Question about Sony KV-36XBR250 TV
Toshiba 36a41 television
I just moved my toshiba television model 36A41 to another room in the house. We have a dish satellite. We have the satellite cable connected to the tv and the dvd is hooked up correctly with the yellow, red & white cables to the tv. The dvd player works, but we can't reprogram the tv channels. I need the toshiba to be on channel 73 to work. Can you tell me how to reprogram the tv or ideas to get it to work? When it was in the other room, the satellite was set up for channel 3 which worked fine, but the satellite for the other room is channel 73. Thank you, bit frustrated
    Novelist:
    Champion:
  • 236 Answers
You should be able to use your remote control to do this.Your channel 73 is more than likely UHF 73 so you need to put your tv in the antenna setting rather than cable setting. Once you do this just input 73 with your remote. Hope this helps! Stargazer
Posted on Jan 28, 2007
SOURCE:
HOW a 36A41 model's External Speakers Work ?? ...
Your speakers may be plugged into outputs intended for connection to an external amplifier.
May 04, 2014 | Toshiba 36A41 36" TV
Remote control senser failure in tV
It can be replaced. Contact any service tech:.
Mar 23, 2013 | Toshiba 36A41 36" TV
Toshiba 36A41 pops when I change the channel and I can not adjust color, brightness, etc,and remote does not turn off tv.
The symptoms you describe is the main processor controller is about to fail, when that happens the tv will eventually become unuseable. if the set is more than 5 to 10 years old you will be further ahead to replace the set.
Sep 15, 2011 | Toshiba 36A41 36" TV
The volume doent work when using the remote. I have tried the cable remote and the original tv remote and the volume works at times but less and less.
Try imputing a different toshiba code into each of the remotes. 0156, 0060, 0154. If that does not help, then unfortunately it is your tv.
May 14, 2010 | Toshiba 36A41 36" TV
TOshiba 36A41 CRTTV has a color problem, i can not see the color Blue.
If it got like that gradually suspect a low emission condition on the Blue gun inside the picture tube, this condition can sometimes be fixed by running a gun cleaning procedure, this is done with a crt analyser device at a repair shop. The other cause for a no blue picture could be a Blue color output that has stopped working, the loss of blue is suddendly when the color out fails, it could also be a problem in the signalprocesing circuit. I suggest having it checked by a tech because it would be something you could not check, first because of lack of equippment and second, you would need some technical troubleshooting skills to do the job.
Jan 28, 2010 | Toshiba 36A41 36" TV
Clear but only blue/green color
Do you have a component cable hooked up to the TV? (cable with RCA connections Green/Blue/Red/White/Red)
If so you want to check that the red cable is tightly connected to both ends (TV and whatever it is connected to).
Good Luck...
Jan 23, 2010 | Toshiba 36A41 36" TV
Audio problem with Toshiba 36A41 TV
Try connecting the cable directly to the tv rather than through the VCR.
Mar 25, 2008 | Televison & Video
Remote Sensor Repair
Before condemming the infared remote receiver, make sure that you have tried and original toshiba remote control. Sometimes universals do not always work. If you do have to replace the (IRR), the main circuit board or the button assembly must be removed. The part is soldered in and has only three wires. The approximate cost of the part is around $20. You local service center would probably charge you $80 to $100 for the repair. If you have already tried a number of universals, the chances are that the(IRR is defective). Also try the code search on the universal remote sometimes this will work. Scrivitron
Jun 19, 2007 | Toshiba 36A41 36" TV
Toshiba 36A41 Bad Gun or Driver?
Sorry to say but your tube is bad. It may be able to br rejuvinated with a CRT restorer machine but its not always the case. Good Luck
Aug 29, 2006 | Toshiba 36A41 36" TV
Sony KV-36XBR250 TV Logo
215 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
