SOURCE: I want to add 1Gig Ram to istalled 512 Mb of ram
Yes, of course you can do this with your own. The first things you should do are they:
You need to buy 1gb RAM which same socket to your old 512mb RAM. Be sure that the said RAM are compatible to your motherboard.
Testimonial: "Thank you for your timely answer,I can upgrade now with no qualms. Kind regards, Brendan. UK."
SOURCE: Upgrade NEC Versa VX
You can insert the Windows XP CD while logged on Win 98 and run a test from the CD. Obviously you need a larger Hard Disk and at least 126 MB RAM to bring XP to a usable speed. You can look for RAM upgrade options in this page.
SOURCE: how to fit ram
turn the laptop off and manually turn it over, there should be a screw covered panel on the bottom of the laptop, un screw the screws securing the panel, then check inside that there is a chip. Your probably going to find a 200pin chip there in one or two slots, that is your ram memory, just replace it with what ever type ram is corrrect for your computer.
SOURCE: How to update ram on NEC Versa M400?
I don't know what a NEC Versa M400 is, but i'm prosuming youve checked under the memory pannel on the bottom of the laptop? if the rams not under one of the pannels on the bottom then you will find it under the keyboad.then just release the 2 clips on either side of the chip & it will pop up. pull it out & put the new one in,you'll see they only go in one way.
