Question about Toshiba Satellite 4090XDVD Notebook
Know what kind of hard drive to put in a toshiba satillite 4090
I have just bought a toshiba satillite 4090 and it needs a hard drive iv looked on ebay but they tell me if they will fit i have a 20 gig hard drive froma dell inspiron 3500 i would like to know would that fit or what em i looking for thanks
  • coatofarms6 Nov 30, 2008
    thanks mate u helped me out heaps good job iv got another prob iv downloaded windows 95 floppy disk set and if i just bort a box of floppys would there go on it i mean are there the right size or is the windows 95 disk bigger then the ones u buy thanks
    Sergeant:
  • 400 Answers
It will If its a laptop sized hard drive , A desktop sized Hard drive will not fit.
Posted on Jul 22, 2009
How do I hook up my toshiba satillite 4100xdvd to
If you want a wired connection to the internet via high-speed broadband (DSLor cable), you will need an Ethernet PC Card (also called PCMCIA or CardBus).
If you want a wireless connection, look for a compatible 802.11b or 802.11g PC Card. (This assumes you already have a wireless access point.)
Make sure the driver for the card is available for your operating system. Since this computer can only have up to 192MB of RAM, you might want to look into using a Linux OS.
The unit appears to have a built-in modem, but I am guessing you are not asking about a dial-up connection.)
Aug 14, 2009 | Computers & Internet
What harddrives can replace a toshiba satillite p25-s2563
Any 2.5 inch notebook hdd of the same connection type can replace the original hdd. You can check some out for specs & research at tigerdirect.com; zipzoomfly.com & newegg.com. Hope this helps.
Jul 17, 2009 | Toshiba MK8025GAS 80 GB Hard Drive
Hard drive crashed
Since the laptop is no longer even listed on the Toshiba site, you probably need a 2.5" IDE hard drive. You should be able to take it in to any reputable computer/electronics shop and they can tell you positively if it is an IDE device or not (I'd put money that it is). You should be able to use anything up to about 200GB. Anything bigger than that is dicey based on the age of the laptop (the built-in controller may not support drives larger than 200GB). And your recovery disk should not have a problem with using the larger drive although you may need to partition it yourself before running the restore disk since some of them hard-coded the partition information (which would give you a 30GB partition and the rest unused space which you could then use for a second partition with a separate drive letter than the rest of the drive)..
May 29, 2009 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
How to Replace Hard Drive in Toshiba satillite 1555 CDS Laptop
Typically laptop hard drive replacement is pretty easy in about 95% of the cases.
Here is one link that has instructions for several toshiba laptops.
http://www.bixnet.com/toshiba2.html
Apr 17, 2009 | Toshiba 10GB NOTEBOOK HARD DRIVE KIT...
Update 4090 xcdt
Yes, you can upgrade from Win98 to WinXP. The minimum hard drive requirements for WinXP is 1.5GB and the minimum RAM requirement is 64MB. You will also need a CD ROM for the install. Now those are the minimum requirements so don't expect it to go very fast. If possible I would recommend you upgrade to Win2000. WinXP and Win2000 are almost identical. The minimum hard drive for Win2000 is 650MB and for RAM it is 64MB. So you could still use your 4GB hard drive and have plenty of room. You will need a CD ROM for the Win2000 also.
Good luck if you have anymore questons let me know,
Don't forget to rate this solution before you log off.
Jan 19, 2009 | Toshiba Satellite 4090XDVD Notebook
Need bios for toshiba satillite 4090XCDT
go to
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1073769739&rpn=&modelFilter=4090XDVD&selCategory=3&selFamily=1073768663&selModel=1073769739|
then click the plus next to the bios section on right and look for 4090.
i think 8.2 was higest
Dec 08, 2008 | Computers & Internet
TOSHIBA SATILLITE 4090XCDT VIDEO CARD
if you are using XP go to start>run (on the right hand side) and type in dxdiag, when the program opens click on the display tab and it will tell you the approx memory for your graphics card. If you are using vista then go to Start>accessories>run and follow the instructions above.
I hope this helps
Toshiba laptops satellite 4090
Hi, The laptop you purchased is an older model. It will use most any IDE laptop hard drive. The drive you mentioned from your Dell will work in it. You will need to pull the hard drive and put the sliders or hardware off the old one on to the new one. Look here for more info on your laptop. Look under portables.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download
Nov 30, 2008 | Toshiba Satellite 4090XDVD Notebook
Need to replace Toshiba Satellite 4090 XDVD hard drive
Any Techie should be able to do this for you, or you can try it yourself IF YOU PROCEED CAREFULLY. The small plastic trim strip just above the left and right click bars must be popped out and the keyboard removed to access the hard drive. I bought a 60 gig Seagate to upgrade the 6 gig that was in it and did it myself in about an hour. You will need to have the restore disc to reinstall all the drivers and the DVD player software. Mine is also upgraded to Win XP Pro. Runs a tad slow as RAM is maxed out at 180 megs but operates fine otherwise and plays movies without skipping. Hope this helps.
Aug 09, 2008 | Computers & Internet
HITACHI 20GB C4K60
It should work without any jumper settings.
If it fails to work then you can use a jumper to go for lower capacity option which i really feel you shoul never got to cause it will just work
Mar 24, 2008 | Hitachi Travelstar C4K60 (08K1532) 20 GB...
Toshiba Satellite 4090XDVD Notebook Logo
164 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
