Question about Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Screen goes blank
After it turns on, 1 second later it goes blank. When I turn it off and back on again I always get that 1 sec. then it's blank again. as if the hibernate is set to that or something. What can I do to fix it. I dont have a power supply that is a 4amp like it says, could the lack of amperage cause this or is it something internal. I have seen several other people with this same error, but have yet to see an answer that works. I have a brand new VGA cable for it, so thats not it!
Please help, Thanks.
Mark
  • millerisgenu Dec 03, 2008
    You were absolutely right. Thank you for oyur help. My monitor is working like a champ now!!!
    Thank you again,
    Mark
  • 32,281 Answers
It looks like your power supply is shutting down (terminal overload shutdown) due to excessive current consumption. You need to get a power supply that meets the voltage and current requirements of that monitor or greater current reuirements (greater than 4 amps).
Posted on Nov 30, 2008
Monitor flickers and goes blank after 5 seconds and keep repeating this very often.
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 26, 2010 | Acer AL2016W 20" LCD Monitor
Screen goes blank when first turned on, have to keep restarting m
Take care.
Jul 24, 2010 | Dell E153FP 15" LCD Monitor
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Monitor goes blank less than a second after turning on.
YOU NEED TO HAVE THE INVERTER BOARD REPLACED.
YOU CAN USUALLY FIN THEM ON E BAY OR YOU WILL HAVE TO TAKE IT IN IF YOU DON'T FEEL COMFORTABLE REPLACING IT YOURSELF.
Dec 18, 2008 | Proview PL926WBi 19" LCD Monitor
LCD blank screen, blink white
blank_page Use a reset sequence on the monitor-
1. turn off monitor
2. unplug power
3. plug power back in, holding down the last button on the left, then push the power button to turn back on and off three times, holding on the third try until it comes on- hold for ten seconds and release; the monitor should work again
Jul 28, 2008 | Computers & Internet
X20G-Naga III screen goes blank after 1-2 secs
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 31, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
Cell phone (Sony Ericsson W910i) turns itself off every 30 seconds
i have one too and it always turns itself off at least 15 times a day and a red light comes on at the back and the screen is blank. It hangs up on people half way through phone calls, and tells me i have messages wich i don't and comes up with blank messages which i can't delete!! Today it has done the exact same thing again but it has been frozen for over 3hours i have tried taking the battery out and nothing works :(
Feb 26, 2008 | Cell Phones
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Kogi l7eh-ta ko 17" Flat Panel LCD Monitor Logo
106 people viewed this question
Top Kogi Computers & Internet Experts
Laxman Bisht
Laxman Bisht
Computer Links
William Miller
William Miller
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
