Question about E-Machines T2642 PC Desktop
It wont stay on
When i turn my tower on, it shuts right off... but then turns back on (by itself) and beeps some sort of code at me, 1 beep 3 beeps 3 beeps 1 beep... i dont know what to do.
Tried cleaning the insides of the computer... pretty dusty cuz it was an old computer... hey it worked! my conputer is fine... just dont forget to plug everything in! and the code (1 3 3 1) it means theres a bad connection in the tower and the tower cannot complete the task at hand (via turning on for me...)
Posted on Jan 22, 2007
    Problem Solver:
  • 5 Answers
Probably bad memory, 256MB DDR (PC 2100)
The tower turns on but does not boot the monitor
There could be a problem with the connection to your monitor.
Dec 21, 2013 | Gateway ATXSTF MNT Pro S P4 1500 Tower...
Maxdata tower computer : - when switched on bleeps 2/3 times and doesn't engage the mouse or the keyboard and the monitor shows " no video input ".Just no response and doesn't turn itself on...
BIOS Beep Codes
Whenever a recoverable error occurs during POST, the BIOS displays an error message describing the problem. The BIOS also issues a beep code (one long tone followed by two short tones) during POST if the video configuration fails (a faulty video card or no card installed) or if an external ROM module does not properly checksum to zero.
An external ROM module (for example, a video BIOS) can also issue audible errors, usually consisting of one long tone followed by a series of short tones. For more information on the beep codes issued, check the documentation for that external device.
There are several POST routines that issue a POST terminal error and shut down the system if they fail. Before shutting down the system, the terminal-error handler issues a beep code signifying the test point error, writes the error to I/O port 80h, attempts to initialize the video and writes the error in the upper left corner of the screen (using both monochrome and color adapters).
If POST completes normally, the BIOS issues one short beep before passing control to the operating system.
I hope this helps.
Mar 14, 2011 | Computers & Internet
My computer is beeping and the green light is staying on but the red light is not on and it just beeps i changed the battery and still beeps and no signal
If you are receiving continuous beeps, it means that computer is not recognising the RAM (memory). In this you have to open the Computer and follow the below steps:
1. Turn OFF the computer
2. Open the flap of the Tower (Remove the screws from the back of Tower)
3. Now, On the Motherboard you will be able to see the RAM see the picture nanjia.jpeg
4. There should be two pins to unlock and remove it
5. Once removed, clean the terminal and replug it.
6. Turn ON the computer, it should take care of the issue
Thanks and regards,
Jitha
Nov 22, 2010 | Computers & Internet
My Dell Inspirion Mini 10 is beeping 8 times when I turn it on. Nothing on the screen.
Try holding Fn + End with battery and power cord out and while still pressing Fn + End plug only power cable back in and try to power on.
Oct 12, 2010 | Computers & Internet
My computer doesn't load on the screen as I turn it in
A solid amber power LED on a Dell System is indicative of a no post. There are 4 diagnostics LEDs on most Dell Towers (Either on the back marked ABCD, or on the front marked 1234) they can give more details of what the POST problem is.
Troubleshooting: Disconnect all external connections to tower except power, turn it on, see if the LED indications changed. If they change, then connect disconnected items one at a time till the failed item is found. If no change, the open tower, remove all PCI expansion cards, see if system will boot. If still no change, then most likely a motherboard failure. Take RAM out, see if you get a Beep error code when powered on, if no beeps, replace motherboard. If it does beep, try RAM modules one at a time, if it boots with 1 but not the other, replace the effected module. If no boot, with either replace MB
Oct 08, 2009 | Dell E173FPb 17" TFT LCD Monitor
Tower pushing out air and beeping and can't turn on PC
the beeping is post codes. they are telling you something is wrong. the code is a code for what is wrong like 3 beeps 4 beeps 1 Beep then repeatsthat code is 341. first thing i would do is pull out you ram and reseat it. that is the most common problem.
Jun 23, 2009 | Gateway 838GM (RB838GM) PC Desktop
Turn on Pc and I get 3 beeps and it shuts off
make a clean the memory or replace the memory
May 23, 2009 | DFI AK74-SC Motherboard
Beep codes
1 Long Beep: Memory problem
Explanation: There is a failure of some sort related to the system memory.
Diagnosis: The first bank of memory probably has a failure of some sort; this is usually just a physical problem such as an incorrectly inserted module, but may also mean a bad memory chip in a module. It is possible that there is a failure related to the motherboard or a system device as well.
Phoenix BIOS ERROR BEEP CODES
Phoenix BIOS beep codes are a series of beeps separated by a pause, for example:
beep --- beep beep --- beep --- beep beep would be 1-2-1-2
  • 1-1-4-1 - Cache Error (level 2)
  • 1-2-2-3 - BIOS ROM Checksum
  • 1-3-1-1 - DRAM Refresh Test
  • 1-3-1-3 - Keyboard controller test
  • 1-3-4-1 - RAM Failure on address line xxxx (check memory)
  • 1-3-4-3 - RAM Failure on data bits xxxx of low byte of memory bus
  • 1-4-1-1 - RAM Failure on data bits xxxx of high byte of memory bus
  • 2-1-2-3 - ROM copyright notice
  • 2-2-3-1 - Test for unexpected interrupts
May 14, 2009 | AOpen AX34-U Motherboard
Computer tower started beeping
If you added more memory this may make your tower beep.
If so I WOULD REMOVE THE ADDED MEMORY AND THEN RESTART
Jan 12, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
Dryer turns itself on & beeps, then off again
aye, see if you can enter the diagnosis mode. What we are looking for is the F-02 code. This will flash when there is a stuck button or user interface problem and only displayed in the test mode. With the unit plugged in and all indicator lights off, select any button except stop. Press for 3 seconds, release for 3 seconds, press for 3 seconds, release for 3 secnds and press for 3 seconds. If you did it right 88 should appear. Press the same button again and if there is a error, it should show up. If no error code shows, open the consol and check the p-5 connector. This will be the interface ribbon to the board. Reseat it and see if the problem stops. Catriver
Jul 16, 2007 | Kenmore 67082 Electric Dryer
E-Machines T2642 PC Desktop Logo
316 people viewed this question
Top E-Machines Computers & Internet Experts
Steve Allison
Steve Allison
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
