Question about Kenmore 24032\24036 Top Load Washer
Empty washer tub wobbles during spining, plus burning smell
After replacing the broken Direct Drive Coupling with a new set from Sears Parts (P/N 285753A), I smelled the rubber burning when test run my Kenmore 90 Series washer about 4-5 minutes in the wash cycle. I removed clothes and drained the water, re-opened the cabinet, switched washer to run a couple different cycles by cheating the lid switch. Everything look normal except the burning smell kept coming and the empty washer tub wobbles during spinning.
Does anyone know what could be the burning smell source? And why the empty tub wobbles at spinning? All the balance?? springs under tub seem normal to me. The instruction from jsrock516 below is what I have used for installation reference, which is very helpful.
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Thanks in advance for helps.
  • ChiaLung Chen Nov 30, 2008
    Hi, JR JR, thanks for your quick
    response and suggestions. I am going to check the three suspension pads, see if
    the pads worn out causing the wobble. However, "I believe" the tub was not
    wobbling much prior to replacing the drive coupling. Do you know whether
    suspension/skid pads likely??/unlikely?? to be the source of smell rubber
    burning?
    Another post online (2005Aug07) described a similar smell
    burning problem as my washer, but it didn't mention their final result/fix for
    some reason(s)?
    http://www.thestuccocompany.com/maintena...
  • 116 Answers
BOTTOM OF TRIANGULAR PLATE ARE 3 SKID PADS, USUALLY WHITE OR BROKEN HALF MOON SHAPE WHEN WORN OUT RESULTS IN THIS
Posted on Nov 30, 2008
Won"t spin or agitate. Makes a loud rattling noise
If this is a Whirlpool manufactured TOP LOADER (such as Roper, Estate, Kenmore, Amana, and Frigidaire), you may have a damaged or broken motor coupling. Whirlpool manufactured top loading washers use a motor coupling between the drive motor and gearcase (transmission) in place of a drive belt. This configuration is known as "direct-drive". The coupling can break through normal wear and tear. Washing frequent loads of heavy items and reduce the life span of the coupler. Common symptoms include the following:
1. No spin or agitation.
2. Washer will fill and empty.
3. Drive motor still runs.
4. Strange rattling, grinding or clicking noise during agitation or spin cycles as the drum sits still.
If your washer is exhibiting these symptoms, then its probably a safe bet that the motor coupling is bad.
The following link explains how to replace one:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
The part number for a replacement motor coupling is inlcuded in the link I provided. Replacements can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I have listed also included helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need.
If you have any questions, please post back with your complete MODEL NUMBER (located on a nameplate along the wash tub rim under the lid) and let me know. I hope this helps you.
Dec 17, 2010 | Kenmore 24032\24036 Top Load Washer
Washer wont spin makes loud noise like the motor tries to turn tub but it wont spin
repairclinic.com
Oct 13, 2010 | Washing Machines
Drum not turning and weird noise heard. any ideas? Was working great on wash cycle until it got to the rinse cycle then a sort of clicking noise and drum stopped. Can still empty and fill but nothing more.
You may have a damaged or broken motor coupling. Whirlpool manufactured top loading washers use a motor coupling between the drive motor and gearcase (transmission) in place of a drive belt. This configuration is known as "direct-drive". The coupling can break through normal wear and tear. Washing frequent loads of heavy items and reduce the life span of the coupler. Common symptoms include the following:
repairclinic.com
Oct 06, 2010 | Whirlpool 3.2 cu. ft. Plus Washer
MACHINE STOPPED - BURNING SMELL COMING FROM WASHER
The burning smell is from your coupling and when this breaks the rubber spins across the plastic face of the opposite coupling. Your washer will not wash or spin until this is replaced. fortunately these are cheap and easy to replace. Refer to my step by step instructions to replace yours.
Here is the guide:
http://www.fixya.com/support/r4355933-washing_machine_repair_direct_drive
Mar 24, 2010 | Washing Machines
Ge washer top load wlse4000goww not washing/spinning only pumps
Your type of washer usually has a belt theat runs the agitator and spins the tub. The pump is hooked by a direct coupling. If you are still pumping that tells me the motor works but the belt is probably broken or worn so badly that it no longer drives.
Have the belt replaced or do a search for "appliance parts" and then enter your model number. You will get a parts menu to order a new belt from for your unit.
Belt replacement for some of these units can be a major chore... then again some are relatively easy, but consider yourself warned if it is a real project....
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 05, 2009 | GE WDSR2080D Top Load Washer
Kenmore series 90 washing machine clunking and burning smell
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26902691
See the section on the Machine Base.
There are a number of balance springs and vibration pads that help keep the tub from vibrating and going out of balance.
It's possible that one or more of these is broken, loose or damaged.
Following is a description of how to remove the cabinet to get access to them.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
Also see the Whirlpool Service Manual for their direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
For the vibration, I'd check the springs and vibration pads.
While you have the cabinet off, I'd pull the pump and motor and check the Motor Coupler. This could be the cause of the "burning smell"
Nov 22, 2009 | Kenmore 24902 Top Load Washer
Stopped with a full tub, burn smell. Direct drive
Carefully check your symptoms. The problem you are having could be a motor coupling, or a lid switch malfunction.
If the washer will fill, will not agitate or spin, but will STILL drain, these are the symptoms of a broken motor coupling. This is a very simple and inexpensive repair. The following link explains step-by-step how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The part number is included in the link I provided. You can purchase a replacement on line at appliancepartspros.com for about $11.
If the washer fills and agitates, but stops at the rinse cycle, or, if the washer fills and then stops, this is a common symptom of a lid switch malfunction. The washer usually will NOT drain if there is a lid switch malfunction. The following link explains how to access and/or replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch can be purchased for about $20 - $30.
If you have questions please post back with your complete model number, so that I may be able to provide yo with better assistance. I hope you find this information helpful.
Nov 12, 2009 | Kenmore 24032\24036 Top Load Washer
Washer does not agitates
Sounds like you've already replaced your lid switch and now the washer stopped agitating and spinning, but WILL still drain water. If I'm understanding these symptoms correctly, these are common symptoms of a broken motor coupling. The burning rubber smell is another symptom as the coupler has a rubber bushing that can tears apart when the coupler breaks. There may also be a strange rattling noise associated with these symptoms too. The coupling is located between the drive motor and gearcase (transmission) and this is what transfers the energy from the drive motor to drive the transmission, which makes the drum spin and agitate. It is common for this coupling to wear out, strip, or break over a period of time. This is a very inexpensive replacement part (usually $15 or less) and can be replaced easily by the average do-it-yourselfer with a little guidance. The following link gives you step-by-step instructions how:
Some of the orginal motor couplings that came from the manufacturer were totally made of plastic. Over a period of time (especially with heavy loads) the center shaft on the coupling would strip out and the coupler would free spin. The manufacturer came out with a new improved, longer life coupling with a steel grommet. The link provides you with the new part number and where you can order the part if you wish go online. If you do not wish to order from the website, take the part number provided and go to your nearest appliance parts retailer. This is a common part they carry. I hope this helps you. If you require addtional assistance, please contact me and let me know.
Aug 30, 2008 | Kenmore 22422 Top Load Washer
Topload washer agitator does not move
Washing machine broken, kenmore model 110.92274100
REPLACE THE DIRECT DRIVE COUPLING IT IS BETWEEN THE TRANSMISSION AND THE MOTOR PART NUMBER IS 285753A THE TRANSMISSION IS NOT BAD
Apr 22, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
787 people viewed this question
Sal De
fordexpert
Robert Rankin
