Question about Sony STR-DE595 5-Channel Amplifier
Amp not responding to remote
My amp is not responding to my remote. The batteries are fine, and the other things that the remote is programmed to function (DVD, TV, VHS etc) all respond to the remote - it's literally just the amp that won't. My amp is about 5/6 years old - I'm not sure if it is exactly the same model as the one shown here - it is Dolby Digital 5.1 and DTS, but not dolby digital EX. I think the problem started when i took the remote to my mate's house to try to get rid of the permanent "AV2" that was displayed on his Ferguson TV. The idea was to programme the remote to his TV, and then amend the display for him as he has lost his own remote, so constantly has "AV2" in the corner of the screen. All i did was programme his TV into my remote, but can't understand why this would affect my amp responding. Please help.
Make sure that your remote is on the same av channel as the amp
Posted on Jan 30, 2007
How do I re-program my Remote Control with automatic starter on my 2009 Town and Country Van
My experience with frequently-used vehicle remotes (any make) is this:
1. When relatively new or in good condition, if remote stops working, the button battery inside is dead or too low.
2. If battery is new, & remote still doesn't work, a solder joint on the circuit board inside may have come loose or broken.(You can try re-soldering using a low-heat pencil iron & thin RESIN-core solder -- even if you're not great at it, what do you have to lose?)
3. It's rather unusual for even an older, well-used remote to simply lose its programming.If this is the problem, it may be cheaper to buy a new after-market remote (or pair of remotes) that you can program yourself (only works with some brands & years of vehicles, so READ THE INSTRUCTIONS ON THEIR WEBSITE BEFORE BUYING AN AFTER-MARKET REMOTE), instead of going to the dealer for a normally HIGH-priced programming job.
4. Used OEM remotes that match yours exactly (check the part # of your remote & the used one you're considering) can often be purchased from a local auto wrecker (now called "auto recycler") for cheap ($5 to $10 is common), but will need programming.I always go thru the many they have, looking for one that appears new or like-new.
5. IF YOU MUST GET PROGRAMMING FROM A DEALER, usually it's the SAME PRICE whether you have 1 remote or several remotes/keys programmed at the same time.Since dealer programming is pricey, I always have 3-4 remotes and/or chip-keys programmed at the same time.(My dear wife loses chip-keys & remotes from time-to-time, so I keep a few spares on-hand.I've found inexpensive after-market chip-key blanks at some key cutters and/or auto parts stores, altho they still require programming after the copy is cut from yours.)
CAUTION
:Some OEM anti-theft systems require that ALL remotes & chip-keys be programmed/re-programmed at the same time, whether they're original, used or new.Determine this IN ADVANCE, so you know what you're faced with.The good news is that for those vehicle manufacturers, dealers normally don't charge more to program/re-program multiple remotes and/or chip-keys, if all are being done AT THE SAME TIME.
6. If all else fails & you MUST buy a new OEM remote (which will require programming), try 2 things -- First, see if the dealer will make you a package deal on buying the remote (or 2 remotes, or a remote & a chip-key) AND doing the programming for a lower combined price.Second, it may be cheaper to buy a new OEM remote from a dealer who's had one in stock for a long time & wants to blow it out (or buy from online OEM seller) & then pay the normal programming price.See the CAUTION above.
There are lots of options here, so hopefully something is useful to you.
Feb 23, 2015 | 2009 Chrysler Town and Country
Can't program remote to tv
hello.....:(,,,,,,try unplugging tv & just take the batteries out of the remote & check conectors ...may litle alcohol 7q-tip.........i sell & repair bose remotes on amazon....listing bose remote rc5
Feb 12, 2014 | GE Televison & Video
I was watching T.V. and when I went to change the channel, the remote control wouldn't respond. I changed the batteries (generic) & the new ones didn't make the remote work either. I hit the power...
You won't be able to see the light from remote's LED (Light Emitting Diode) because it is IR (Infra Red) which is invisible to the human eye.
Try re-entering the code for your tv to see if it works.
If that doesn't work, the remote might have just died. It happens.
Get yourself a new UNIVERSAL REMOTE for less than $20 and just program it for your tv.
Good luck and post back to let us know how it works out.
Jan 24, 2011 | Televison & Video
2003 Escalade Keyless Remote not responding
You need to take it an have scan tool method done .
Mar 29, 2017 | 2003 Cadillac Escalade
I need the code to program the tv to a remote controler
Hi my name is Eric,
I hope I can help you with your issue ,
 The TV remote that came with the TV will work it without being programmed, so if you are using a unversal remote and trutech is not listed in the code list the only thing you can try is the search method, if that doesn't
 work you can buy a working remote here
Trutech is a daewoo product. some codes are 10451 also try 11661, 10092, 10672, 10019, or 10623. taken from remotecentral
 these two websites have the best remote info, search around there, try using the daewoo codes
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Sep 08, 2009 | TruTech KLV3112 10 in. LCD TV/DVD Combo
I need instructions and codes to program jumbo remote control
Try this, just be patient when programing it might take a couple of minutes to program.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Aug 11, 2009 | Brookstone 538744 Remote Control
Universal remote can use on tv.
You need to program it. Search Google searching for your model number proper information for programming your remote. I am sure you can find something if you just think about your question carefully and go from there. Good luck
Jan 05, 2009 | RCA DIRECTV Satellite Remote Control
Sony STR-DE595 5-Channel Amplifier Logo
158 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
