Question about Kodak EasyShare DX6440 Digital Camera
Stuck :( my kodak easyshare DX6440 is stuck. The lens wont retract and whenever i turn it on, the little green light flashes, but then makes a few buzzing noises and turns red. Ive tried new batteries, but it still wont work... what should i do?
  • 2 more comments
  • skye young
    skye young Jan 22, 2007
    oh, and the screen stays black.
  • Anonymous Jun 25, 2008
    We have the same problem. We've used the camera exactly one day. We've tried recharging it, but we cannot seem to find a way to turn the camera off.
  • wilk714 Dec 12, 2008
    Mine was stuck also. I took it apart and couldn't get to the lens motor. I was able to push the lens back in and get the screen to come on. But with the lens closed teh screen shuts off and I'm back to square one. Anyone know how to access the lens motor? The back panel comes off easily, but there is one part on the front panel that sticks on the top of the lens and I can't get that off. Thanks.
  • Anonymous Jan 11, 2009
    easyshare dx6440
  • 3 Answers
I concur. The camera will be "beyond economical repair," and the 10% offer does little for customer loyalty.
Posted on Aug 16, 2008
  • 26 Answers
My Kodak DX6440 did the same thing. After sending it to Kodak's third-party repair (as per Kodak), they called to say it was not fix-able. Kodak's response was "No parts available" and offered 10% off list price of a refurbished camera. ...Big sports ...Way to keep customer loyalty If you choose Kodak, the cameras are good but buy them knowing they are a disposable item. BK
Posted on Jun 18, 2007
It started failing after a few shots in that it wouldn't retract as if the batteries were run down.Now it wont activate even when brand new batteries are put in, It merely flashes with the red allert light...
What can happen is the lens on them can go ofsidded, if the lens is not retracting back in give it a firm push untill u hear a click and turn off and on, hope this helps in some way.
Dec 01, 2009 | Kodak EasyShare C330 Digital Camera
Lens wont retract with or without new batteries. green light blinks but no lens movemant even using wide/tele buttons
Since you already used new batteries and still lens will not moved and you can just see flashing green it means that the Gar of the camera is defective You may call repair center specialize with kodak camera's at 1 800 665 6515
Nov 09, 2009 | Kodak EasyShare C340 Digital Camera
It shuts off after turning on and the lens will not retract makes a grinding sound then shuts off
It seems that the one of the gears of your lens has came loose that is why you are expiriencing the problem. This may happen if the camera has been dropped or the lens has been banged.
You should contact the companies repair center to have your camera fixed
Nov 03, 2009 | Kodak EasyShare DX6440 Digital Camera
Wont turn on
Sir that click sounds is due to shutter breakage and hence you won't be able to access it properly. Take the shutter out after opening it and replace it with a new/fresh one.
Jul 21, 2009 | Kodak EasyShare DX6440 Digital Camera
KODAK M863 LENS STUCK
Here's what I did...Mine had the lens stuck out and would not power on. Just a green blinking for a second or two. Well, I tried twisting the lens ring closest to the camera while hitting the power button. It's kinda tricky to do...BUT, just keep at it. Mine was a $1 resale shop "find" and now it works. This worked for me. Maybe it will help you!
Apr 18, 2009 | Kodak EasyShare M863 Digital Camera
C875 lens won't retract
Camera (with new rechargable batteries) won't let the lens come out or if it does it instantly retracts.
Nov 14, 2008 | Kodak EasyShare C875 Digital Camera
Won't turn on light flashes green then flashes red then nothing else
This usually means weak batteries, the other possibility is the lens mechanism is faulty or stuck. These cameras will shut down if the lens cannot extend or retract. Sometimes you can coax the lens out with a little help by pulling gently on the lens with your fingers if it starts to come out, don't force it. If you have dropped the camera with the lens out, this can damage the mechanism to either work intermittently or not at all.
Oct 12, 2008 | Kodak EasyShare C743 Digital Camera
Kodak dx6440 wont power up lens wont and retract
I have the same/similar problem. I could hear the camera attempting to retract the lens. Camera shut down after timeout.
Disassembled camera & found two teeth missing from plastic gear in gearbox attached to lens motor. Don't know yet if part(s) are available.
Camera had light use. Patheticly short life & that Kodak didn't use stronger nylon gears. Bought a barely use Kodak P880 recently, & the autofocus died shortly after. Web search showed others had same failure. I'll never buy another Kodak camera.
Sep 20, 2007 | Kodak EasyShare DX6440 Digital Camera
Start and die
Could be time for a new camera But check out Kodak Support first. It has been said that cameras in a certain price band[any make/model] are to be considered as disposable -like toasters and kettles I guess.
Aug 22, 2007 | Kodak EasyShare DX6440 Digital Camera
Camera lens will not open
Lens motor shot- contact Kodak repair price likely to be well on the way to a new camera
Jul 31, 2007 | Kodak EasyShare DX6440 Digital Camera
Kodak EasyShare DX6440 Digital Camera Logo
265 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
