Question about Acer Aspire 5100 Notebook
I have purchased a secondhand toshiba notebook and it has a faded flash in the monitor can the monitor be changed or fixed? thank you for any help you can give
Toshiba TE2100, Sreen flashes rapidly on and off, If I tap it on the side, it stops flashing, bu intermitently starts again. Seems lide aloose connection in the wiring to screen, as computer will still...
Sounds like you are correct about the loose connection. There is a thin ribbon cable that powers the monitor.
You will have to download instructions for taking your laptop apart, but once you do, simply reseat the ribbon cable. That should fix it! Good Luck.
Apr 07, 2009 | Toshiba TE2100 Notebook
Ac adapter light is solid green, but when plugged into laptop...
the most likely reason is a systemboard problem (the ac plugin port cannot changed independently for notebooks)
Mar 23, 2009 | Toshiba Satellite A65-S126 Notebook
Wont boot up
Norine,
You might want to try plugging an external monitor in to see if it is the LCD or the video card that is bad. If it is the LCD, an easy fix. If it is the video card, not so easy.
Good luck, and thank you for rating this response.
Mar 15, 2009 | Toshiba Satellite L15-S104 Notebook
User manual
This is the site for the manual but I think you would not be abe to download it.
pcsupport.toshiba.com  - enter  -  downloads  -  portables  - satellite  - archived models  - select model - show results - user's guide. Hope it helps. Thank you.
Sep 25, 2008 | Toshiba Satelite 2410 Notebook
Laptop monitor goes black
If you're working on the computer when that happens, it's not probably a power setting. Try to update your BIOS to the most current version at the toshiba support website (support.toshiba.com) & see what happens. Fixes the issue most of the time
I hope this helps.
Aug 25, 2008 | Toshiba Satellite A100-S8111TD Notebook
Hood Levers
i have a silvercross carlton but the hood is more faded than the apron how can i get it back to the same colour
Apr 16, 2008 | Silver Cross Carlton Carriage Stroller
Toshiba Satellite A105
Have you tried connecting to an external monitor? Try that. If the picture is perfect on the external monitor then the VGA port is OK but there is a problem with communications between the system board and the screen connector.
Hope this helps. Kindly leave a rating.
Mar 05, 2008 | Toshiba Satellite A105-S4004 Notebook
X223W LCD Monitor, white background too harsh
Try setting the font smoothing to Clear Type.
Feb 06, 2008 | Acer Aspire 3690-2196 Notebook
Acer Aspire 5100 Notebook Logo
21 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
