before you replace the timer, check and see if the timer has a battery in it. if it has, then change the battery. it will work fine.
Posted on Jan 27, 2008
SOURCE: set time on delonghi oil filled portable heaters and set start and finish times
It was very tough to find the actual manual online for your modle in English. However, you can call Delonghi customer support:
DeLonghi Customer Support: (800) 322-3848
Delonghi does have manuals for some models on their site. Take a look at this link, the model might be similar enough to yours to be able to get the information you need.
http://www.delonghiusa.com/search_results.cfm?sp_q=oil+filled+heater&sp_p=all&sp_f=ISO-8859-1&sp_w_control=1&sp_w=alike&sp_a=sp1003e79d&sp_c=5
Hope this was helpful.
have a great day!
Posted on Oct 29, 2008
  • 3 Answers
SOURCE: Delonghi MG15T Magnum Oil-Filled Radiator timer -timer keeps running?
I found the manual at this website:
http://safemanuals.com/user-guide-instructions-owner-manual/DELONGHI/MG15T-_M
I hope this helps.
Posted on Dec 19, 2008
  • 259 Answers
SOURCE: Delonghi HMW2400T oil filled radiator with no operating manual
if the timer is working when it gets to the off/on position you will hear a click so to test it just turn the timer around slowly until you hear the click much like an alarm clock that has the alarm turned off hope this helps regards Jim
Posted on Apr 14, 2009
I need a safety user manual for a delonghi rapido oil filled radiator
probably need to take radiator back to store and trade for another one, most time when you buy new electric appliance all inside paper work like warranty,operation instruction manual should be inside package if not, need go back to the store where you purchased radiator, they should give you another operation instruction manual and warranty paper work or give you whole new entire radiator take back the other radiator.
Dec 12, 2011 | Heating & Cooling
I have lost the brochure for my heater, the Dimplex Eco 2.4kW 11 Fin Column Heater.how do you set the timer?
Emily, if you live in the USA, contact Dimplex Technical Service 888-346-7539 for that information, as well has getting a replacement Owners Manual.
Apr 18, 2011 | Dimplex OFC2000 Oil Filled Radiator Heater
Do I need to ever add oil to my heater??
No. It comes correctly filled from the factory and usless it would develope a leak should never need oil. Thanks for using FixYa and for the generous rating.
hardrocko
May 04, 2010 | Honeywell 510477 Oil Filled 7-Fin Radiator...
How do I program my Honeywell HZ-709 radiator heater
Is there a seperate control for the timer and temp? If so, turn the temp off first and then the timer.I think they need each other for safety.
Oct 30, 2009 | Honeywell HZ-709 Oil Filled Radiator...
Apr 14, 2009 | Heating & Cooling
Need an instruction manual for DeLonghi Magnum MG15T
Here was the tricky part for me:
The round timer dial has red tabs on the outer edge of it. They all should be pushed inward to allow continuous operation.
From the manual:
Please note when you first use your heater, all the tabs are outwards. You must push in those
tabs for the period that you want the heater to work. (If you want to bypass the timer you must
push all 96 tabs inward).
I hope this helps.
Nov 16, 2008 | DeLonghi MG15T SafeHeat Oil Filled...
I hope this helps.
Oct 13, 2008 | DeLonghi MG15T SafeHeat Oil Filled...
Jan 25, 2008 | DeLonghi DR-18TG Oil Filled Radiator...
Heater shut off but doesn't turn on by it'self
Do not touch the timer, once you do, it activates it. Set the temp. and leave the timer alone, unless you want it to shut off at a given time, 1 hr. and up. Once the timer shuts off you will have to start it manually.
Oct 14, 2007 | Honeywell HZ-709 Oil Filled Radiator...
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
