Question about Kodak EasyShare C613 Digital Camera
Camera Kodak C713 won't hook up to Computer
Does this mean that this certain camers will only hook up to WindowsXP? Or can I use my exsisting computer?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
It doesn't matter to the camera what operating system you have on your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Oct 11, 2012
  • 62 Answers
SOURCE: Win 98 USB driver
This is the driver
Posted on Jun 25, 2008
jyackle5
  • 8197 Answers
SOURCE: looking for a Windows 2000 driver for Kodak
try here.
http://www.kodak.com/global/en/service/downloads/dln_ekn034494.jhtml?operatingSystem=windows_2000&downloadLanguage=en
good luck and please rate FixYa! fro free answer
Posted on Apr 08, 2009
BillB-SA
  • 2761 Answers
SOURCE: Kodak C713 dose not turn on back.
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 03, 2009
praky16
  • 744 Answers
SOURCE: Kodak V610 Camera error #45
hi...
The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Posted on Aug 18, 2009
leepania
  • 1099 Answers
SOURCE: camera Kodak C713 does not turn on..
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Dec 03, 2009
Fuzzy lines like interference on screen and then pictures once the camer is on for about 5 seconds or so.
you\'ll need a donor camera, and to replace the lens mechanism is easiest..... the ccd is screwed on the back as part of the mech but worse case cenario is that you would have to swap the ccd\'s if the swapped lens mech was broke.
the ccd is basically an elecronic retina (as in "eye", not display)
Oct 12, 2013 | Kodak EasyShare C713 Digital Camera
I can't find my disk to download my camara on my new computer. Where do I go to download it from your site? Kodak easyshare C713 C813
http://support.en.kodak.com/app/home/selected/true
You'll find links for "Downloads and Drivers" and "Installation and Setup" along the right side.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com )..
Aug 05, 2011 | Kodak EasyShare C713 Digital Camera
I can't extract pictures from my C713 Zoom Digital Camera.My pc says, "The computer cannot detect the scanner or camera.Please make sure the device is turned on and is properly connected to the...
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Feb 11, 2011 | Kodak EasyShare C713 Digital Camera
Kodak easyshare c713 showing lens error 221,0,0,0. what does this mean.
KODAK C713 LENS ERROE 20E 1,0,0?
IT DID NOT RESOLVE AFTER PUTTING NEW FULL CHARGE (AA) SIZE BATTERY EVEN , WHEN I TURN ON CAM IT SHOWS ERROR 20E 1,0,0 AND SHUT DWON.
Dec 31, 2009 | Kodak EasyShare C713 Digital Camera
Why does the camera trun off when i hook it up to
the thing that you experienced on your camera Is normal. It will turn off because when you connect the camera on your computer it will be ready for transffering your picture. Most of the kodak digital camera will shuts off when connecting to computer its either to charged the battery or transffer picture.
By the way your camera will not be charged using the USB cable it will just transffer the picture., Gudluck!
Nov 08, 2009 | Kodak EasyShare C713 Digital Camera
Jul 25, 2009 | Kodak EasyShare C713 Digital Camera
Cannot turn on my Kodak easyshare c713
Hi I had the same problem with my daughters c713. Tried several bateries found out that the camera is specific with its bateries brand. When i put in new ones from kodak itself from my sons camera a c913 the c713 turn on again. Tried a new pack local brand checked them first and voltage was ok but didn´t work again. Back in those from kodak and ok again. Tried philips also ok.
So try different brand and find out. Good luck.
Jaap Davids The Netherlands
Jun 17, 2009 | Kodak EasyShare C713 Digital Camera
My kodak c713, turns off when I plug my USB in, While transfering
Mine does the same thing. I let it shut off like it wants (while 1st plugging it into the computer), then I hit the On button while it's still plugged in. Now the computer will pick up on a new device. It's stays on when I unplug it from the computer.
Jun 04, 2009 | Kodak EasyShare C713 Digital Camera
Cant transfer pictures to computer
try loading GOOGLE PICASA 3 for storing your photos and see if it recognises your camera
Jan 02, 2009 | Kodak EasyShare C713 Digital Camera
Kodak EasyShare C613 Digital Camera Logo
32 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
