Question about Lands Phones
Hi have panasonic gigarange supreme model KXTG5240ALM my caller ID is just saying incomming call cant find manual cheers petra
I have telephone Panasonic KX-TG5240ALM, now i do not Dial. password is mistake.
Please help me !
Thanks !
my email: tuanbuingoc@gmail.com
Posted on Mar 15, 2009
NEED USER MANUAL FOR KX-TAG931S PHONE HANDSET What I really need is how do I make the incoming call go to Voice Mail without it ringing 4 times.
You may download the KX-TGA931 manual from http://shop.panasonic.com/shop/model/KX-TGA931T?support
The number of rings is controlled by the answering machine or voicemail system on your phone line. It cannot be changed from the handset. Please refer to the documentation for whatever answering machine or voicemail system you have.
If you require further assistance with the answering machine or voicemail system, please tell us the make and model.
Sep 23, 2013 | Panasonic KX-TG5210M GigaRange Supreme 5.8...
Incoming call does not show in caller id window all the time. sometimes it simply says "incoming call" without identifying the caller. other times is works proberly.
Caller ID information is sent after the first full ring. If the call is answered too soon, the caller ID information may not have been sent yet. Some of the many and varied networks do not send caller ID information. In this case you may notice that caller ID is missing only on calls from certain callers. Occasionally bad data is sent, causing your phone to reject it.
Jan 23, 2011 | Panasonic KX-TG5632 Phone
When a received call comes in the number shows 1-402 then the number.on call back the phone dials all 11 numbers,then i get a recording from windstream that says i dont need to dial the 1 and area code....
The caller ID in your area is set up to show the 1 plus the area code although not every area has yet to require you to dial the 1 before the number. In the near future it's possible you will have to dial the 1 even if you're calling a local number. I know of no way to change the phone settings in order to remove the 1 in the caller id. Unfortunately it looks like your only option will be to dial the number directly without the 1. Good luck!
Dec 10, 2009 | Panasonic Lands Phones
Does this phone have caller ID
Hi
Yes indeed it does and as long as you are subscribed to it (check with your call provider) the phone is caller ID capable.
Thanks for using FixYa.
Dec 05, 2009 | Panasonic GigaRange KX-TG2432 Cordless...
Hi, I have a Panasonic KX-T7636 and I dont see any caller ID on incoming calls. How do I fix this?
Okay well i'll just give you the long and short. If your caller id was working and then it all of the sudden stopped working you need to call your phone service provider and notify them. If you just got these phones installed then you would need to get a caller id card and turn on the caller id prompt from your phone system.
Dec 16, 2008 | Panasonic KX-T7630 Corded Phone
I have a Panasonic KX-TCA132E but no instructions. I have set up with my phone company for incoming caller id to be displayed, however it is not working. Do i have to use the handset to activate the...
I have had this phone (twin) for quite a few years . If your incoming line supports caller ID it should work immediately. I never had to activate this. I would check if caller ID on your line is working. Check with another phone if you can.
Aug 13, 2008 | Lands Phones
Panasonic KX-FC392
I can receive and here the caller, but I am very faint to them. How do I solve this problem? I cannot find a manual for this model so please help?
Apr 02, 2008 | Panasonic GigaRange KX-TG2432 Cordless...
Caller ID not working
I don't think the problem is the FSK vs. DTMF. The manual even states that the caller ID is generally received after the second ring. This is true in America. I lived in India for four months and I never ran into the problem there so... I just can't say how your provider sends the caller ID. It may be that the line is being interfered with. Do you have a DSL line attached to the same device. If so make sure that there is a filter between you phone and its connection.
I am assuming that you tested your line with the other equipment connected to the same location. You may want to reduce the problem to the simplest configuration by connecting directly to the line only no other equipment. If it works add the other equipment until the caller ID stops again. Then you know what is interfering. If you have a monitor set you could listen to the DTMF being sent make sure it is coming between the first and second ring. It is audible if it is there. If you are answering on the first ring you will not see caller ID you have to wait till after the second ring then you should see it, If BSNL is sending the same as American systems. Good luck Z
Mar 12, 2008 | Panasonic (KX-TG1032S) Phone
CALLER ID ONLY SHOWS "INCOMING CALL"
I was using this site while trouble shooting this in the US...
If the customer has DSL with filters in the same system go back to the NID and Isolate the DSL,
test the caller id and call waiting caller id. If this works you have Data Bleed coming from the DSL.
Make sure there are not two sets of filters on the line. Tjis customer had a filter with the DSL modem.
Doing this we just fixed an on going problem for a field tech who was the second callout on a customer issue.
Oct 27, 2007 | Uniden Cordless Phone
Lands Phones Logo
91 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
