Question about Nikon N60 35mm SLR Camera
FEE blinks I have a fEE message blinking and I have tried to set the aperture, no change , please help me.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 206 Answers
Set f stop ring ( aperture ring ) on the lens to highest F stop number ( 16 ) and lock in position. This will get of fEE massage.
Posted on Sep 03, 2007
SOURCE:
I am trying out a Nikon D70 and it is used. Don't have manual. Everything is automatic. When I hit the shutter button, nothing happens. On the top of camera housing, there is a letter F// that blinks,...
Fee blinks--lens aperture not set to minimum (largest f number)
F-- blinks--no lens or non-CPU lens attached. Use a DX nikkor lens or place camera in manual mode
Apr 25, 2011 | Nikon Cameras
What does FEE mean? The camera won't take a picture and I see that in the display of my Nikon N90S
FEE error message displayed on SLR camera LCD Description If the cameras LCD screen displays "FEE" in the area where the aperture is normally displayed, please ensure that the lens is attached to the camera correctly. This error message will appear if the lens is not attached correctly to the camera or if you are not using a CPU lens such as the Nikon AF or Nikkor P lenses. Alternatively, if the lens has an aperture ring, it may not be set to f22 (or the highest aperture number on the aperture ring - normally marked in orange). Select the aperture number marked in orange on the lens and lock it using the aperture locking switch to prevent this occurring again.
The FEE error message
Set to F22, or the highest aperture number - normally marked in orange. Note the locking switch.
If the above did not resolve the problem and you still experence the the error display FEE, please contact your local Nikon office. Before doing so please also check the following.
1157d.gif That the EE servo coupling highlighted above on the lenses has not been broken. That the F-min switch highlighted above on the camera body has not been broken. If either of the two items above are broken please contact your local Nikon service center.
Apr 19, 2011 | Nikon N90S 35mm SLR Camera
I just bought a Tokina 100mm f/2.8 AT-X M100 AF Pro D Macro Auto Focus Lens from B & H and put it on my Nikon D300. When I press the button a blinking FEE appears. What seems to be the problem?...
The FEE error indicates that the camera cannot control the full range of the lens aperture. If your lens has a mechanical aperture ring, rotate the aperture to its smallest opening, or highest f-number - normally marked in orange. Select this aperture and lock it using the aperture locking switch to prevent this message from appearing again.
Dec 18, 2010 | Cameras
FEE keeps flashing with aperture ring nikor lenses
Your aperture lenses should be set to the biggest f-stop (smallest aperture)
Jun 07, 2010 | Nikon D70s Digital Camera
I have copied and pasted someone elses problem, because it is the same one I am having. So if I want to use the aperture for taking Manual photos I cannot do this because when it goes off of F22, it reads...
Lock the aperture ring at its smallest opening (in this case, F22). Change the aperture setting by turning the subcommand dial (the one in front, unless you changed it in the setup menu).
Of course, you can only change the aperture directly in Manual and Aperture-Priority modes.
Mar 23, 2010 | Nikon D80 Digital Camera with 28-80mm Lens
FEE error code on nikon d80
To solve this all you need to do is turn the lens' aperture ring (the one nearest the camera body) to the smallest number (probably 22 or 32).
Jun 21, 2009 | Nikon D80 Digital Camera with 28-80mm Lens
Our Nikon d1x won't take a picture. It gives me an FEE type of error and the battery flashes.
The blinking FEE message means the aperture ring is not set to minimum aperture (highest number). Turn the aperture ring to the highest number, and then find the aperture lock -- either a little slider or a button you press and turn. That will keep it from accidentally changing again.
Dec 31, 2008 | Nikon D1X Digital Camera
F-100 Won't take any shots
fEE blinking is Nikon's error message for cameras that control the aperture from the body instead of the lens. You need to set the lens to the smallest aperture (and lock it there, if the lens has a lock for the aperture setting).
Dec 27, 2007 | Photography
Fuji Finepix S1 Pro fE E blinking when turned on?
Might Help:
Notes on G-type Nikkor and other CPU Nikkor lens
The G-type Nikkor lens has no aperture ring; aperture should be selected from camera body. Unlike other CPU Nikkor lenses, aperture does not need to be set to minimum (largest f-number). CPU Nikkor lenses other than G-type Nikkor lens have an aperture ring. Set the lens aperture to its minimum and lock. When the lens is not set to its minimum aperture setting and the power switch is turned on, "fEE" blinks in the control panel and viewfinder and the shutter cannot be released.
Nov 09, 2007 | Fuji FinePix S1 Pro Digital Camera
What does the fEE error message displayed on an SLR camera mean?
The "fEE" error indicates that the camera is not communicating with the lens. The lens may not be attached to the camera properly, or if it has an aperture ring, it may not be set to f22 (or the highest aperture number of the lens) - which is normally marked in orange. Select this aperture and lock it using the aperture locking switch to prevent this from occuring again. The fEE error message Set to f22, or the highest aperture number - normally marked in orange. Note the locking switch.
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Nikon N60 35mm SLR Camera Logo
113 people viewed this question
Top Nikon Photography Experts
Ric Donato
pictureman4u
Jay Plesset
Are you a Nikon Photography Expert? Answer questions, earn points and help others
