Question about Mitsubishi VS-50705 50" Rear Projection Television
Vs-50707 bouncing lines
Bouncing lines...first this happens when it turns on the color of pic is in and out. I read that the prob might be with the 9 volt power regulator IC? If this is the issue were can I get this part? abelsmith1978@gmail.com
  • abelsmith Dec 11, 2008
    Jaime, sorry my model # is mitsubishi vs-50707. but when I opened it up below the signal board on the right it says model #55707. on the main board it says model #50707. I have horizontal lines that bounce and the pic seems to be shifted downward. Can you tell me what could be the fix for this prob? I've looked for the icp201 but i think that was for the wrong model. Thanks
  • 2,326 Answers
Click here to find the 9 volts regulator. You might also want to check radio shack.
Posted on Dec 01, 2008
Mitsubishi VS-50707 screen is jittery when it first turns on
Sounds like the verticle circuit is failing a honest shop will take of this for you around 180-230 if you want to do yourself youll need a iron and some filters and an verticle ic
Sep 26, 2009 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi vs-55707 or vs-50707????? bouncing horizontal lines weird color
If the picture looks like a 3D then you have a convergence failure.
I would suggest to visually inspect the STK Ics for dry or crystallized solder joints.
IC8C01 - STK392-110
IC8C02 - STK392-110
Dec 11, 2008 | Televison & Video
Mitsubishi vs-50707
The problem could in the 9Volt, and 3 Volt regulator supplies.
Replacing C2P05 (100ufd. @ 16 VDC), and C2P08 (also 100 @ 16 ) might fixed problem. They are located near IC2P01, and IC2P03.
The numbers(C2P05, C2P08) means the place where to find the parts that need to be change.
Apr 29, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-50707 shuts down sporadically
you can do a self-diagnosis test by pressing the menu and input/device button on set for 5 sec and see what error code it gives you. Count the blinks followed by a short pause then more blinks. This is the error code.
Mar 10, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-50707 50 in. Rear Projection...
There is a quick test you can do to determine if the problem is in your PIP module, using two 4.7uf/50v electrolytic capacitors. The PIP module plugs into two connectors on the main board. Remove the PIP module, and on connector VP on the main board (the 11 pin connector), use one cap to jumper from pin 7 to 9 (negative lead on pin 9); and use the other cap to jumper from pin 5 to 11 (negative lead on pin 11). If the PIP module is bad, you will now have video. The PIP module has surface mount capacitors that go bad. Just make sure you solder a small lentgh of wire to the capacitor leads to prevent them from shorting as they cross over each other. Just plug the wires into the socket no need to solder them.
Mar 08, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi vs 50707 50 inch projection tv problem
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Dec 15, 2007 | Mitsubishi VS-50707 50" Rear Projection...
VS 50707 turns on, then off immediately
Dec 10, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-50707 - Scrambled picture
Nov 08, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-50705 50" Rear Projection Television Logo
119 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
