Question about Belkin (F5D7230-4) Router (587009)
Wireless Repeater/Bridge (Belkin)
I have a Belkin Vision One as my main router.
I have an old Kiss Media Player which has an ethernet connection (but no wireless). This is in a room with no ethernet cable.
I want to use my old Belkin Wireless Route (f5d7230-4) to connect physically to the Kiss box and wirelessly to my main wireless network.
How do I do this?
    Genius:
  • 1,061 Answers
Http://www.belkin.com/support/article/?lid=en&pid=F5D7230-4&aid=1564&scid=0reset to factory defaults and reset up your laptop All info at factorywebsite here at this web address.RICHARDM69
Posted on Dec 06, 2008
How to make a net gear dgb111g into a dummy or bridge unit for wifi, using with bt home hub?? thank you
SETTING A ROUTER AS A REPEATER 1. Connect your computer to the repeater router's RJ45 port with a LAN cable. 2. Open a browser, then enter the router's URL configuration's IP address, This is usually something similar to 192.168.0.1 3. Enter the configuration user name and password. The router will display the various router settings. 4. Go to the page that changes the IP address of the router. Changed the IP address so that it is not the same as the main router on the network, or any other network devices. If the main router on the network is set to 192.168.1.1 then the repeater router should use a higher number (ie. 10), such as 192.168.1.10 or higher, depending on how many devices are on your network. 5. Disable the repeater router's DHCP server. This setting should be on the same page as the IP address, (this may be different depending on the make of the router). When the main router is operating normally, this server assigns an IP address to every device that is connected to your network. Because this router is used as a repeater, the main router on your network will still issue the IP addresses. 6. Also turn off the DNS server, if it is activated. This function will be taken over by the main router. 7. Disable any firewall settings on the repeater router. This is usually in the "Security" section, depending on the make and model of your router. 8. Remove all in the "Port Forwarding" section. Some routers may refer to this as "Applications and Gaming," and it allows less-restricted access to the internet. 9. Set the operating mode switch to "Gateway" or "Switch" if applicable. Also, if the repeater router is a wireless router then disable the wireless access or set it to access point only. 10. Save the settings for each page, and reboot the router. When the router boots up, the changes will allow it to act as a simple repeater. 11. Now, place the repeater router in a new location and connect both routers with a Ethernet cable in each of the router's RJ45 LAN ports, and power it up both routers.
Aug 15, 2012 | NetGear DGB111G Wireless Router
Can i use my old usr 5461 wireless max g as a repeater?
SETTING A ROUTER AS A REPEATER1. Connect your computer to the repeater router's RJ45 portwith a LAN cable. 2. Open a browser, then enter the router's URLconfiguration's IP address, This is usually something similar to 192.168.0.13. Enter the configuration user name and password. Therouter will display the various router settings.4. Go to the page that changes the IP address of the router.Changed the IP address so that it is not the same as the main router on thenetwork, or any other network devices. If the main router on the network is setto 192.168.1.1 then the repeater router should use a higher number (ie. 10),such as 192.168.1.10 or higher, depending on how many devices are on yournetwork.5. Disable the repeater router's DHCP server. This settingshould be on the same page as the IP address, (this may be different dependingon the make of the router). When the main router is operating normally, thisserver assigns an IP address to every device that is connected to your network.Because this router is used as a repeater, the main router on your network willstill issue the IP addresses.6. Also turn off the DNS server, if it is activated. Thisfunction will be taken over by the main router.7. Disable any firewall settings on the repeater router.This is usually in the "Security" section, depending on the make and model ofyour router.8. Remove all in the "Port Forwarding" section. Some routersmay refer to this as "Applications and Gaming," and it allows less-restrictedaccess to the internet.9. Set the operating mode switch to "Gateway" or "Switch" ifapplicable. Also, if the repeater router is a wireless router then disable thewireless access or set it to access point only.10. Save the settings for each page, and reboot the router.When the router boots up, the changes will allow it to act as a simplerepeater. 11. Now, place the repeater router in a newlocation and connect both routers with a Ethernet cable in each
Jul 18, 2012 | U.S. Robotics USRobotics USR5461 Wireless...
