Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool from ikea DWF415
The programme is only lasting for about 20 minutes instead of 2 hours. The start indicator light flashes on and off It is not cleaning properly. Filter clean
    President:
  • 878 Answers
Hazman, depending on your serial number, this model has a bunch of service issues. Everything from the motor rework to the heating element. Sounds like your issue has to do with the heating element. If the dishwasher does not detect a 4 degrees temp. rise in the water in will go into this fault. They have redesigned the board to bypass this fault in later models. Since I don't have a serial number I can't tell if you have one of the affected models, but I assume so. I would call Whirlpool and inquire about any service flashes they have on this dishwasher, you may be covered. Otherwise you would have to do some tests to determine the cause, starting with the heating element. I believe you can clear the fault by pressing these keys in this order: high temp-air dry-high temp-air dry. four key presses...this should put it in the automatic test mode. Let it do it's thing and the fault should clear. For more info on your dishwasher there should be a tech sheet behind the bottom toe panel....Catriver..post back.
Posted on Jan 22, 2007
I have model GU3200 series that the clean light was blinking suggesting a problem in the heating cycle and this solution worked to stop the light from blinking.
Posted on Apr 19, 2007
SOURCE:
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Aug 29, 2016 | Zanussi Dishwashers
I have a adg7560/1. the cycle starts but ends after a few minutes. the light flashes four times
Run the dishwasher through a test mode
Test Mode
Make sure the appliance is empty of water before running Diagnostics as it does not pump out before starting to fill and therefore you could overfill the appliance.
Open the door and set the program to the first program. (Normally rinse).
Turn the power off.
Press and hold the start button and while holding turn the power on.
After a little while the start button will flash, release the button.
Press the start button once and close the dishwasher door.
The machine will now run through a diagnostic routine.
Should take about 20 mins.
The machine will stop during diagnostics if an error is found and will display the error code. If no error is found it will complete the diagnostics and end the programme.
To exit diagnostics at any time just press and hold the start button till the programme is cancelled
Error codes
F1. Single flash. NTC Break. NTC open circuit/short circuit or ambient temperature less than 3 Celcius
F2. 2 Flashes. Water leakage. Floater switch LS6 in drip tray has switched.
F3. 3 Flashes. Heating system defect. Heater or relay on control board defect. Chack also cabling.
F4. 4 Flashes. Draining failure. Drain pump, control board OWI or water indicator defect.
F5. 5 Flashes. Sprayarm Blocked (not present on VBL version. On 1 digit display will show as F and flashing start led).
F6. 6 Flashes. Water valve (WV1) is switched on but flow meter (FM) senses no impulses (less than 10 impulses in 10 secs) and the water indicator (WI) is at a low level
Water Valve Closed. Water inlet hose blocked.
Water inlet valve (WV1) defective. Flow meter (FM) defective (leads to FM failure)
F7. 7 Flashes. Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked.
F8. 8 Flashes. Water level failure. Sieve strongly dirty or big amount of foam inside to less water.
F9. 9 Flashes. Continuously Water Inlet. Water inlet valve mechanically not closed or control board defect.
FA. 11 Flashes. OWI failure. Dirty OWI lens. OWI defect or control board defect. Check cabling.
FB. 12 Flashes. Motorised Diverter Valve
FC. 13 Flashes. Water Hardness Sensor Failure
A fault with no fault code indication = faulty module
Read more: http://www.diynot.com/forums/viewtopic.php?t=200838#ixzz2zKhYFHxt
Apr 19, 2014 | Whirlpool Dishwashers
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after...
Anyone got an answer to this, as I have exactly the same fault.
Dishwasher appears to switch on OK, then after a short time (20 secs?) the pump noise stops and the green light flashes - it seems to e a sequence of 7 flashes, then stop... 7 flashed then stop.
The sequence could indicate a fault detected?
Anyone know anything about these units from IKEA, made by Whirlpool?
Thanks!
S
Feb 12, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
03 grand am 3.4l no crank at all. All the light on dash work good fuel pressure starter spins and engine starts and then stalls when jumping the starter directly installed new pass lock switch and...
If the Passlock switch has been replaced, the computer has to "learn" the new Passlock code. You will need to hook up a battery charger to perform the learning process. (It takes about 30 minutes with the key in the "ON" position and it will run the battery down.)
