My dryer has had a problem of periodically humming when the start button is pressed. Yesterday, the dryer quit working all together. The only thing it will do is "hum" when the start button is pressed. The drum will not turn and it seems nothing else is moving. I'm thinking it has something to do with the motor but I don't know. Please help...
There
can be many reasons why your dryer will not start or turn...
The
most common causes are the belt breaking or jumping off, or the motor
going bad...
Here are a couple of tips that I wrote will help
you to figure out why your dryer will not run...
Dryer Repair
- The Dryer
is not Turning
Dryer
Repair - The dryer
will not start
heatman101
I took off the front panel and eventually the rear "window" panel. The belt isn't broken. I replaced the front panel and door, then I plugged it up and pushed the start button. The motor doesn't turn, just a humming noise. I also felt of the side of the motor (after I unplugged it) and it was very hot.
The repairman came by yesterday and said it was the motor. He is coming back next Wednesday to replace the motor.
Our Maytag Neptune has given us a lot of problems such as, sensor not working efficiently, clothes smell burnt and hums without running. We're buying another brand. Maytags are not built the way they used to.
