Question about Tally T6218 Matrix Printer
My Tally T6218 gives the following error message shuttle fault
    New Friend:
  • 114 Answers
May shuttle belt is lose or it is not in proper place. check the shuttle belt and clean the shuttel sensor , your problem will be solve.
Posted on Jan 30, 2009
Error message PAPER OUT and PLATEN CAL required Tally 6218. Please help me. Esli mojno po ****** otvet daite. subat@mail.ru
You will need to calibrate the paper and platen.To do that,you will need to enter technical access and disable disable four fault error by pressing LF and enter button simultaneously until tech access appear on control panel display,then press tof + enter to override four fault.Now you can clear the fault message.,then go to calibration procedures.
Oct 11, 2011 | Tally T6218 Matrix Printer
I have a tally genicom 6312 printer which gives me hammer voltage 2 error what do i do
A high resistance coil fault has likely occurred in one or more of the hammer coils.
Note: this fault message will have been preceded by printing slow-down attempts associated with On-
The-Fly thermal monitoring of hammer bank temperature.
Check the hammer bank for defective coils.
If no defective coils are found replace the Controller Board.
Dec 31, 2010 | Tally T6218 Matrix Printer
TAlly printer T6218 is showing shuttle fault error
may shuttle belt is lose or it is not in proper place. check the shuttle belt and clean the shuttel sensor , your problem will be solve.
good luck and do rate if helped
Nov 30, 2010 | Office Equipment & Supplies
Lipi Line Matrix 6312 shows error "shuttle fault"
  1. what is the main reason for hammer voltage
Jun 10, 2010 | Tally T6218 Matrix Printer
Tally 6218 give skip ribbon weld error
Skip Ribbon Weld
Explanation: This is an advisory message. The message appears when
the welded part of the ribbon is moving across the Hammer Bank.
Corrective Action: None. Wait for the ribbon to finish moving, and the message will disappear.
Apr 21, 2010 | Tally T6218 Matrix Printer
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Apr 20, 2010 | Tally T6218 Matrix Printer
Tally Printer the error is some times Hammer
In the T6215 Maintenance Manual the fault message: Hammer Voltage has been replaced, in the T6218, with:
Hammer Voltage 1
There is a new fault message for the T6218. It is:
Hammer Voltage 2
Explanation: A high resistance coil fault has likely occurred in one or more of the hammer coils
Note: This fault message will have been preceded by printing slow-down attempts associated with On-The-Fly thermal monitoring of hammer bank temperature.
Corrective Action:
Check the hammer bank for defective hammer coils.
Confirm that hammer drive board is functioning properly.
Apr 05, 2010 | Tally T6218 Matrix Printer
How do I clear a "config 1" error on my tally t6218 printer
Click start>run>type services.msc. The services window will come up and you can right-click on the Print Spooler and then click Restart. This will clear the print queue and hopefully allow you to print. Good Luck. Let me know if you have any questions.
Feb 28, 2009 | Tally T6218 Matrix Printer
Sotutions
there is no shuttle in 6306 printer . so the problem will never come.
Jul 25, 2008 | Tally T6218 Matrix Printer
Print stops after 2 pages !
Hi my tally printer 6218 giving Ribbon motion fault, what could be done to remedy this error message ?
Jan 19, 2008 | Tally T6218 Matrix Printer
Tally T6218 Matrix Printer Logo
499 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
