Question about Epson Stylus C46 InkJet Printer
I need to change my ink cartridge but the holder will not move to
The correct position
  • Dominic
    Dominic May 11, 2010
    When you open the lid to your printer the ink cartridges should move to a position for you to replace them...
    What are you having problems with?
    Problem Solver:
  • 18 Answers
Go to the epson website and find the manual
Posted on Nov 30, 2008
How do I get cartridge holder to move to change position?
Hi there bud. Don't worry. Explaining it via text wouldn't be the ideal way so I attached a link to a easy video guide , please do watch it . Hope it will help ya. Good luck!
Note :
This is the best video guide I found and it's for everyday general printer .
Aug 02, 2016 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
How to replace catridges for Epson Stylus Office T40W??
Good day. I hope this steps can help you in replacing your cartridges. This how i remember doing it. Just follow these steps.
>Make sure the power light is on, but not flashing.
>Open the printer cover and the output tray.
>Press the ink button. The ink cartridge holder moves to the ink cartridge check position and the
power light begins to flash.
>Press the ink button again. If more than one ink cartridge is expended or low, the ink cartridge holder moves to the mark.This
occurs each time you press the ink button until all expended or low ink cartridges have been
indicated. Once all of the expended or low ink cartridges have been indicated, the ink cartridge
holder
moves to the ink cartridge replacement position when you press the ink button. >Open the cartridge cover and place the ink cartridge into the cartridge holder with the bottom down.
Then push down the ink cartridge until it clicks into place. Then close the cartridge cover
>Press the ink button and then the printer moves the ink cartridge holder and begins charging the
ink delivery system
Hope this will help you a bit with your ink cartridge replacement problem. Have a great day.
May 22, 2011 | Epson Computers & Internet
In the maintenance section Inkjet Cartridge Repacement does not work. The cartridge does not move into position to be replaced.
Hi!
Does it make a grinding noise when you change the button to replace the ink? As if it is trying to move the cartridge holder to a position where you can replace the ink?
If the cartridge holder has like a lock to keep the ink cartridges in place, try to use a flat object that you may insert to push it down.
One or two things- you may have not close that ink latch properly so it won't move, or the mechanism for printer is damaged.
Thanks for your time and using Fixya Online Support. Cheers!
Jan 02, 2011 | Epson Stylus Photo R300 InkJet Printer
Epson stylus sx200 refuses to acknowledge black ink bought direct from epson
I believe the DX series and the SX use the same system
# Determine which ink cartridges are not recognised.
# With the ink cartridge holder in the ink cartridge replacement position, lift up the ink cartridge holder lid and take the cartridge or cartridges out.
# Check that the cartridge is a genuine Epson ink cartridge - look for the EPSON branding and T0xxx codes on the cartridge labels.
# Check that the cartridges are correct for your Epson product.
# Wipe the green Intellidge Chip on the cartridge that is not recognised.
# Check the chip contacts within the ink cartridge holder for any debris or dried ink and wipe with a lint-free cloth if necessary.
# Check that the plastic at the bottom of the cartridge has been pierced.
# Check that the cartridges are in the correct slots.
# Reinstall the cartridges into the ink cartridge holder in the correct order.
# Push the ink cartridge down firmly. It should click into place.
# Repeat this for any ink cartridges that were removed.
# Push the ink cartridge holder lid down. It should clip into place and be secure.
# Press the Stop button, this will return the ink cartridge holder to the right hand side of the unit.
# If the error light flashes after the print head returns to the home position, the ink cartridge may not be installed properly.
# If the red light is no longer displayed, but Status Monitor still reports a Non-Genuine Ink warning.
# If the red light is still on the printer, and Status Monitor indicates that an ink cartridge is not recognised, follow the steps below.
# If the problem remains, there may be a fault with the ink cartridge.
Dec 30, 2010 | Epson Office Equipment & Supplies
How do I load the ink cartridges into the Canon Pixma printer MX320?
