Network port problem
HI Dear Bro / Sis,
i alrady format the Hyundai Laptop and install the drivers but i find out that the Local Area Network unable to connect. The light did not blink in the ADSL Modem, I am not sure whether the network port problem or the driver. If want to connect to internet i am using normal internet connection that is dial up but for broadband cannot because of LAN not connect. Please help on this.
Regards,
K.Loges
  • 41 Answers
Hi
go to run and in run type in devmgmt.msc
and under network adapter click on to the plus sign and then in the drop down menu look for local area network if it has a red mark then right click on to it and enable it and u would be able to connect ,if not then u can contact me on fixya
Posted on Jul 22, 2009
Nvidia nforce network controller
google translated
engo deshabilitadad wireless network and can not find the drivers windows7 teengo is a acer aspire 4520
Your Acer computer has a networking card installed so that it can connect to a wireless local area network (LAN) to share files or surf the Web.
By using a wireless network, you can bypass the need to run cables between different rooms in your office or home.
To set up a wireless LAN, you will need to change settings in the computer's operating system and use the eNet Management software that Acer provided.
Connect an Ethernet cable to the "Wide Area Network" port on the back end of your wireless router.
Attach the other end of the cable to the Ethernet port on the back end of your high-speed modem.
nsert the installation disc that came with the wireless router into your Acer computer's disc drive.
Follow the on-screen installation instructions.
Access the Acer's Start menu and open the Control Panel.
Click "Network and Sharing Center," and then choose the "Set up a new connection or network" link.
Choose "Set up a new network" and then "Next."
Enter a name for your local area network, such as "Home" or "My Network," into the "Network Name" text field.
Type a password for your network in the "Security Key" text box and click "Next."
Click "Finish." Right-click the "Acer eNet Management" icon in the Windows task bar.
Scroll to "Available WLANs" and then click the name of the network that you chose earlier.
Type in the password you chose earlier and click "OK" to connect your Acer to the Wireless LAN.
You only need to check the BIOS if you cant install the driver
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
"Enabled"ima
Jul 19, 2013 | Acer Aspire Computers & Internet
TP-LINK TL-WN321G - Hi-Speed USB - 802.11g driver not install in window xp
You will have to open up your network connections
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled.
Make sure your antivirus program is not blocking the internet connection.
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers.
The driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
"Enabled"
Apr 03, 2013 | TP-LINK TL-WN321G - Network adapter -...
I have acer aspire 5740g windows 7 64 bit. i used wireless wifi till now. but now switched to ethernet or wired network. but i cant connect. local area connection does not show up in my network connec
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc You only need to check the BIOS if you cant install the driver Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"ima Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
Mar 14, 2013 | Acer Aspire 5740-6025 Notebook
I formatted my dell laptop but there's no internet connection even after i plug in my internet cable?
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"imake sure its enabledPci device arrows key scroll to nstalled. Hope this helps.
Jan 16, 2013 | Computers & Internet
I have a smart bro modem and i connect to my PC windows 7 starter the problem is i cannot connect to the network?
HI there !
Have you install the smart modem driver to your laptop? If not, install it for your modem to work.
After installing, there would be a destop icon in your computer that will appears. Just plug the USB smart bro and then click the smart bro icon to connect to internet.
Jan 27, 2011 | Acer Aspire One Netbook 8.9" Notebook
Trying to install magic jack. Inserting the usb into the port should download the software automatically but not doing it why?
hi bro or sis i have magicjack so i made a mistake
i was made a format my computer so at that time i forget to unplug my nagicjack so can i get download in progres
Aug 22, 2010 | Computers & Internet
Problem with network drivers
Click Here which will take you to the dell support and drivers page. Select the drivers you want and download them to a pen drive, and then install them to the D600. :)
Mar 14, 2009 | Dell Latitude D600 Notebook
Sis intallation problem in N73
hi,
dear there is way to install a sis file in NOKIA N73
coz its N-series mobile higher.
you have only install sisx,jad,and jar files
if you want to get some files tel me i will tel you links were you can ezzzely
Dec 15, 2008 | Nokia N73 Cellular Phone
on desktop
right click My Computer
Manage > Device Management >
expand
Network adaptors > If it is correct and enabled no mark will be there
for driver It would have Yellow Explanation on its icon
Choose it properties to view problem and possible cause
if its shown in
My network Places >properties
Driver is generally ok
choose lan >properties >on general tab > tcp/ip > properties >
obtain ip automatically
or as provided by your ISP(internet service provider)
also check the utp/STP cable you are using
if its loose it won't work
also
check with your ISP
if your account is active
and that you filled the correct username and password
in configuration of your adsl
regards
-Mayank
Nov 29, 2008 | Computers & Internet
Computers & Internet Logo
53 people viewed this question
Alun Cox
David Payne
David Payne