Step 1:
Turn the key to the "START" position and release to the "RUN" position. The "SECURITY" light will be flashing. After about 10 minutes, the light will stop flashing.
Step 2:
Turn the key "OFF" then back to the "RUN" position. (Do NOT try to crank it yet) The light will start flashing again. Wait about 10 minutes for it to stop flashing.
Step 3:
Turn the key "OFF" and back to "RUN" one last time. The light will be flashing again. This time, when it stops flashing, do not turn the ignition off. Instead, turn the key from the "RUN" position to "START". The engine should start and run. The computer has now learned the new Passlock code.
Please help myself and others by taking the time to rate my answer. Thank yoou for using fixya!
Feb 08, 2011 | 2003 Pontiac Grand Am
How do i programm 735 t6 timer prince castle timers
A search of prince channel site for 735 timer sent me to the 740 timer >> their other models wer 755 and 840
Here's the prince castle page:
http://www.princecastle.com/products/timers_740series_single-display.asp
Here's the 2 instruction guides:
740 horizontal
740 vertical
The timer is a multi-channel countdown timer which means it can control multiple electrical devices separate from each other
Set the french fry cooker to tun on for 5 minutes
Set the dryer to come on for 10 minutes
Set the blower to come on for 1 hour
Set each item for different lengths of time
The item with least amount of time left shows on the screen
To program timer
Press and hold Prince Castle logo for six seconds
Time displays will change from " ----" to "PROG"
Press timer channel to be programmed
LED indicator light will turn yellow and beep will sound
Current programmed time will display (for example it might show 5 minutes 20 seconds)
Time value will indicate either H:M (hours-minutes) or M:S (minutes-second)
Press SCAN/UP arrow or SCAN/DOWN arrow to change program time
These arrows are located next to Prince Castle logo
If you want H:M instead of M:S, then press and hold SCAN/UP button
When display reaches 59:59 it will automatically change to 1:00 Hour
LED indicator light switches from M:S to H:M
Now you programmed first channel, click next channel and repeat steps above
To FINISH programming, press Prince Castle logo for a moment, and programs are saved
Oct 08, 2010 | Prince Castle 740T2 2Channel Single...
There is also a way of setting it by simply turning the light on and off at the desired time. Can yu help?
Manual: http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
The manual says:
"To automatically program, letting the switch
timer "record" your ON/OFF activities over a 24-hour period,
storing them as programmed settings:
Move the control lever to the OFF-CLEAR position for about
20 seconds. The red indicator light will go off and any previous
time settings will be cleared from memory.
Move the control lever to the ON position. The Red indicator
light will start flashing.
Press the dial as an ON/OFF switch to turn lights ON and OFF
at the ON and OFF times you desire for the first 24 hours.
At the end of the 24-hour period, the switch timer will be programmed
and the Red indicator light will stay ON, indicating
that the switch timer is in AUTOMATIC mode."
Sep 17, 2010 | Intermatic Programmable 24 Wall Switch...
Need a user manual for the time magazine free chronograph watch
I have NO ideal what kind of watch it is so I am giving general chronograph instructions. You will have to use as it applies to the watch you were given.
These instructions are provided for users who are not familiar with using a mechanical/analog chronograph. The instructions may be applied to any chronograph that has a seconds counter, 30 minute counter, and hour counter.
Please refer to the instructions of the appropriate model to determine the location of each counter on the dial. Note: some of the features described here may not be available on your particular model. Again, refer to the specifications to see if they apply to your model.
Using the chronographe functions:
How to read the chronographe:
For a chronographe that has a center seconds register, a 30 minute register and an hour register. Example 1: If the hour register is between the 1 and 2, but closer to the 1, and the minute register is at 20, and the seconds register is at 35, then the elapsed time is 1 hour 20 minutes and 35 seconds. Example 2: If the hour register is between the 1 and 2, but closer to the 2, and the minute register is at 20, and the seconds register is at 35, then the elapsed time is 1 hour 50 minutes and 35 seconds.
