Question about Apple iPhone Smartphone
Iphone touchpad not working
Iphone bottom part of touch is not working plzplzlz help
  • 2 more comments
  • Anonymous Jan 24, 2009
    i have the same problem with my iphone but the instruction that u shown its not working. please help
  • Anonymous Jan 25, 2009
    the bootom half of my iphone is frozen so i cant unlcok it. plz help
  • Anonymous Feb 14, 2009
    Bottom half of the screen is not responding.. Cannot unlock or make calls.
  • Anthony Perez
    Anthony Perez May 11, 2010
    Need more info...
    Novelist:
  • 157 Answers
Hi devanshu-
I have a smiliar problem but only because I was a bit of a twit and dropped my iPhone on the cement and thus, breaking the screen. So now part of my screen wont accept the touch.
If you did not drop your iphone, there are some other possible reasons:
  1. If you have more than one finger touching at one time (unless doing that cool little double finger zoom in), the touchpad will not respond. I have caught myself doing this on accident if I am holding it so my thumb is touching part of the screen as I am trying to make a call or write a text.
  2. The touch sensor is malfunctioning. Sure, this could be a software problem (which is why I am including the directions for the dreaded restore below), but the iPhones touch sensor seems to be a bit sketchy in both the 2gs and 3gs. Since you just bought it, it should be under manufacturer warranty for a year. Go to cingular's website (used to work for cingular/at&t and know that if you go to the store, the procedure is to you to call the 888 number with a smile and do nothing else), get the warranty/customer service number and get them to replace it.
The only bad side to either resetting or replacing your phone is that you will lose your contacts. But, if you choose to try this route (which, in the worst case scenerio, will put you in no worse of a position than you already are with a phone you cant use), I will provide some instructions:
  1. Turn off iPhone - Hold down the Sleep/Wake button for a few seconds until the red slider appears, then slide the red slider. Ignore this step if your iPhone is already off.
  2. Press and hold down the Home button for about 10 seconds until a yellow triangle with a text which says Please Connect to iTunes appears. iphone touchpad not working - iphone-recovery-mode.jpg
  3. Plug the iPhone into Mac or Windows PC. Release the button if you haven’t.
  4. Run and open iTunes if it’s not already opened yet.
  5. iTunes will prompt a message that says iTunes has detected an iPhone in recovery mode. Click OK.
  6. You will be taken to the iPhone pane. Then, click on Restore.
  7. Wait for the full restoration process to complete, and the iPhone will be back to the original settings state as when it left the manufacturing factory, typically a working phone again if you face any problem, unless it’s hardware related.
Hope this helps!!
TJ
Posted on Dec 03, 2008
Gateway NV53A 15.6 inch Notebook, touch pad not working
Touchpad settings: right click on the touchpad icon on the Taskbar at the bottom right of the screen. Click on Default button, then Apply, then OK. Re-try. If that doesn't fix, then TouchPad ribbon inside the laptop needs to be replaced.
Feb 09, 2014 | Gateway MT3705 Notebook
IPhone touch screen not working
Have you tryed reseting and restoreing the iphone?
May 23, 2008 | Apple iPhone Smartphone
Touch pad not working
It's a driver related issue or the touchpad is locked. Unlock it.
Each computer has it's own way on how to unlock the touchpad. Please provide me with the model of your computer so that I can provide you with the correct steps.
You can also scan your computer with RadarSync so that you will know if the drivers are out-of-date especially the touchpad driver. Your touchpad stops working if the driver is out-of-date so you might want to check RadarSync.
David
Jun 16, 2013 | BenQ Computers & Internet
The bottom part of my iphone touch screen doesnt work, i cannot use this part of the phone but everything else works? Any ideas on the problem or the fix?
You need to replace the digitiser of your phone which is the hardware which makes the touch screen work. This is attached to the glass of the touch screen and can be replaced in one. You can do this yourself using tutorial videos although I would recommend using a local iPhone repair shop as Apple will charge extortionate prices for this repair.
Mar 28, 2011 | Apple iPhone Smartphone
The bottom part of my iPhone touchpad is not responding to touch
The touch on the screen works as a seperate component from the screen itself. Either the lower portion is damaged and has to be replaced, or it is wet and can't sence touch as a result. The one may get better in time if the components don't corrode, the other is probably not resolvable...
Dec 03, 2009 | Apple iPhone Smartphone
Iphone - bottom portion of touch screen not working
my cell iphone 's screen is not working. it became black with an arrowhead.
Sep 29, 2009 | Apple iPhone Smartphone
My iphone wont slide to unlock, I dont know what to do??
First try to reset the setting. If resetting wont work, then your touchpad is faulty.
Another way is to press the power button to go into standby mode. and turn it up again. see if the touch is responding.
Else, reset the entire setting, just like formatting it and restoring to the previous version.
If all fails, then you're doom. you'll need a new touchscreen.
Do note that Iphone comes with LCD and touchpad. these are two diff things.
You might need to replace it.
Sep 11, 2009 | Apple iPhone Smartphone
Bottom row of my keypad doesn't work
You have to get it changed
2G iPhone - FULL LCD with Touch Pad !. 3G iPhone - Only Touch Pad !
Best Regards
Jun 24, 2009 | Apple iPhone Smartphone
The bottom part of my iPhone touchpad is not responding at all, even though everything above the first centimeter is. can't use the space bar on the key pad.
try restoring the phone. if that doesn't work there is an issue with the multi-touch display and it needs repair :(
Feb 03, 2009 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
724 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
