Question about Sony PFM-42X1 Plasma TV
TV flickering when I turn a light bulb on in the same room
Hey,
I have a PANASONIC 46inc VIERA plasme. It works fine but as soon as a light switch is switched on in the same or nearby room the tv flickers for a couple of seconds. Horizontal lines appear on the tv when it flickers. Could a surge protector solve this problem? otherwise, can you think of another solution. Thanks.
    New Friend:
    Problem Solver:
  • 8 Answers
Go to settings, back light and turn down.
Posted on Dec 10, 2013
    Problem Solver:
  • 11 Answers
This is a sony feature, they have a sensor on the front of the tv to measure ambient and adjust the tv brightness to the ambient light.
if you want to turn this off?
call sony or put some black tape over the sensor.
R
Posted on Nov 30, 2008
Light switch affects picture source
hi your tv may be set up on eco mode, there is a light sensor built into
your tv this detects the room light and adjust the picture to suit the light hope it helps
regards
shaun
Jan 16, 2014 | Panasonic Viera TH-50PZ85U Plasma TV
On panasonic viera tx 32 Lx where can I turn off TV speakers sotahat I can play sound through denon sound system
When you plug in to the aux audio jack, that cuts out the speakers automatically. There is no switch.
Jan 11, 2014 | Panasonic Viera TX-32LX70 32 in. LCD TV
Panasonic viera will not turn on
Try the following troubleshooting steps.Check power cord and power outlet, possible light switch problem.
Check if you TV savy check the P board if the P board is not good check the fuses on the P board.
If the P board is OK check the A board.
To check these Unplug the TV , Disconect A5 A6 and A7 on the A board and plug the TV in and see if you get a white screen if this is the case your P board should be OK.
Nov 20, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic viera TH50PZ700B 4yrs old. will turn on and begin auto search however does not find channels, sky aerial cables connected. the screen goes to customer id but as soon as a button on the remote...
Tries tv unplug,replug it back like about an hour later for the tv to do a resetting itself back to the factory setting.Go into the tv menu go to PICTURE to go down to do a resetting to the tv Tuner signal board.Tries scanning for channels again.The tv should be work again,if it still have the same result.The tv main board,the tv Tuner signal board is bad.Can u do some mechanicals work like take things aparts and putting it back together again?Yes?Try website like Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Apr 15, 2011 | Panasonic VIERA TH-65PZ700A 65 in. Plasma...
TV won't turn on with remote (new batteries)
Sounds like a power supply problem. The blinking light is never a good sign. Is it still under warranty?
Jan 06, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
Panasonic Viera TH-46PZ85BA Will not switch on
Yes, the unit has a problem. I work for Panasonic in New Zealand and the unit needs to go in for servicing. 10 flashing lights means a fault has occurred (if I was at work I could tell you what 10 flashing lights means).it should be repairable.
Sep 26, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Flickering - Toshiba 62HMX84
it could be as simple as the tv feeding back on itself in a dark room.
it is adjusting the light level because of what it sees ambient in the room.
turn on a light near the tv and see if it stays constant now.
Mar 07, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Sony PFM-42X1 Plasma TV Logo
479 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
