Question about Toshiba Satellite A215-S7422 Notebook
My computer was freezing constantly and windows woud not load i spoke with a rep who told me to do a bios upgrade but i forgot what she told me
My computer runs really slow, freezes, internet explorer hardly ever works. help!!
There is no such thing as a windows vista machine. You can install different operating systems on different machines. Your problem is most likely that you're missing drivers for the peripherals.
Download a program called "driver easy" and run it. It will tell you what drivers are missing, once you get all the drivers installed you should find things work better, like once you get your network running then internet explorer will stop having problems.
Jun 09, 2014 | Computers & Internet
I woud like upgrade BIOS from ATHLON AXDA1800 to AXDA2500 who to do it please
You can go to the manufacturers website to see the process of upgrading the BIOS. Caution : Only update your BIOS if you know what you are doing.
Sep 28, 2013 | Syntax SV400 Motherboard
New ram not reconised
Try upgrading the Bios to the latest version and when you start it for the first time after it's upgraded make sure to "load bios defaults". Then restart and tweak the bios settings if you need to.
Jul 25, 2012 | HP (D7580-60003) Motherboard
I have Photo explosin 3 on my computer it will not work correctley I have windows 7. It keeps freezing or not opening,
Hello!
I'm Richard from SoftCity Cafe, the new home of Photo Explosion's tech support. I spoke with the tech support reps about PE 3 and its compatability with Windows 7. Unfortunately, only some aspects of the program work in Windows 7 and the recommended solution is to upgrade to version 4. I can tell you that there has been a request of the PE development team to release a patch for Windows 7 compatability, and if this is something you are interested in I would recommend leaving a message in this thread on SoftCity:
http://cafe.softcity.com/questions-answers/view/1cDMxMzN/please-help-photo-explosion-deluxe-version-3-is-much-better-than-version-4
Hopefully this will help you and users like you.
Cheers,
Richard
Sep 07, 2010 | Nova Development Photo Explosion Deluxe...
PC constantly freezes. Computer screen will change to a color eg pink and will sometimes blink. PC will do this at any time while Windows is loaded or even in the BIOS. Please assist
completely clean your computer of dust
in BIOS press f1 for general help then load failsafe defaults or optimised defaults then
run chkdsk/f then defragment your hard drive then you should fix your registry
Aug 24, 2010 | Asrock Computers & Internet
Hi Please help - I require a BIOS upgrade
Try first to If bluescreen comes and reboot after to diasble reboot an writing here what on the blue screen they writing.
Other solution maybe possible :
1. Run chkdsk if possible so windows can find erors on the Harddisk.
2. Disconnect all usb except keyboard and mouse
3. uninstall new software installed on the computer (during the last 7 days)
5. maybe it can bee some hardware on the computer that is defect, ex your harddisc/ Dvd drive
Please let mee know if this solve the problem.
Aug 22, 2009 | Computers & Internet
Windows wont load after memory upgrade Presario R3000
Some time this type of problem occurs either one of you memory module is not working properly check your memory updation in bios then reinstall the windows after ram ugrade ,reinstllation after memory upgrades solves this problem
Aug 16, 2009 | Computers & Internet
Windows Vista freezes while loading up& Blue Vertical Bars appear
Hi
Reflashing the bios doesn't make any difference.
Check in the BIOS Screen whether notebook scree has the same issue if it is the same then it is a hardware issue if it is fine in the bios screen then need to run the hdd and memory test
After the test result we can decide next steps
> If hdd and memory test passes - then reload the os.
To login to bios - Reboot the system and keep tap on f10
Apr 28, 2009 | HP Pavilion dv9000z Notebook
Gateway 7320GZ restore problem
are you able to do a system restore back before the upgrade which I am almost sure you did right, take the computer back in time to the upgrade you were able to do with it, like if you had xp upgrade to vista, you don't need the 16 digit number, if this is windows that is, if this is a gateway computer this of course wont work.
Apr 28, 2017 | Gateway 7320GZ Notebook
Qosmio g30
Qosmio uses bios setting to configure the raid type for the HDD set up. this is not dependant on have two HDDs in you laptop. When bootining the laptop enter the bios setup F2 (I think not on a toshiba right now) check and reset the raid configuration for the drives. I am asuming you are using the origional recovery disks for your qosmio. If not you need to aquire a usb floppydrive and the raid drivers for you laptop iin order to install windows of any kind on this laptop.
Nov 08, 2008 | Toshiba Qosmio G35-AV600 Notebook
Toshiba Satellite A215-S7422 Notebook Logo
50 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
