Question about Acer LXA3706003 Notebook
Helpneed m using acer laptop 2920 model and suddently it appeared error on disk press ctrl+alt+del to restart this is keep on coming
  • 520 Answers
A few things you can do.reinstall os.repair os or checkdisk all of which require xp disk(or whatever os disk )
to check disk.boot up from os disk(xp,whatever)
screen displays install or repair
select repair which then takes you you a dos platform (black screen c:/promt
type in chkdsk (exactly as is)
system will run program and if any errors try to repair.
To repair system:-boot up with os disk
in choices install or repair select install
after diagnose system stsate os already exist install or repair ...
select repair..if you want to reinstall fresh copy choose install instead of repair.
repair does as it says and leaves previosly installed software intact..
install wipes all data and installs new copy which has to be registered again within 30 days.
Posted on Jan 05, 2009
My acer 5630 laptop does not boot up
Try reinstalling the OS with your restore disks. It might be that you have HDD failure in which case you would need to replace the HDD.
Feb 01, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
A disk read error occurred
when upower up thecomputer enter in bios setup press del or F2 or F1 to neter in bios setup when u power up.
thenr eset bios defaults settings.
then check your hardiskk is deteted or not.
if sata is enabled then disable then press F10 to save settings.
Jan 07, 2009 | Sony VAIO VGN-FS640W Notebook
I m using acer laptop 2920 model and suddently it appeared error on disk press ctrl+alt+del to restart this is keep on appearing everytime i restart what should i do
The might be a problem with MBR. What brand of HDD you have there might be bootable image of software on the manufacturers website that can fix the problem. If you are using windows, then boot from the Installation CD and type fixmbr in the recovery console, this might work, but be careful with MBR.
Nov 30, 2008 | Acer LXA3706003 Notebook
Computer won't start
My Acer Aspire LapTop will not even power up.
What should we do as this machine has also been charging battery for two days
It has worked before but all of sudden it simply failed to power up.
What's up with this !
Aug 10, 2008 | Acer Aspire 3000 Notebook
BOOTMGR is missing Press Ctrl+Alt+Del to restart
first u go to bios settings and change first bootdevice cdrom and reboot system u put winxp cd in cd drive
u will see this message
press any key to boot from cd
u press any key
winxp setup start automatically
and repair winxp
som case hardisk partition probelm , that case u will format drive and re install winxp
Jul 12, 2008 | Computers & Internet
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
Problem with a disk read error
There are a couple of possibilities.
1. The hard drive is defective.
2. The operating system is corrupt.
The easiest way to test this is to run the restore cd that came with the computer to reload Windows.
If you get this error while running the restore cd then you will need to get a new hard drive.
Jan 03, 2008 | Computers & Internet
Acer LXA3706003 Notebook Logo
148 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