1. Make sure that the power is turned on, and open the Paper Output Tray.
2. Lift the Scanning Unit (Cover), then hold it open with the Scanning Unit Support on the right side.
The FINE Cartridge Holder moves to the replacement position.
3. FINE Cartridge.
(1) Pinch the tabs and open the Ink Cartridge Locking Cover.
(2) Remove the FINE Cartridge.
4. Prepare the new FINE Cartridge.
(1) Take a new FINE Cartridge out of its package and remove the orange protective tape gently.
5. Install the FINE Cartridge.
(1) Put a new FINE Cartridge in the FINE Cartridge Holder.
The Color FINE Cartridge should be installed into the left slot and the Black FINE Cartridge should be into the right slot.
(2) Close the Ink Cartridge Locking Cover to lock the FINE Cartridge into place.
Push down the Ink Cartridge Locking Cover until it clicks.
(3) Confirm that the Ink Cartridge Locking Cover is closed correctly.
(E) Closed correctly
(F) Not closed correctly (the cover is tilted)
6. Lift the Scanning Unit (Cover) slightly to set the Scanning Unit Support back to its original position, and gently close the Scanning Unit (Cover).
Oct 05, 2010 | Canon Office Equipment & Supplies
How do u change the ink in the epson 6000?
Things You'll Need:
  • Replacement cartridge (black, cyan, magenta, or yellow)
  1. Step 1 Turn on the printer and press the Color button.
  2. Step 2 Lift up the scanner and wait for the ink cartridge holder to move into position. Remove the ink cartridge holder's cover.
  3. Step 3 Push the tab at the back of the empty ink cartridge to free it from the cartridge holder. Lift the empty cartridge out and dispose of it.
  4. Step 4 Prepare the replacement cartridge by shaking it gently while still in its packaging. Remove the cartridge from its wrapper, taking care to hold it by the sides.
  5. Step 5 Insert the replacement cartridge into the appropriate slot of the ink cartridge holder. Push down on the replacement cartridge until it clicks into place.
  6. Step 6 Close the cartridge cover and lower the scanner until it clicks into place. The printer is now ready for operation
Nov 15, 2009 | Epson Stylus CX6600 All-In-One InkJet...
E5 error
HI ...
This error comes in when the cartridge is not installed correct ... I would suggest you remove and then re-install the cartridge using the below steps:
Removing Ink Cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
    Note: Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
Installing ink cartridges:
    Note: After confirming that the scanning unit support is fixed into position, release your hands.
  2. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot
  3. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  4. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  5. Fold the scanning unit support and close the scanning unit (printer cover).
  6. Wait until the preparatory operation is complete; it takes about one to two minutes.
Please vote if this helps ... Cheers :)
Jul 26, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Change ink cartridge on epson stylus SX200 -printing head moves from side to side but then parks to the R and I cannot get access to change the cartridges.........
The ink cartridges are all separate so you press the cancel button (with no jobs pending) to bring the cartridge holder in to the right place open the holder remove the cartridge and then replace it, let the printer purge the cartridge then your good to go
Mar 24, 2009 | Epson Stylus Photo R320 InkJet Printer
I need to change the ink cartridges on epson stylus sx200 but i need help as instruction book doesntreally tellyou how-thanks
buy an ink cartridge made specifically for your printer. Turn on your printer and raise the lid or press the cartridge changing button. 3 Wait for the cartridge carrier to slide out. with an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal. Carefully remove the tape from the ink opening on the bottom of new cartridge. Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been. 7 Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned. with an Epson printer close the cartridge holder lid and press the cleaning button to charge the cartridge. Close printer cover.
Dec 09, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Print cartridges Epsom Stylus CX4300
Hi.... i had the exact problem... heres how to change the cartridges manually:
i got windows vista not sure if it will work for XP
open control panel..... go to printers... right click on ur printer.... go to printing preferences... then click on the maintenance tab... select on the ink cartridge replacement.... and it should work from there on
Dec 09, 2008 | Epson Stylus Photo RX700 All-In-One InkJet...
Epson Stylus C46 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
