Question about Kyocera Mita FS-3830N Laser Printer
Kyocera FS-3830 with error F030
I know this machine will need to have the firmware upgraded via a flash card that is inserted into the printer. My question is, fromwhere do I get download/upload the firmware? Do you have a link?
  • whindy Dec 02, 2008
    I already tried that option. Nothing doing! The kyocera website is not info friendly, like the HP site. Any other sites to visit? Have you actually found the f/ware options on the KM site in the past?
  • 628 Answers
Try www.kyocera.com and look around for links to software upgrades.
Posted on Dec 01, 2008
  • Joe Fine Dec 02, 2008
    You might try www.driverguide.com They have all kinds of drivers. Generally, though, for firmware upgrades, you have to go to the manufacturer. Have you tried a local dealer and inquired about it?
I have a kyocera fs-3830 F040 Failed what is the problem?
This error means - Communication error - Communication between the engine board and the main board is failed. IF there are no loose connections then yo most likely have a bad main board which will need to be replaced.
Dec 21, 2010 | Kyocera Mita FS 9500DN Laser Printer
Kyocera FS-1920, error F030:0077538
i've been working on kyocera's for about 4 years. now..this error is not good..it's a general system failure..only solution is replacing main board.
contact me if you need a part #.. I can look it up for you
Feb 01, 2010 | Kyocera Mita FS-1920 Laser Printer
Call service engineer Kyocera
power down unit and power on... if same error get a surge protector or power conditioner... plug unit into it and then power down and power up... if same error replace the memory card in the unit... if same error replace memory board...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Apr 10, 2009 | Kyocera Mita FS-C5016N Printer
My Kyocera fs-3900dn has the message: call service 0150:0040557. What does it mean?
0150 - Engine PWB EEPROM error. Detecting engine PWB EEPROM communication error.
Solutions:
1. Switch the printer OFF; unplug the power cable; wait 20 seconds; plug in the power cable; switch the power ON, If the error comes back follow the next solutions:
2. Update / Burn the latest firmware version. You may need to call a Kyocera Service Provider because you need a CF card (compact flash memory card) and the FIRMWARE.
3. Replace the Engine PWB (a board) - again you have to call a Kyocera Service Provider.
Dec 30, 2008 | Kyocera FS-3900DN Laser Printer
I got Call Service 0150:3900991 any ideas what it is and how to fix it? TIA
This is a firmware problem. You will have to try and do a firmware upgrade first, if this do not work your mainboard is damaged. The firmware can be downloaded from kyocera's website where you will have to unzip and copy it to a flash drive/memory card. Switch machine off and insert card. Switch machine back on and wait for firmware to be downloaded. Switch machine off and remove card, switch back on.
Nov 10, 2008 | Kyocera FS-2000D Laser Printer
Kyocera fs1920 problem
F030 = main controller PCB System Error (frimware upgrade required)
do you have access to a Compact Flash Card & a Card Reader / Writer?
or is the printer connected via Parallel?
Nov 08, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera 3900DN Error Code
F030 General failure
Miscellaneous failure with the main
PWB, other than F000, F010, F020,
F040 and F226, above.
Defective main-PWB
Turn the power switch off/on to restart the
printer.If the error is not resolved, replace
main PWB
Sep 04, 2008 | Kyocera FS-3900DN Laser Printer
Call service
This is a mainboard problem. You will have to try and do a firmware upgrade first, if this do not work your mainboard is damaged. The firmware can be downloaded from kyocera's website where you will have to unzip and copy it to a flash drive/memory card. Switch machine off and insert card. Switch machine back on and wait for firmware to be downloaded. Switch machine off and remove card, switch back on.
Mar 12, 2008 | Kyocera FS-2000D Laser Printer
Kyocera Error
Signifies comunication error between mainboard and engine.
Only hope would be check and reinstall printers firmware via flash card in side socket.
Check connections on the boards.
Replace main board.
Error is stated as for F040: the .0183044 is just page count.. no match for just 040 in service manual.
Cheers
Jan 03, 2008 | Kyocera Mita FS-3830N Laser Printer
Error code 0159:0061914
I couldn't see a 159 error in the 2000d service manual, but I know 150 errors . They need to have their firmware updated, should be under warranty, their is a kyocera service bulliton on this issue so all agents can do your repair. It is just a matter of downloading firmware from kyocera. unzipping it to a mem stick or CF card and powering on your printer with it inserted, firmware then self installs.
The bits after the 159:is just page counter. Post Email if you want me to send you zippped firmware to suit.
Dec 21, 2007 | Kyocera FS-2000D Laser Printer
Kyocera Mita FS-3830N Laser Printer Logo
2,144 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
