Question about Apple 160 GB iPod Classic (Silver) + Deluxe Accessory Kit (MB145LLA/K2)
My IPOD 160GB only shows the apple screen or a X in a red circle
How do I reset my IPOD 160GB to factory settings without a MAC computer and without the CD. I have a laptop and just got this ipod as a gift without the manual. Any ideas or websites you can recommend?
My ipod is not charging and not coming on what i can do to fix it
Posted on Jul 10, 2009
Itunes restore 160gb
If it is an Apple 160GB. You can plug it into your iTunes account. On the left hand side it should come up under devices. Click on it and it will show your device on the screen with a tab saying "Restore" Click this and it will take you through the restore process make sure you know your computer password, it will ask for it. It will take you through resetting up your iTunes library back onto the iPod.
Mar 11, 2012 | Apple iPod classic MP3 Player
How do i reset the pin coad wen i have forgot it ?
You cannot reset/change the iPod's password once it has been set without having to restore it to its factory settings, but if you only want to unlock it connect it to an authorized computer and it should automatically unlocks it. If for some reason you cannot seem to unlock it like this then try manually changing the locked file into an unlocked one. First you need to make sure you have your computer/mac set to view hidden files, if not, follow this for windows: http://windows.microsoft.com/en-US/windows-vista/Show-hidden-files and this for mac: http://guides.macrumors.com/Viewing_hidden_files_on_a_Mac
once that is done, go to My Computer or Finder, open your iPod by selecting your iPod's Name "iPod", then go to the now visible folder called "iPod control", now open the folder called "Device", once here you should see a file called "_locked" right click on it(Control+ Click on mac) and select "rename" now add a U and an N right after the underscore so now it should read "_unlocked" and done! Your iPod will now be unlocked no matter what.
Jan 14, 2011 | Apple iPod nano
Hi i recently received an ipod apple 4GB model number a1236 and the screen is locked please i need help
Jan 10, 2011 | Apple iPod nano
My ipod says www.apple.com/support/ipod
This means there's some kind of problem with the iPod.
It might be solved by resetting or restoring your iPod. Otherwise, you'll probably need to take the iPod into an Apple store to see what's wrong.
Here's how to reset your iPod:
  1. Turn on the iPod, and make sure it's unlocked (no red is showing by the switch at the top)
  2. Press the "menu" button (at the top of the circle) and the "select" button (middle of the circle) at the same time and hold them down for at least 10 seconds, until you see the Apple logo on the screen
Here's how to restore your iPod:
NOTE: this will delete all music, etc. from your iPod
  1. Plug your iPod into the computer
  2. Open iTunes
  3. Click on "Restore" (on the "Summary" tab).
  4. Follow the onscreen instructions.
    You'll need to resync all your music etc. to get it back on the iPod after it's been restored.
If your iPod does not show up in iTunes, use these directions to put it into disk mode: http://support.apple.com/kb/HT1363
Then try the restore directions again.
Hope this helps!
Jul 18, 2010 | Apple 20gb Ipod Mp3 Player With Click...
My ipod says apple.com/support/ipod
  2. Open iTunes
Hope this helps!
Aug 27, 2009 | BoxWave Corporation Apple iPod mini (6GB)...
Problem with ipod classic
Hi! YOu need to disconnect your ipod from the pc.
Put the ipod into diskmode by following these instructions-
Before placing the iPod into disk mode, you should verify that it is charged.
Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
ht1363_2.jpg Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect
After doing this open latest version of itunes and then restore your ipod to factory settings by selecting it from itunes.
Dec 29, 2008 | Apple iPod classic MP3 Player
Ipod classic 160gb
http://fixyouripod.weebly.com/
Jul 02, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod wont show up in my computer or itunes...
Have you tried resetting either ipod? In order to reset it, you just need to hold down both the menu button and the center button at the same time until the ipod turns off. then the apple will pop up on the screen and it will start up like normal. If this doesn't fix the problem for either ipod, then most likely the problem is with itunes or your computer. I would say that if it doesn't even show up on your computer anywhere, you're probably missing a driver or something.
Jun 30, 2008 | Apple Ipod Nano Second Gen. Green (4 GB)...
Ipod classic 160gb screen froze, can't reset, Help!
allright i have the same problem and i know how to get it to discharge, reset it then right when you see the apple logo hold previous and center.
then it will take you to the whole systems analysis ******** that they do when you send it in, just go auto test and DONT continue, it wont auto shut off cause of the mode its in. thats what im doing right now.
May 30, 2008 | Apple iPod MA446LL/A MP3 Player
Apple 160 GB iPod Classic (Silver) + Deluxe Accessory Kit (MB145LLA/K2) Logo
1,016 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
