Question about HP Office Equipment & Supplies
I just put in a new hp 57 tricolor printer cartridge brand new out of the package. When I print with it the red does not print at all. Is there something I can do to make it print or do I just need to get a new one?
  • 628 Answers
Make sure the contacts on the cartridge are clean. If it doesn't do the trick, try a new cartridge.
Posted on Dec 01, 2008
It is reading Print cartridge problem(tri-color)
if it is not yet empty try to remove and reconnect the cartridge, if same error, try printing without the tricolor cartridge. if that works, you need a new tricolor
Mar 14, 2011 | HP Officejet 5610 All-In-One InkJet...
I just new printer.But when i want to print using colour,the outcome is just red and blue colour,even the actual colour in the input is green,it will be come out in red colour.How i'm gone to fixed it??
If it is a brand new printer and you are using the host cartridges that came with the printer, then you may face this issue.
You need to try with another set of cartridge.
HP 60 Black Ink Cartridge : part no. CC640WN#140
HP 60 Tricolor Ink Cartridge : part no. CC643WN#140
You may place an order directly from HP ( 1-888-897-8561 OR http://www.shopping.hp.com/webapp/shopping/home.do
After you recv the cartridges, clean inside the printer with a lint free cloth or coffee filter, remove all tapes from the new cartridges.
Install the cartridges and this should resolve your problem.
However if this does not solve the problem, call 1 800 474 6836 for troubleshooting and/or replacement.
Jul 14, 2010 | HP Deskjet D2660 All-In-One InkJet Color...
Magenta in tricolor not flowing
unplug printer cables, replug in
take cartridges out, put back in making sure sure nothing is obstructing the ink dispensary on the cartridges and that they're clean
look in the printer where the cartridges go, making sure nothing is blocking the ink
check the rollers to make sure no paper is caught inside the printer
turn on printer and try this
hope this works and good luck
Apr 30, 2010 | HP DeskJet 810c InkJet Printer
The tricolor cartridge status light is blinking. I want to print with the black cartridge as I always do. I have hardly used the tricolor cartridge. It cannot be empty. The printer will not print. I have...
Ink cartridge will go dry up if you don't use them. I would try cleaning the head and do some maintence on it. It looks to me that you have to buy a new black cartridge. I went through the same thing on mine.
Nov 15, 2009 | HP Deskjet 6940 InkJet Printer
I have a hp desk jet 5440 i put i a new tricolor
Make sure that your buying a new Tricolor as the same and Geniune too.
Only solution to this is put it properly inside your printer.
At first sometimes New Cartridge are being initial & calibrate by your printer before it works.
Power Off first your printer and put the cartridge inside. If the problem still exist then put back again your old cartridge and identify what is the problem occur before you put a new cartridge on it.
Sep 23, 2009 | HP OfficeJet J4580 All-In-One Laser...
HP Deskjet 648C printer
Just a suggestion: Have you tried using a different ink cartridge? I have found brand new cartridges to be bad right out of the wrapper.
Aug 29, 2008 | HP DeskJet 648c InkJet Printer
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
Hp photosmart 7350
The 7550 takes three cartridges 56(black) 57(tri-color) and 58 (photo).
If you replace the 57 but the 58 is also empty and still in its slot - you get green tinted photos.
So, check to see if you have the 58 photo cartridge still installed, and if it is out of ink. If so - remove the 58 - the printer will then default to "reserve mode" and you'll get better color.
Dec 16, 2007 | HP PhotoSmart 7350 InkJet Printer
HP 6110 color problems
Did you try a printer test sheet and alignment? Same thing?
Maybe defective cartridge.
Oct 11, 2007 | HP OfficeJet 6110 All-In-One InkJet...
35 people viewed this question
Ben Johnson
