Need unlock code
You can get the unlock code for Samsung I907 from your service provider or from reliable online sites like prounlocking.com .At prounlocking, the unlocking steps are simple and the codes are reasonably priced!!!!
SOURCE: NEED UNLOCK CODE SAMSUNG
switch off ur mobile phone remove the sim card and battery for some time and replace the sim and battery again and switch on the mobile
and if it is asking for the unlock code type 0000
SOURCE: i need the network unlock code for samsung SGH -E390
To unlock your samsung mobile,follows these steps
Do a custom reset:
*2767*2878# once this has finished rebooting turn the phone off.
Next
a SIM card from a different service provider needs to be pushed half in
- (Push it fully in then slide it back out by about 1/2 a centimeter),
Turn on the phone - you will now see an "Insert SIM" message,
Now perform a full reset:
*2767*3855#
When the phone powers off, quickly push the SIM card fully in, and let
the phone power back up.
After you do the reset, check and make sure that your Network lock is active by pressing *#7465625#
If it isn't active you must use this code to reactivate it:
*7465625*638*00000000*00000000#
Then you have to deactivate the SP lock first. To do that you need to input:
*7465625*77*00000000*00000000# (this will reset the lock)
Then you enter:
#7465625*77*00000000# (to disable the SP lock).
Then you disable the Network lock:
#7465625*638*00000000#
The phone is finally unlocked.
SOURCE: need codes to unlock my samsung s5320 for free
To get the security code to unlock the cell phone from the current cell phone provider so you can use it with a different phone provider, Please click on this link and follow my instructions :-
http://www.fixya.com/support/r4049238-unlock_cell_phone
If your phone provider does not help you then this WEB site it provides security codes for a small price.
http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw
Try this WEB site also - Unlock Free
http://www.unlock-free.com
Because the phone is fairly old, the unlock dofe should be free
The suggestions did not work