How to read the tachymetre:
If you are driving and want to determine the speed of the car using your tachymetre, start your chronograph when you pass a mile marker, stop your chronographe when you pass the next mile marker. Look at the center seconds hand and read the number on the Tachymetre scale, this number will indicate the miles per hour that the vehicle is travelling.
How to read the pulsometer:
Some watches have a pulsometer instead of a tachymetre. Use it as follows: Start the chronographe and begin counting the pulse. When you have counted 30 beats, stop the chronographe. The number on the pulsometer scale will indicate the pulse rate per minute.
How to read the telemeter:
Some watches have a telemeter instead of a tachymetre or pulsometer. Here is an example of one use for a telemeter: Start the chronographe when you see lighting. Stop the chronographe when you hear the thunder. Read the center seconds hand on the Telemetric scale and the number will indicate the distance separating the observer from the place where the lighting struck. This can give you a good indication of how far off a storm might be.
The many uses of a chronographe:
A chronograph has many practical uses, from timing a plane flight, a car ride, or simply being curious. There are also some uses for the chronographe that may not be so obvious. For example, you can use the chronographe on your watch as a dual timezone indicator. This is done as follows: If it is currently 6 A.M. in your home location and it is 12 noon in London, start your chronograph at exactly 6 o'clock. The number of hours displayed on your chronographe hour register will then show you the current time in London. Of course, these are just some uses of a chronographe. There are hundreds of uses for chronographes.
Instructions: Astronic Chronograph Chronograph Chronometer Power Reserve Chronometer Astronic Chronometer World Time Chronometer Retro Alarm General Chronograph Common Q & A's
Aug 12, 2010 | Watches
Ikea whirlpool dwf415 will not take in water and green light flashes on and off...help
MINE DID THE SAME IT WAS DUE TO A SPLIT PIPE ON THE OUTLET OF THE PUMP. THIS CAUSED A SMALL PUDDLE UNDER THE MACHINE THAT TRIPPED THE BUILT IN ANTI FLOOD SWITCH SO CUTTING OF THE POWER TO THE WATER SOLENOID. TO FIND THE LEAK BRIDGE THE ANTI FLOOD SWITCH AND RUN THE MACHINE WHILE LOOKING AT ALL THE PIPE WORK UNDERNEATH. IF IT IS THE HOSE ON THE PUMP OUTLET IT IS BONDED TO THE PUMP BUT YOU CAN CUT IT OF AND REPLACE WITH A HOSE AND HOSE CLIPS. DONT FORGET TO RE-CONNECT THE FLOOD SWITH. HOPE THIS HELPS
Aug 09, 2008 | Whirlpool Dishwashers
Whirlpool Flat top Accubake self clean 24 inch
Of course - Empty the oven and clear off around it.
The AUTO-CLEAN cycle time is adjustable, from 2 hours
30 minutes and 4 hours 30 minutes in 15-minute increments.
Suggested clean times are 2 hours 30 minutes for light soil and
4 hours 30 minutes for heavy soil. The last 30 minutes of the
cycle is for cool down.
To Self-Clean Using AUTO-CLEAN
1. Press AUTO-CLEAN.
2. Press the TEMP/HOUR “up” or “down” arrow pad to set the
desired self-clean cycle time.
3. Press START.
The oven door will automatically lock. The “DOOR LOCKED”
and “CLEAN” indicator lights will be displayed. The time
remaining will also be displayed.
4. When the self-clean cycle is complete and the oven cools,
the “DOOR LOCKED” and “CLEAN” indicator lights will turn
off.
5. Once the oven is completely cooled, remove ash with a damp
cloth.
To Delay Start Self-Clean Using AUTO-CLEAN
2. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired self-clean cycle time.
3. Press START TIME.
4. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired start time.
5. Press START.
The oven door will automatically lock. “DOOR LOCKED” and
6. When the self-clean cycle is complete and the oven cools,
off.
7. Once the oven is completely cooled, remove ash with a damp
cloth.
Owner, Warranty, Installation and Parts manuals are here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=sf362lxst&siteCd=WHRCOM
Sometimes search links don't work when copied.
Here is the direct link to the Use and Care Guide:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10110369.pdf
Page 16 has the above instructions.
God Bless!
-Ptochos
Jun 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
Whirlpool GU2400XTP Built-in Dishwasher Logo
909 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
