Question about Panasonic TX-28DK2 TV
Tv is on stand by but won't 'fire up'
Have a Panasonic tx-28dk2. Whilst watching it flicked off into stand by mode. Used the remote and it came back on 2 days later it did the same but would not come back on, the screen flicked as if to come on but immediatly turned back into 'stand by'. I systematically pulled out leads and came to unplug one of the 'push-in' speaker connectors (the 'sub woofer') and after I could turn it back on. It seemed fine. I reconnected the speaker lead thinking it may have been a coincidence as I had turned the power completely off during the taking-out-of-leads. All was back to normal. It happened again, going to stand by, so I went straight to the subwoofer lead, started up after taking the lead out. So I left the lead out. Wouldn't turn on again the next morning but the speaker lead was unplugged. Have unplugged everything and turned it on and off no joy, picture flashes as if to turn on for a fraction of a second then goes straight to standby and blank. I'm guessing its a power surge/short somewhere and the circuits are 'protecting' themselves. Any pointers for a quick fix? Or is it for the knackers yard? I DO want a new flatscreen but, I do like the picture and sound of this telly, and I could do with saving the pennies.
  • 1 more comment
  • Anonymous Nov 24, 2008
    standby light on but no picture,turn on tv flickers and turns back to standby
  • martynthe gr Nov 24, 2008
    same as andy s's
  • Anonymous Apr 05, 2009
    my sony trin a tron vega t.v. clicks on and red lights flash, then it goes straight to standby. no picture ever comes up?
    Novelist:
    Champion:
  • 236 Answers
I don't know the age of your set but I've found some Panasonics with a loose connection on the heat sink (an aluminum plate standing vertically on the circuit board) of the regulator IC (chip). The IC gets its ground through the heatsink. If the ground is open the power supply puts out too much voltage and causes the set to go into shut down. I've found this problem several times. Stargazer
Posted on Jan 28, 2007
Had the same on my Panasonic wide screen, took it into the shop and was told the tube was dead, so too expensive to repair so had to go. Went on ebay and got a £30 replacment set until i can pick the flat screen unit i want.
Posted on Mar 30, 2010
SOURCE:
Panasonic TX-L42S10B has power but won't turn on
ok, this may be a silly question but when you turn it on and it starts flashing red, have you tried pressing the stand-by button on the remote. if a tv has been put on stand-by by the remote, and is then switched off by the set, when the set is turned back on it is still in stand-by mode and you need to press the stand-by button on the remote.
other than that I don't know.
Nov 08, 2013 | Panasonic TXL42S10B 42 in HDTVReady TV
Universeal remote control coad
GET ANOTHER AT WALMART THEY COME WITH PASS CODES YOU WILL BE HERE ALL DAY FOR SOME ONE TO TELL YOU PASS WORD THEY THINK IS TO YOUR TV.
Feb 15, 2011 | Panasonic TX-28DK2 TV
Can we simply use this tv as a monitor? if yes then how? Apart from this i m also facing a problem that is like the TVs visual r coming in negative and is keep on shaking?
if it has a VGA port its possible for you tu use it as a monitor...
most of the flat tv nowadays are also good as monitor.
Mar 26, 2010 | Panasonic TX-28DK2 TV
Freeeview update has not allowed BBC1, BBC2 Channel 7 and 8 to be viwed. They have been deleted from the menu on digital. I can get BBC1 and BBC2 on analog.
Make sure all cables are securely connected to your Freeview Box or Freeview TV before you begin
Do a Factory Reset of your Freeview TV and then do a rescan of new channels. If successfull then all channels should be back and working.
Oct 14, 2009 | Panasonic TX-28DK2 TV
I want the sky remote to put the volume up and down on my panasonic tv so i need a code, model no th-42px80b,thanks if u can help.Colin
Hello Colin
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0051
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Apr 26, 2009 | Panasonic TX-28DK2 TV
Tv on mute
turn the tv off at the mains leave for 10 - 20 mins the turn back on, this should solve your problem.
Mar 10, 2009 | Panasonic TX-28DK2 TV
Sky remote to control Panosonic TV PV M20F8
Panasonic
0051
678,254,278,154,242,241,368,128,191,368,395,585
Try These might help
Feb 15, 2009 | Panasonic TX-28DK2 TV
I`m trying to get my tv working with my sky remote
press tv, then select and red together until it blinks, then enter 0254. Worked for me.
Dec 30, 2008 | Panasonic TX-28DK2 TV
Panasonic TX-28DK2 TV Logo
507 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
