Question about Philips 50P8341 50" Rear Projection Television
Chirping Problem Did you ever figure out what was causing your TV to shut down and chirp?  I have a similar problem.
  • 3 more comments
  • Edward
    Edward Dec 06, 2008
    Chirping may be one of two things...
    Shorted convergence chips
    Faulty Flyback ( HVG )
  • Edward
    Edward Mar 22, 2009
    Most common reason is shorted convergence chips. Goto the site www.TvRepairKits.com and get their "chirping set" repair kit.
  • Anonymous May 02, 2009
    my tv be on but knoe picpure you can hear it on and it be chirping
  • Edward
    Edward Nov 29, 2009
    The most common cause for chirping on this model of Magnavox is a fault in the convergence chips. When they fail they will typicaly short out. You can get complete repair kits with instructions from TvRepairKits or just the parts from MCM, Bdent, etc.
    Hope this helps,
  • Mendonca May 11, 2010
    All the wires are disconnected to the circuit boards. I haven't bought the amps yet.
    Genius:
  • 1,139 Answers
I posted this earlier but it applies in this case so here goes,
The chirping sound is either a shorted Horizontal Output Transistor (HOT) / Power FET (whichever one is used in this case) or the IHVT (Flyback Transformer) has developed a short in its windings. In ether case both components will have to be replaced. I would suggest you have a qualified TV technician come over and troubleshoot the problem and give you an estimate on the repair.
However, if you are doing this repair yourself take into mind that the HOT and the IHVT (flyback) are in a series circuit configuration and if the Flyback is bad I would change out the HOT also, and vice verse.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Dec 09, 2008
  • Henry McKelvey
    Henry McKelvey Mar 22, 2009
    I post this only because I have seen this path taken before and it does get rid of the symptom, but it does not get rid of the problem. The convergence IC are usually tied to the same power supply as the Horizontal Output Stage and when the ICs go the cause excessive current through the IHVT causing it to develop a short circuit. That is what actually causing your TV the chirp. If you just replace the Convergence IC your set may work but in a sense you have a ticking time bomb on your hands, because of the IHVT then is functioning with a shorted winding.
    That is why troubleshooting is very important, to find the true cause of a problem, and not just to fix a symptom. Just remember, if you replace the ICs, keep your eye on the set and if another outage happens look at the HOT and the IHVT as possible candidates for replacement.
    That is why at my shop we try to get the customer to buy a maintenance plan, because a TV like any thing else has to be maintained for proper service.
    Thank you,
    Shuttle83
    http://www.electron-age-technologies-llc...
I have a 2005 Jeep Wrangler Unlimited Rubicon - chirping noise
have a local repair facility look at the front and rear universal joints
Mar 09, 2010 | 2005 Jeep Wrangler
No picture No sound, chirping from a board
Is the FBT,the high voltage transformer.The big black block of plastic with a red wire solder to a board.MIght even have to change transistors deflection board also.
Nov 21, 2009 | Philips 60PP9352 60" Rear Projection...
RCA p46732ba projection TV no power.
This is a common problem and the set is in shutdown mode. It attempts to fire up three or four times (the chirp you hear) if it detects a fault it shuts down - the most likely cause is the HV (high voltage) block- caution working on it since HV is present - The repair generraly costs $200-400 P# 205064
Google your model # and HV block to see what I mean.
Oct 06, 2009 | Televison & Video
Hitachi rear projection tv wont power on makes a chirp
You could have a bad HV Transformer causing it to shut down.
Jun 19, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Philips 55PP9352 Rear Projection, no picture or sound, chirping.
This is a common problem with this model. The convergence circuits have shorted out causing the HVG to chirp.
Goto the site www.TvRepairKits.com and get their "chirping" tv repair kit. It will fix the no audio+no video + chirping problem.
Nov 16, 2008 | Philips 43PP9202 43" Rear Projection...
No picture on screen, chirping noise every second from back
again a good set the deflection modules on these sets are pretty reasonable you need to have a tech swap it but i highly suggest that than a new one the chirping is the set trying to start up but going into shut down
Dec 02, 2007 | Samsung HC-P5241W 52" Rear Projection...
No power just a chirping noise.
Chirping means the power supply is being loaded down by a short in most cases, likely a bad convergance IC
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 21, 2007 | Philips 60PP9352 60" Rear Projection...
Samsung PCL5415RC Chirping noise
power supply discharging.even after the set is unpluged.
Sep 13, 2007 | Samsung PCL5415RB 54" Rear Projection...
Please Help!
A chirping sound from a TV set is the switch mode power supply trying to start up, but gets shut down because of a major short inside the set or in one of the circuits.. Most likly in this set, the horizontal output transistor is shorted because of a defective flyback transformer. Thats whats the common problem is with this set. A repair like this, if this is the only parts that are bad, will run you about 300 to 400 bucks or so. In some cases, not many but a few times, I have seen poor solder connections on L401 cause the horizontal output transistor to go bad. There are no user replacable parts inside this set, so please play it safe and seek out a pro to assist you in this repair. Good luck PS Please do not forget to rate this thread.
Dec 11, 2006 | RCA P52939 52" Rear Projection Television
PT-43LC14 No Picture, chirping sound when turned on
Most of the time, when there is a chirping comming from a TV set, there is a short somewhere inside the TV set. That chirping noise is the TV's power supply starting up and shutting down because of a heavy load on the power supply. These sets have no user replaceable parts inside them, so play it safe, and call out a pro to assist you in this repair. good Luck PS Please do not forget to rate this thread.
Dec 11, 2006 | Panasonic PT-43LC14 43" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
179 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
