Question about Ovens
Oven & hob taking a long time to come on(on FULL pressure)
When initially igniting either the grill or the oven, both will ignite but ''gas'' is only on very low.
Sometimes it takes up to 3 or 4 minutes before they ''fire'' up and I get full pressure.
I only use ONE at a time as per makers instructions,if it's the grill I always leave the oven door open,and if the oven the door remains closed.
Cooling fan is operational.
Can you please help? why are they on what I would term as ''low pressure'' ?
regards Mr M Cartwright
west midlands.
    Scholar:
  • 82 Answers
Hello mick1939. Are the ignitors the clicking/sparking type or the glow bar type?
If they are the glow bar type, when they get older they don't send enough amps to the gas safety valve thus only letting a small amount of gas to the burners. Try replacing them if they are glow bars.
Posted on Dec 01, 2008
Where do i find batteries for ignition in my creda expression l152g gas cooker ?
Not normally batteries, most are mains powered, but your is a single AA battery. The manual states;
The battery is not covered by the guarantee. Use an alkaline AA battery. The battery holder is located in the plinth panel below the oven door. Open the oven door fully. Press the tag on the left hand side of the battery holder/cover and withdraw it just enough to get access to the battery. Fit the new battery with the end marked "+" on the same side of the battery holder as the red lead. Replace the battery holder by pushing it firmly into the hole in the plinth.
The spark unit is usually under the hob on the left side. Check the connections as they can get really messy and even break through. Also spray the igniter posts with oven cleaner and leave for an hour, clean off with a plastic brush and water. Dry thoroughly. On the hobs, remove the burner and wash them, the underside as well as they rely on the earthing through the aluminium ring, remove and clean that too.
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Creda/Cooking/HBC150GG.pdf
Feb 17, 2018 | Creda Ovens
Why does grill ignition click when bottom oven lit
ignition probably serves both, if clicking when not lighting, fault or sticking button
Jan 04, 2016 | Stoves Premier 720GRa Gas Double Oven
Oven wont light keeps making the clicking sound smell of burning and smoke appears grill working normally?
Sounds like the jets at the base where the gas ignites are blocked. Try cleaning those out with a metal skewer or similar
Sep 12, 2014 | Ovens
Cannon double oven
The quality of new stuff is not as good at the old, but they are shiny and clean to start with.
With the upper burners, they have just a standard gas igniter, but you say there is no gas. This can only be cause by two things, but most likely a blocked jet for some reason. The only other reason is a faulty control.
The grill is the same, some share igniters, some have one for each of the three department, hobs, grill, ovens.
So your choice is buy a new one or get a service engineer in. It is gas, so you shouldn't really work on this on your own for safety reasons.
Feb 02, 2018 | Ovens
Hi there, I have a belling gas oven cooker, which when you try to ignite the oven or grill it keeps ticking but wont spark up. The gas is fine as you can light them manually and the hobs light fine so...
why would they be trying to light an electric oven ( see which product do you think they mean ) You need to check that the spark being produced is close enough to the gas outlet
Oct 03, 2012 | Ovens
Oven wont turn on
I have a delongi oven and hob hob is working fine but the oven isnot im turning the nob on the front of the oven and ignition on lighting is fine after I release the knob on the front the supply turns striaght off no flame no gas nothing
Apr 04, 2011 | DeLonghi Ovens
I CLEANED MY CANNON CARRICK COOKER TODAY AND NOW THE IGNITION WILL ONLY WORK ON THE TWO RIGHT HAND HOBS. OVEN ANG GRILL ARE FINE AND LEFT HAND HOBS CAN BE LIT WITH A MATCH.
More that likely your just got the cleaning solution you used on the igniter/in the burner. Light the burners with a match and let them burn for a little bit of time. This usually works. If not you might have to clean the igniter and make sure it is creating a spark for ignition.
Mar 07, 2011 | Ovens
Trouble lighting gas oven. Brand is a Chef
your thermocouple needs replacement
Aug 31, 2009 | Ovens
Grill ignition is sparking when the oven is on
if the grill is constant sparking when the oven was on and turns off when the oven is not in use then u either have a defective pcb/ht lead or electrode if it is self lighting or if you have to push in a button then this button or control will have a problem
Aug 21, 2009 | New World G70m Gas Double Oven
Ignition switch on a gas hob/electric oven not sparking
Some have a AAA battery under the button - replace this, others use mains to create the spark, ensure you have the ignition wired up
Jun 01, 2009 | Ovens
Ovens Logo
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
