Question about Yamaha RX-V800 Receiver
Loses settings after power off
Lovely box, but I now have to reprogram it every time I have a power cut. (I get those on a monthly basis).
Is there a replaceable battery to maintain custom settings?
The cap he is taking about is c633 it is about $4. Look in the parts list to find the part # and order it. It is available
Posted on Oct 04, 2009
  • 71 Answers
Garetht, there is a capacitor to maintain your settings. This capacitor may have leaked on your board and can damage it. You should replace it and clean the area around it as soon as possible to avoid problems. The capacitor is located on CPU board and looks like a coin with two terminals.
If you are not experienced with this kind of repair, take the amp to a qualified technician.
Posted on Dec 01, 2008
Samsung LNT4032H LCD TV lose backlight after period of time. Still hear audio. What are my steps for testing?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
May 15, 2016 | Samsung Televison & Video
Tv loses it channel settings on daily basis
The tv has been wired incorrectly during install - it should have been attached to the permanent power line, just like the lighter, but it was attached to a key one: when you turn off the key the tv loses all power and all the settings get lost.
You'll have to have the wiring redone , correctly this time. This is a job for a specialist so go looking for a radio/alarm shop near you.
Oct 03, 2013 | Dainese Man textile Contact Goretex...
Once set the aqualink works however if a storm or lightning is in the vicinity its loses it's memory and has to be reprogrammed. this is problem since we intend leave house for a period of 3 months; We had...
First try a 9v battery at the box by the equipment. If it programs it's probably just a matter of keeping power to the board when it goes down. You need a new battery at least once a year.
If this dosn't help you may need a new board, but I would spend the two bucks on a battery first.
Sep 13, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
My Magnavox tb110mw9a converter loses programming randomly.
Badge #7067 is giving you a load of bunk. I have had one for 8 months and the only time I have reprogrammed it was when all TV was to go digital. Even when our power goes out the converter remains programmed.
I would keep calling back. Chances of getting the same guy is slim. Insist on a replacement.
You can also go online at http://www.funai-corp.com
Wayne
Sep 04, 2009 | RCA Analog (RCA) to Digital (VGA)...
Coil light and loss of power
The battery grounding ******** vw's periodically go bad and need replacement, I would suspect this to be the case.
It will corrode
in its casing, resulting in faulty electrical systems.
Jan 28, 2009 | 2000 Volkswagen Golf
Car cuts out and loss of power
Change the fuel filter a gain you may just got dirty or bad fuel. Also check and replace the air filter TDI need a lot of air.
Re: Reprogramming tv set
Wish I had a sister like you -
No, is the answer I would venture. The settings in most modern electronics items is stored in 'flash' memory that requires no power to retain stored information.
The only possible exception is if you are going to depend on an indoor antenna in place of cable or dish input. If that is the case, you may have to tell the set via the setup menu to look for input signal from an antenna instead of whatever source you normally use. Obviously, you would have to change it back after their team loses - Jeez, didn't mean to say that . . .
Sep 23, 2008 | Olevia LT32HVE 32 in. LCD Television
SCREEN PROBLEMS
Try unplugging unit for 24 hours then, retry. Unit may also have problem in standby circuit, have serviced
May 06, 2008 | Kenwood HM-331 Shelf System
Sanyo TV
it is not a problem you must have replaced system control ic or remote ic which might be having this program you remove it by reprogramming thanks
Sep 09, 2007 | Televison & Video
Yamaha RX-V800 Receiver Logo
215 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
