Question about Microsoft Windows XP Professional for PC
I have alwaise a problem with my computer when ever i used 2 any game it stops in the middle and show a messege 'that the programe have encountered a peoblem would u like 2 sand 2 microsoft'
    Guru:
  • 859 Answers
You will want to disable error reporting for Windows. This nusance of a subProgram causes a lot of grief like this.
Right Click My Computer and select Properties. On the subsequent popup you will see a series of property sheets identified by tabs with labels. Select the Tab that is labeled 'Advanced', when this sheet is on display you will see a button at the bottom right labeled Error Reporting. Click on tihs button.
The subsequent pop out page has several lines of text with selectable holes on it. Click on the Disable Error Reporting and the one just underneath it 'But, etc.'
Click OK on every page to back out of these pages and reboot your machine and recheck the settings.
If the settings do not persist respond back to me and I'll help you make these persistent but this is rare.
Now, you want to discover what errors are generating these error responses. Often this can be accomplished by updating your display drivers and seing if there are any patches to your game.
You've probably done this already. So, go back into the property sheets for my computer by right clicking it. Now select the advanced tab again and then the 'Settings' button. Now click on the 'Advanced' tab of Performance Options. At the bottom, now, is the Virtual Memory section. Click on Change. You want to have a permanent swap file by manually setting the min and max size of your virtual memory swap file to a figure equal to your RAM onboard. If you only have 1GB of RAM you already have a problem as you want 2GB with Windows XP and 4GB with Vista. The point is to make the swap file a Custom Size. Use the number 1024 for each Gigabyte of RAM. 2048 for 2GB and so on.
Lastly, just make sure you have enough free space for all the files that run when the games in open. Right click your C: drive and select properties and you will see a pie chart.
If you have more than one drive partition and your game runs on that partition, use that drive letter for an extra swap file, you will have seen the ability a bit earlier to set. Use the same logic so your game running on this other drive also has a swap file with the same value as I just outlined above.
And, now, make sure you don't have a whole lot of extra stuff running in the background at startup that could be interferring.
Click on the Start menu and select Run, in the run text box type MSCONFIG and hit enter. In this pop out go to the startup tab and you will see a whole lot of programs that run at start up from your antivirus program to Messenger. Turn of by deselecting any that aren't really needed. If you have a question about any just comment back to me and I'll tell you about the program.
Regards,
Worldvet
Posted on Nov 30, 2008
While playing 3-D HUNTING 2010 Hunt Rare and Wild Animals I encounter a " Game launcher has stopped working" in some cases (usually when using marking gun) My laptop specifications: Asus A42Jr...
This can be caused by 2 programmes having similar or same names, check your computer for other programmes/files sharing the same name. or i found a fix on another site which you could try!
If you are receiving the DRM activator error message do the following to
correct the issue.
1 - Left click on Start
2.- Right click on Computer
3 - Left click on Properties 4 - Left click on Advanced System Settings
5 - Under Performance click on Settings
6 - Left click on Data Performance Settings (on my computer the tab said
Data Execution Prevention)
7 - Click on TURN ON DEP FOR ESSENTIAL WINDOWS PROGRAMS AND SETTINGS ONLY.
8 - Click on Apply and then OK.
This may not work in your case! But worth a try.
Sep 17, 2011 | Video Game Consoles & Games
Dear Sir/Madam, This is to state that I recently bought Commandos 2 Men Of Courage PC DVD pack. I installed it and played. Upon playing, I encountered a unique problem in the...
Try to make this .BAT file and use it for making backup of your savegame during game by ALT+TABbing.
md "c:\COMMANDOS 2 SAVEGAME BACKUP" xcopy "c:\Program Files\Commandos 2\OUTPUT" to ""C:\COMMANDOS 2 SAVEGAME BACKUP" /E /F /H /R /K /X /Y
Jan 04, 2011 | Eidos Interactive Commandos 2: Men of...
When i send a message from my nokia 1110 it shows messege sending failed.when i put my sim to another mobile the message is going
just reset your phone,i encountered that troubled many times in my customers phone and no need to reprogram your phone..
do this..
1.MENU
2.SETTING
3.RESTORE FACTORY SETTING
4.ENTER LOCKED CODE
5.WAIT UNTIL YOUR PHONE RESTART
i hope it will help you ,thanks
Jun 14, 2010 | Nokia 1110i Cellular Phone
Zoo Tycoon has encountered a problem and needs to close?
stop playing it because it might mess your computer up alot by playing it.
May 14, 2010 | Microsoft Zoo Tycoon: Complete Collection...
Windows says the game has stopped working - cannot launch. System requirements are OK - install was successful.
Note the system requirements are Windows XP or Vista. If you're using Windows Vista, and it's 64 bit, you'll encounter more problems running some programs that can only run on the 32 bit version.
Also note that if you got this as a pirated copy, Ubisoft implemented an anti-piracy measure that forces the game to error and close out, or otherwise cause unpredictable crashes.
Nov 08, 2009 | Ubi Soft Entertainment Assassin's Creed...
Not able to login thru yahoo messenger
[Solution # 1]
(1) Check your firewall to be sure that this port is not blocked.
(2) Ensure that another program is not using the same port number.
Type netstat in command prompt to see all active ports.
[Solution # 2]
Goto Connection  Prefrences and use a http proxy. It helped!!!
[Solution # 3]
It might do this because it cant recognize the internet. Mine does this from time to time too, but I'm not sure if I get that particular error.
Try a couple things.
1. Totally close down Yahoo! and open it back up. See if that helps.
2. If you have a Wireless connection, shut your computer down and basically reboot the connection. Unplug your modem, then your router. Wait 15-30 seconds, then plug in your modem. Wait for the lights to all become solid, plug the router back in, then turn your computer on.
Sometimes a router will stop recognizing your computer. I've had it happen to me, and the odd part of it was I could still browse the net, but not use my IMs.
3. If nothing else works, uninstall and reinstall Yahoo! IM. It may just be a glitch.
[Solution # 4]
Take a look to this address : http://epayvn.info/2009/01/yahoo-messenger-error-81003004.html
Good luck
Mar 19, 2009 | Yahoo Messenger
Unable to delete a video file
Start in SAFE MODE (F8 at start up)
and delete the file
also you can try to run CMD to start command interface.
If not working you have to change file attribute let me know
Jan 04, 2009 | Computers & Internet
The Lord of the Rings The Battle for Middle Earth on PC
Have you checked on the disk if you need to access the internet for the game to load? and if so do you have the internet running?
Nov 22, 2008 | Electronic Arts The Lord of the Rings: The...
PS2 game lock up
please dont tell me you used action replay...it will destroy your systems insides your ps2 cant handel the information it sounds like it might be overloaded
May 08, 2008 | Sony PlayStation 2 (PS2) Console
My PSP turns off in middle of stuff
it may be a temporary glitch.try to do it several times and if it's really showing consistently the same glitch,then there might be either a disc game or psp hardware problem.try to play other disc games on your psp console,if you don't encounter any problems,your psp console may be out of the woods.or use your nba 08 disc on other working psp consoles and see how it goes...if you encounter the same glitch,most likely,the disc is defective.i assume you have an official firmware on your psp.hope this helps.
May 04, 2008 | Sony PlayStation Portable (PSP) Console
Microsoft Windows XP Professional for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
