Question about Denon AVR-4306 Receiver
Denon AVR 4306 receiver not connecting up 1080p with playstation 3
I have the following equipment: Denon AVR 4306 Samsung HL-S7178W Playstation 3 I am experiencing the following issue. I hooked up playstation 3 with an HDMI cable to the Denon receiver, that is published as having 1080P switching. I have an HDMI cable from the receiver to the TV. When setting up the Playstion 3 video resolution automatically it came back that it wasn't supported and only supported 480p. I then went to custom set up on the playstation 3, and chose all of the formats. It again came back and said it wasn't supported. I then only checked 480P; 720P; and 1080i. It accepted this configuation, but no 1080P. Obviously, I then made every change possible on my denon receiver with no luck. I then connected the HDMI plug directly into the TV, by-passing the receiver. With this set up, the Playstation 3 accepted all formats, including 1080P. However, my issue is this high end Denon receiver that goes for $1999 at best buy. Does anybody have info on my problem. Is this a misrepresentation by Denon, configuration issue, or is there another issue with Playstation 3 hooked up through a receiver?? Thx, Dave
  • igbino Mar 09, 2008
    I cannot connect my new denon 3808ci with the playstation 3
    Problem Solver:
  • 5 Answers
Wow..yeah that is starange for it to got to EDTV 480p mode..Did you try to press and hold the power button on the Ps3 to reset it's setting?? Try to press and hold the Ps3 power button until you here hear the 2nd beep and then let go,the ps3 will reset it self and look for a video resolution..
Posted on Mar 03, 2009
  • 119 Answers
HELLO, I DID A LITTLE RESEARCH FOR YOU AND FOUND IN YOUR MANUAL ON PG 103 IT STATES "RES OF 1080P ARE NOT HANDLED"
Posted on Mar 02, 2009
4 Suggested Answers
webdevil
  • 43 Answers
SOURCE: HDMI XBOX360 Elite -"No Signal"
The connection order can be a key issue as to whether or not the HDMI signals will pass through the system. For best results the receiver should be turned on first, then the source device(s) and then the display. The reason for this has to do with getting the equipment to handshake properly for the HDCP protocol.
If HDMI video will not pass through your receiver, you may with to just connect the xbox using the component cables. Since component will pass through 720p and your TV is 1080i you should expect the same qualtiy and a more crisp picture.
Posted on Jan 06, 2009
  • 128 Answers
SOURCE: Denon AVR 1610 hdmi to component video conversion missing?
hello i believe your problem is that you are trying to downconvert from hdmi to component connections and Denon receivers will not do that.
I have a 4310 and I know it will UPconvert from an analog signal to HDMI but won't do it the other way around.
you may have to use component inputs for all your equipment. You will also have to go into the receivers menu and designate which signal is being used for each component as it won't auto select between analog and digital signals when it comes to video.
hope that helps
Posted on Jan 25, 2010
Testimonial: "Thanks. Very helpful"
  • 5 Answers
SOURCE: Flickering video with Denon AVR 1910
I had the same issue with my Denon AVR-1908.....It turned out to be the cable box, not the receiver. I would suggest you unplug your cable box, remove and reseat the cable card,HDMI cables, and finally the cable line itself. Make sure the wires are not frayed or otherwise pinched.
Good luck....
Posted on Mar 09, 2010
How can i upgrade denon avr 4306 up to 1080p?
You don't need to upgrade that model as it already supports 1080P. If you are using HDMI connections between the receiver your TV the receiver will upconvert the other analog video sources (composite and component video) to 1080 content. Most likely 1080i as this is the standard format when upconverting.
Feb 28, 2011 | Denon AVR-4306 Receiver
Denon AVR-4306 + Motorola DCT-6416 Blanking
Hi Jim,
I tried connecting my dvr via component and optical to see if it was my hdmi or my dvr. Ended up being a bad hdmi plug in back of my amp. I was fortunate enough to have both style connections on my dvr. Hope this helps
Turk
Oct 13, 2009 | Denon AVR-4306 Receiver
Can PS3 go to receiver but not to TV if reciever hooks to TV?
Sounds like you just want audio I would just use the optical audio from the PS to the Denon and assign and input and you;ll have PS video and audio on your tv and just audio at the Denon
Feb 18, 2009 | Denon AVR-4306 Receiver
No component output on AVR-4306
This does not work... You can only upscale the video signal with 4306; meaning you can covert s-video, component video to HDMI but can not down-convert HDMI input (coming from your HD DVD player) to Component video output. Sorry that I could not give you a solution as this is the 4306's limitation (written on the 4306 manual.).
Nov 21, 2008 | Denon AVR-4306 Receiver
On screen display
Try connecting to the yellow RCA monitor output on the amp and corresponding input on the TV. This works for me. You could also try the composite outputs on the amp. This is one flaw the amp has that the setup screen will not display through the HDMI connection.
Aug 04, 2008 | Denon AVR-4306 Receiver
Install ps3 on avr-4306
PLUG THE STANDARD PS3 CABLE INTO PS3 THEN TO TV GO TO SET MENU FOR PS3 AND SET VIDEO OUT TO HDMI,PICTURE WILL GO OFF SO BE QUICK AND PUT HDMI CABLE INTO PS3 THEN TV,NOW SET AUDIO OUT PUT TO HDMI,THEN CONNECT TO AMP,IF YOU STILL GET NOTHING CHECK AMP SETTINGS IE INPUT SELECTION FOR HDMI.
HOPE THIS HELPS.
CABLE GUY.
Jun 18, 2008 | Denon AVR-4306 Receiver
Zone 2 Problem
Yes and no. You can get some digital signals to go to zones 2 & 3 but only PCM ones, Analogue always goes. I have a Denon DVD player connected to my 4306 with a denonlink cable. I had to connect RCA Analogue cables to the DVD input to get the sound to come out on Zone 2.
May 02, 2007 | Denon AVR-4306 Receiver
Open Questions:
See all Denon AVR-4306 Receiver Questions
Denon AVR-4306 Receiver Logo
1,077 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
