Question about Dell Pocket DJ MP3 Player
Firmware Problem So I wanted to install my DJ on a new computer. I installed the software that came with it (Explorer, Drivers, Adobe, MusicMatch) and then I went to recovery mode and selected options 1-3 (Clean Up, Format All, Reload Firmware) and now every time I try to reboot it won't come out of Recovery Mode. The computer recognizes my player, but when I try to install the upgraded firmware or the firmware from the CD it says that my player is not connected. Likewise when I try to open the DJ Explorer it says it's not connected. What do I do? I don't want to have to buy another player if I know this one can work. I have no technical support left with Dell because I've had it for almost 2 years. PLEASE HELP! :(
I had this problem as well and found help. I tried the suggestions below and the problem was fixed! What you can try is this: Open up Control Panel Click on Performance and Maintenance Click on System Click on Hardware tab Click on Device Manager button If you see a Yellow Exclamation mark beside something that looks like the DJ then double click on that. If you see something that says to Update the driver then do so. If it asks to checked Windows Update, choose this option!! If this fails then delete it from your computer by pressing the Del key then clicking OK. Restart the computer, connect your DJ and see if it works properly. If not, open up Device Manager again. This time remove ALL your USB ports, everything under Universal Serial Bus controllers. Restart your computer, let it reinstall your USB devices, connect your DJ with its done, hope it works... If not, open up Add/Remove Programs Click on Show Updates box in the top middle if your running Service Pack 2 Scroll all the way down until you see Windows Media Player 10. If more than one WMP 10 item is showing then remove those first. After your PC restarts remove WMP10. If removed successfully then your computer will now have WMP9 installed. Open up WMP9, click on Help, click on Check for Player Upgrade. WMP10 should be displayed. Let it update... After your computer restarts, install the Windows Media Format 9.5 Runtime from this sticky Restart your computer, connect your DJ and hope it works....... Or you can just take it to another computer running Windows XP and WMP10 and if it recognizes correctly then put back a v1 firmware, I recommend 1.02.01. Download it from this FAQ Hope this helps you as much as it helped me.
Posted on Feb 04, 2007
I have a discontinued dell pocket dj player that when i download the software it says it isnt compadable how do i fix this i have a vista.
Go to dell.com and enter the DJ's service tag ID on the back of your player on the support section. It will give you a list of drivers and software that you will need for your DJ. If you are running Vista, download the XP drivers. They will work fine.
Oct 09, 2009 | Dell DJ MP3 Player
I just got a dell dj20 (unused). no driver disc!
I have the driver as well as the DJ Explorer software to sync songs. I will be glad to try to e-mail them to you. Contact me at marcs2@hotmail.com.
Jun 09, 2009 | Dell DJ MP3 Player
Cannot get my computer to recognize my Dell Jukebox
Assuming that you don't have windows vista, you can load the Dell DJ Explorer program that came with your DJ. It comes up as a regular looking window that should "see" your DJ when you plug it in. If it doesn't, where it says "not connected", right click and then click refresh. Sometimes it works better to plug in the DJ first, then load dj explorer. When it sees it, "not connected" should change to the name of your DJ. Double click that and it should then 'read' your dj, showing all the files on it. Then its just a tedious amount of copy and paste to another folder on your computer (like your My Music folder), and your music is restored to your computer. Take care, as DJ Explorer can also delete files from your DJ if you tell it to.
If you no longer have the DJ drivers and DJ Explorer and Musicmatch loaded on your computer, you can still download that stuff from the Dell site.
If you Do have Vista, try to find a friend with XP. Load the DJ explorer software on their computer, and pull your music off the dj to your friend's computer, then use a USB drive or something to move it to yours. Or better yet, upgrade your computer from VIsta to Xp (yes, I said upgrade - Vista is ****)
Jan 28, 2009 | Dell DJ MP3 Player
Files on Dj Ditty won't show up on computer..
Sounds like you need to reformat the player, but here is my Dell Ditty troubleshooter:
Dell DJ Ditty
http://support.dell.com/support/edocs/systems/P97347/om/OM.pdf - manual
http://www.dellcommunity.com/supportforums/board/message?board.id=dce_djmusic&thread.id=47830 – How to Troubleshoot the Dell DJ Ditty – from Dell
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PDA_MP3_DJ_DITTY&os=WW1&osl=en&catid=&impid= - Firmware for Ditty
Did you run the installation CD first? If you don't, Windows will load its own, possibly wrong, drivers.
Make sure you didn't accidentally press the player's lock button:
The keys on the Dell DJ Ditty have been locked.
Unlock the keys by pressing in on and holding the
Volume/Scroll/Select dial until the lock icon disappears.
Reset method - Insert the end of a thin object, such as a straightened paper clip, into the reset button (near the headphone jack).
Also make sure your operating system is Windows XP - it won't work on anything before or after.
The Musicmatch service that this player was tied to was discontinued in October 2007, so you’re going to have problems even if we get it working again.
The DJ Ditty does recognize DRM-encryption for WMA files – make sure the license is up to date, or convert the file to mp3 format if you are experiencing licensing issues.
If you are experiencing frequent freezing, or a file system/corruption error, or getting the “Warning! Reformat with Firmware Updater!” message, there are two ways to format the DJ Ditty:
Format using Windows Media Player:
Run Microsoft Windows Media Player.
Connect the DJ Ditty to the computer.
Click the Sync button on the top of the menu.
Click the "Format storage media" button on the right-hand side of the screen.
Disconnect the DJ Ditty and power it back on.
Reload or upgrade the Firmware:
Download and install the latest firmware from http://support.dell.com
Run the firmware upgrade program with the "Format Data Area" checked.
-Tha Mp3 Doctor
Dec 14, 2008 | Dell DJ Ditty MP3 Player
My dell dj ditty has frozen
Dell DJ Ditty
-Tha Mp3 Doctor
Oct 06, 2008 | Dell DJ Ditty MP3 Player
My dell dj ditty wont turn on
Dell DJ Ditty
-Tha Mp3 Doctor
Jun 27, 2008 | Dell DJ Ditty MP3 Player
Dell dj computer saysn= not connected
What operating system is your computer? If it is Vista you will have trouble getting your dj to work. Dell dj software was meant to be used with XP or Windows 2000. If you are currently using either one of these two Operating Systems then you most likely have a driver problem. The best solution is to install a software package from Dell, labeled R74224. This package includes the driver and Musicmatch software.
Mar 09, 2008 | Dell DJ MP3 Player
Moving Music Tracks from Dell DJ to Computer
i'm pretty sure you cannot. you can only transfer from dj to dj not to a computer. i had the same thing happen and i don't see any way to do it.
Dec 09, 2007 | Dell DJ MP3 Player
Make vista recognize my dell dj 20 gig
Try downloading the newest firmware to your Dell DJ
Nov 12, 2007 | Dell DJ MP3 Player
Dell Digital Jukebox and Vista
sound easy, just go to this webpage: Driver Update and use their tool to update your drivers.
Cheers
John
Jul 30, 2007 | Dell DJ MP3 Player
Dell Pocket DJ MP3 Player Logo
261 people viewed this question
Top Dell Audio Players & Recorders Experts
Steve Allison
Steve Allison
ptpumpman
Marvin
Marvin
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