Unable to print from repeated wireless network
If you have done it properly there is no need to bridge networks because there should only be one. The entire idea of a repeater is to simply pick up the signal from the first router and rebroadcast the signal.If you had included the model of the repeater I could have been more specific but as it is, read this: Linksys Official Support Configuring an Access Point as wireless repeater
May 13, 2017 | Cisco Linksys WirelessG Broadband Router...
I need to bridge 2 belkin N300 routers
The easiest way to bridge 2 routers is to turn off the DHCP and NAT on one of them, and connect them from port1 to port1. This of course reduces the number of available ethernet connections, but it does bridge them together... basically it turns one of them into nothing more than a hub/switch.
Jun 04, 2011 | Belkin Surf N300 Wireless Router...
My internet is greatly reduced with Belkin N1 vision wireless (before the hook-up it was 15mbps now only 5mbps), I have tested by hooking directly from the modem to the computer and got 15mbps. Before N1,...
When you only get 5 mbps are you connecting to the new router wirelessly or via the ethernet cable? If it is wirelessly then try connecting with an ethernet cable and see if you still get 5 mbps. If so then try resetting the router (the procedures for this will be explained in the manual) and re-test. Wireless connections can slow down due to obstacles such as thick walls or other obstacles of that type. If all else fails return the unit and try another.
Mar 08, 2011 | Belkin N1 Vision Wireless Router
I have two Dell 2350 Wireless Routers trying to bridge or repeat
The first router must the root AP and the second should be set to Wireless Repeater. Follow the steps on how to resolve this setup.
1. Get the Wireless MAC Address of the main router. The router has two MAC addresses, one is wired and 1 is wireless. To determine the wireless MAC address, go to Status page of the router, there's a sub tab there for wireless and you'll see the Wireless MAC Address. Take note of it.
2. Access the setup page of the 2nd router. Change the LAN IP address to 192.168.0.2 then save. Power cycle it by just turning it off for 10 seconds then turn it back on. You can now change it to Wireless Repeater and there's an option for you to type the Wireless MAC address of the main AP. Make sure all wireless settings are the same on both routers like SSID, Channel and Encryption Key. Save your changes after that.
3. From your computer, try to ping the 2nd AP which is 192.168.0.2. If it replied back, you're all set.
Good Luck!
Jul 25, 2009 | Computers & Internet
Spare Di-624
Well, if you run a LAN cable from your existing router to the DI-624 in a remote location you could use it as an AP, but this router does not support repeater of bridge modes.
May 24, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Hello, I currently use a Belkin F5D8631 as my Modem Router. I have a spare Belkin F5D7633. Can I use the 7633 as a repeater/bridge to extend my wireless range? If so, how?! Thank you
It will not extend your wireless range. If you connect your spare Belkin F5D7633 to your Belkin F5D8631, one of them would have to be set to "bridge mode" or a pass through modem so that there will be no conflicts as to which modem will receive the ip address from the network. If you set your modem/router to bridge mode, it would disable its wireless function because it will only be a pass-through device.
If you want some tips on how to improve your wireless range, check out this site http://www.microsoft.com/athome/moredone/wirelesstips.mspx. Hope this helps.
Apr 22, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
Can I use my belkin N1 Vision as a bridge?
It can't be used as a bridge but you can use it as an Access Point. All you need to do is disable the DHCP server of the router and don't use the Internet/WAN port
Apr 01, 2009 | Belkin N1 Vision Wireless Router
Repeater
The repeater must be the same brand as the signal it is repeating. Different routers / access points work in slightly different ways and the current generation of wireless repeaters aren't smart enough to work with other brands.
It's kind of like trying to put an engine from a Nissan Altima into a Honda Accord... both make the car move but they aren't the same inside.
Oct 31, 2007 | 3Com OfficeConnect (3CRWE454G75)...
Belkin (F5D7230-4) Router (587009) Logo
1,526 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
