Question about Sony Handycam DCR-DVD205 DVD Camcorder
Sony handycam DCR-DVD205: use new ac adapter or reinsert
I have a sony handycam DCR-DVD205. I have taken it out from a cold place to warm palce and after that it while starting it shows the error msg "use new ac adapter or reinsert". I read the manual and kept it in cool place but even after seven days I am getting the same error msg. Pleae help me out.
    Scholar:
  • 107 Answers
Remove the battery insert your AC adaptor turn on your DVD CAM if it work fine reinstall the battery set CAM to off position the amber light should be on to indicate battery is charging
You got that msg depend what function you use if the CAM calculated the battery not enough to run or finish this task it display that msg for you to use AC adaptor to ensure no power corrupted such in formating the disc
Some time system control is faulty even you use AC adaptor it still display this msg I hope that is not in your case
Let me kown how you go with this problem
Posted on Dec 02, 2008
How do I transfer video to PC
The DCR-DVD205 does not support a direct connection to a PC. You have to record to a disc on the camcorder and then play the disc on the PC. Please see the instructions beginning on page 61 of the manual.
May 24, 2012 | Sony Handycam DCR-DVD205 DVD Camcorder
Sony dcr-pc9 ejects tape when trying to load....not a claening issue..common symptom on this model
Try this:
1. Turn off the Handycam
2. Remove the battery from the Handycam.
3. Remove the AC Power Adapter from the Handycam.
4. Move the Handycam power switch to the ON position.
Note: Leave the switch in the ON position for at least 15 seconds.
5. Move the Handycam power switch to the OFF position.
6. Connect the AC Power Adapter to the Handycam.
7. Turn on the Handycam.
Apr 05, 2011 | Sony Handycam DCR-PC9 Mini Digital...
Camcorder say inerset new ac adapter or reinsert
your adapter is not makeing contact with the camcorder itself ,poss. not seating all the way,check to see that it is seated properly.
Oct 15, 2010 | Sony Handycam DCR-DVD105 DVD Camcorder
AC Power Adapter
Hi here is link where you can buy this ac adapter/charger for DCR-DVD108
http://azsurplus.com/index.php?main_page=product_info&cPath=1_85&products_id=1910
it is also works with more models as mentioned bellow
Compatible Part Numbers: AC-L20A, AC-L25A, AC-L25B, AC-L200
Input: AC 100V-240V 50/60Hz
Output: 8.4V 1.5A
Dimension Approximate: (48mm x 29mm x
To Use With :
CCD-TRV138
CCD-TRV338
DCR-DVD103
DCR-DVD105
DCR-DVD108
DCRDVD202E
DCR-DVD203
DCRDVD203E
DCR-DVD205
DCR-DVD305
DCR-DVD403
DCRDVD403E
DCR-DVD405
DCR-DVD505
DCR-DVD508
DCR-DVD7
DCR-DVD92
DCR-DVD92E
DCR-HC1000
DCR-HC1000E
DCR-HC16E
DCR-HC17E
DCR-HC18E
DCR-HC19E
DCR-HC20
DCR-HC20E
DCR-HC21
DCR-HC22E
DCR-HC26
DCR-HC28
DCR-HC30
DCR-HC30E
DCR-HC32
DCR-HC32E
DCR-HC36
DCR-HC39E
DCR-HC40
DCR-HC40E
DCR-HC42
DCR-HC42E
DCR-HC46
DCR-HC65
DCR-HC85
DCR-HC85E
DCR-HC90
DCR-HC90E
DCR-HC96
DCR-HE20E
DCR-HE22E
DCR-HE30E
DCR-HE32E
DCR-HE40E
DCR-HE65E
DCR-HE85E
DCR-IP1
DCR-IP1E
DCR-IP210E
DCR-IP220
DCR-IP220E
DCR-IP45E
DCR-IP5
DCR-IP55
DCR-IP55E
DCR-IP5E
DCR-IP7BT
DCR-IP7E
DCR-PC1000
DCR-PC106E
DCR-PC107E
DCR-PC108E
DCR-PC109
DCR-PC109E
DCR-PC350
DCR-PC350E
DCR-PC53E
DCR-PC55/B
DCR-PC55/R
DCR-PC55/S
DCR-PC55/W
DCR-PC55E
DCR-SR100
DCR-SR200
DCR-SR300
DCR-SR40
DCR-SR60
DCR-SR80
DCR-SR82
DCR-TRV280
DCR-TRV480
HDR-CX7
HDR-HC3
HDR-HC5
HDR-HC7
HDR-SR7
HDR-UX5
Jul 11, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
I want to connect my DCR-DVD205 to my imac
Correct me if I am wrong, but isn't this a DVD camcoder, as in records directly to 3" DVD's?
If so, just put your mini DVD into the tray as you would a normal DVD. There is a smaller inner ring on the dvd tray made for 3" discs to sit in.
From there you can edit it directly from the DVD to the computer, and burn it back out onto a normal blank DVD.
Hope that all makes sense =)
Apr 11, 2008 | Sony Handycam DCR-DVD205 DVD Camcorder
Dcr-dvd 205 error code
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Oct 05, 2007 | Sony Handycam DCR-DVD205 DVD Camcorder
Sony Handycam DCR-DVD205 DVD Camcorder Logo
751 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
