Question about Lexmark Office Equipment & Supplies
When i am trying to print my work the paper goes to the one side and does not print, when loading the paper it happens to
  • smithjean23 Dec 02, 2008
    it has gone a little better but still not right as it is not pulling through the machine
  • Anonymous Jan 12, 2009
    my paper won't pull through when I am trying to print or when I push the paper feed button
  • 35 Answers
YOU HAVE A JAM AND OR A BAD ROLLER.
LOOK IN THE AREA THAT(SAY PULLS TO THE RIGHT LOOK ON THE LEFT ECT.)
TRY THIS FIRST
YOU MIGHT NOT SEE IT AT FIRST SO TAKE A PIECE OF CARDBOARD THE THICKNES OF A MEMOPAD AND FLOSS THE THE PRINTER WITH IT.
Posted on Dec 01, 2008
When printing uisng an mf4270 I get an error "load correct paper". I am using A4 and the setting is A4 on both printer setting as well as printing driver. My OS is Win7 and editing software MS office and...
Hi
Just a thought but is the printer detecting the "type" of paper you are trying to use, as opposed to simply the size. For example, is it trying to load "glossy photo paper" specified by the printer utility and finding standard photocopy paper.
Cheers
Dec 06, 2014 | Canon Image Class MF4270 Monochrome Laser...
My printer prints blurrey out of focus pictures. I download from my camera and print a few on photogaph paper. This happened once before and for reasons that evade me it cleared up and printed fine. ...
Before replacing this awesome printer try this steps first.
First check the paper you're using, load the paper with the printing side down.
In the program being used for printing, click File , and then click Print .
Make sure the appropriate printer is selected, and then click Preferences or Properties.
Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
Paper size : Make sure that this option matches the paper loaded in the product.
Make sure that the image file has enough resolution for the size of the printed picture. Although many photo applications can enlarge an image or part of an image to any size, eventually the individual pixels become visible and the whole image looks blurry.
Apr 23, 2011 | HP PhotoSmart C4280 Laser Printer
Which way do I insert the transparency into my front loading MP 560 Canon Printer.Shiny side up or down Thank you V
It depends on which side you want to print on. For transparencies, you want to print on one side only. Most likely, you want to print on the shiny side; essentially as if it were a glossy photo. Load the transparency so that the shiny side gets printed on. Don't know that part? Front loading printers are the easiest to determine which side is printed on. Look at where the paper goes in and where it comes out. Think about it; for single sided printing, the paper isn't being turned around inside; merely rolled around an internal roller, then back out. Watch what happens to the paper the next time you print on a single side. See if the top of the printed page came out first, or last.
The most common designs of front-loaders have the paper come out above where it went in. The paper curls around the bottom of the internal roller and comes right back out on top. Therefore, the printed side started out on the bottom, then curled around the internal roller and came out with the printed side up.
Most front loading printers have the top of the printed page come out first; therefore, the same edge that went in first, got printed on first. With that in mind, if you ever want to print on the unprinted side of a piece of paper (that is already out of the printer), obviously keep the printed side up, but since the top of the printed side came out first, you need to make sure the top goes in first to come out first for the back side.
Your Canon 560 printer has duplex printing, so it is a good idea to run your test to see what happens when printed on a single side, and what happens if you use the duplex-mode. For duplex mode printing, after printing on one side, the printer pulls the paper back in to print the other side automatically. Think about how much space is inside the printer. Depending on how much data the printer can store, either the first page is printed, then the second page, or the second page is printed first, then the first page. It depends on how the printer wants the page to come out. You can run a simple test and see exactly what happens.
Since the printer cannot easily turn the paper around, it merely starts with the opposite end of the first printed side when it prints on the back. If the top of the page came out first for the first printed side, the printer prints the bottom lines of the second page of text working back to the top in reverse order. As a result, the bottom of the page comes out first, with the top coming out last.
Some duplex printers can store so much data that the determine how the second page will look, print it first, then print the first page. Watch to see what yours does.
Worse comes to worse, mark a sheet of paper in one corner, insert it into the printer, then print a document that contains only the period character and see where it is printed. By knowing how you put the paper in, and where the period was printed, you can tell how to handle any situation. By the way, the period character was chosen because it will be so small that most likely you can use that sheet again.
Jan 07, 2011 | Computers & Internet
Printer won't take paper through
Hello there
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 23, 2010 | Office Equipment & Supplies
Paper stuck under the print head container
pls clean ur drum with tissue paper or soft cloth and then try once
even after if the same thing happens change the drum or catridge
Sep 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Problem with paper loading. Left side of paper
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Aug 19, 2009 | Epson Stylus NX100 InkJet Printer
I have an Easy Share printer dock series 3 that has paper loaded
Dirty rollers? I had the same problem and think the rollers are no longer sticky enough to pick up the paper due to a coating of dust... maybe cleaning the rollers would work?
Jan 28, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
Paper not loading (but it is)
If it's an older machine, try cleaning the Multi-sensor (next to the printhead with the scissors icon on it).
Mar 12, 2008 | Epson Stylus Pro 4800 InkJet Printer
Paper won't load
first this to do is turn it off unplug, take paper tray out and remove paper and clean the tray, take the printer and put it on it's side (the side where the paper tray goes and see if you get any paper dust to come out. other wise blow air into that area you will see a roller on top need to clean that.
Feb 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
All in one printer
This seems to be a paper registration problem for the copy function only that is an HP thing Good old HP so innovative and so secretive none of us know whats going on most of the time. Two things to try. Take the stack of paper out of the feed tray and riffle so that it is slightly 'untidy' switch off the device , load the paper, switch on- see what happens. Next look at the software disk- there is usually a fully comprehensive reference manual on there [more than in the book]- check that out then come back.
Sep 06, 2007 | HP OfficeJet 6110 All-In-One InkJet...
53 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
