Hi, my simpson eziset 550 washing machine wont start, I press power on then the start button and beeping alarm starts with the three water temp lights flashng, this has happened intermitantly in the past but until now turning it on and off a couple of times has seemingly fixed the problem and away it will go. any ideas ?
  • 2 more comments
  • Anonymous Jan 23, 2009
    Absolutely the same thing! Just looking for an answer because it seems completely stuck now. Really hope you get an answer! Am looking for my manual now...
  • mrlucky2 Apr 05, 2009
    HI and thanks for that input. The machine is fixed now, it turned out that we had a five year warrantee on it so the service man was called for this one.The switch in the lid was replaced and it has been working fine. Repair man did say this is about the only fault these machines develop other than ones caused by overloading. I did have a look at that switch before he came and I think the average handyman could replace it without too much bother just make sure its unplugged etc.
  • Kim Grant Jun 30, 2013
    can you tell me where the switch is I can't see it
    I have an eziset 750
5 beeps with the 3 temp lights flashing means lids not closed. or lid switch not working
i just fixed this problem. the magnet in the lid had come loose. I undid the two screws on the side of the lid put the magnet back where it should sit then i poured candle wax over it to hold it in place and working fine now.
Posted on Apr 04, 2009
  • KAREN LOCK Jun 05, 2011
    where does the magnet sit and what does it look like ? I cannot see a magnet at all in the lid .
    Problem Solver:
If no power and youve done the basic checks - there is a little glass fuse in the top of the machine. Disconect machine from power point then unsecrew the 2 screws and gently lift the control panel. the fuse is esily seen. Try replacing with e new fuse like I did.
Posted on Sep 26, 2009
Hi I have an Eziset 550 and am having difficulty with lint on my clothes. Have tried to remove the agitator, to no avail. Does anyone have any ideas? This m/c was left to me by my late father and I know it is only about 3 years old.
Thanks
Posted on Nov 21, 2009
I have an eziset 750. Same problem with not starting the cycle and three water temp lights on with beeping. Turns out it is the same warning that is given for having the lid open during operation. Found the lid switch and gave it a clean. Works now but expect the lid swtich will need replacing eventually.
Posted on Dec 17, 2011
  • David Ody
    David Ody May 07, 2017
    Where do I find the lid switch? Ours doesn't have a catch or anything lid just opens by hand (top entry for clothes)
'beeping alarm starts with the three water temp lights flashing'..I would agree with lid switch not working. The manual says 5 beebs with temp lights flashing is from faulty lid switch.
I just had mine replaced.
'Lint problem' Have you lifted out the piece in the middle of the washing machine and cleaned the mesh? That is your lint catcher. It just pulls straight up and out.
Posted on Aug 11, 2010
Condensatore
Posted on Jul 18, 2011
  • Cangurokoala Jul 18, 2011
    Where is capacitor?
    Where is condensator
To remove the agitator you need a 10mm socket with a couple of extensions.
Posted on Mar 03, 2011
Simpson 605 washing machine
it is worth having it properly diagnosed first before making a decision to spend money
could be a program board or start run capacitor
Nov 11, 2017 | Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
My Simpson eziset 800 washing machine will not start, I press power on then the button start and beeping alarms starts with the 3 water tap lights flashing, Have checked and clared filters and taps
When I had a problem with my simpson washer, with all 3 water temp lights blinking, it was a blockage in the pump, I emptied the washer and disconnected the host to the pump underneath, then cleared out the pump and put the hose back on, problem solved.
Nov 08, 2010 | Siemens Washing Machines
I have a Simpson Eziset 550 washing machine and it does not fill with water at the start of a wash - instead it will start to fill then stop and all three lights on the water temp gauge light up and start...
When mine had all 3 water temp lights blinking, it was a blocked pump, I emptied the washer, tilted it back, disconnected the hose from the pump (you will need towels) and clear out the pump, then put the hose back on.
Nov 01, 2010 | Washing Machines
Washing Machines Logo
4,943 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
