Question about Dynex DX-ESW8
Playstation 2 not connecting to the internet
I have a computer hooked to the internet through Roadrunner DSL cable, I connected the Dynex router DX-ESW8 to the computer and the cable box, this worked great.... Then I connected my playstation 2 to the router and the playstation 2 will not connect..... when we manually put in the ip address (same as computer) it says conflicting.... It will time out if we go to auto, to find the ip address.....
  • 160 Answers
The router you are using is not comp with the ps2 try using linksys or belkin
Posted on Dec 01, 2008
Router will not pass the internet connection. I can direct-wire computers to my modem, but the minute I change the connection to the router, the "Internet" indicator only blinks on and off...
Please post more info. What is your Internet connection? Cable or DSL?
Most Cable providers you will need to set the connection on the Router to DHCP.
If DSL, you should have the DSL modem placed into bridge mode (contact your provider for assistance) and then set the Router to authenticate the DSL's PPPoE.
Also, if you've got a Cable modem, it might need to be rebooted to allow the Router to work. I know I have to do do this when I'm testing and switching out routers.
Apr 22, 2011 | Dynex DXWEGRTR Router
My computer is not connecting to my Dynex wireless router. I've called my locate cable subscriber and they told me that it's a router problem. I've disconnected the router several times and it shows that...
First off, verify that you can connect to your cable modem directly. After that, hook up your Dynex wireless router and reboot your cable modem. After this, directly connect your computer to the Dynex router (using a cable). If you cannot get an Internet connection, then there is some issue with your Dynex router configuration. It's possible that there might be an IP address conflict with the cable modem. It would be best to contact support for configuring the Dynex.
If you can connect to the Internet with your computer connected directly to the Dynex router, then there must be some router configuration problem affecting your ability to connect wirelessly. You'll have to check the configuration--might be a good idea to completely reset the router and start over. If that doesn't help, you should contact Dynex customer support, as each router has its own configuration specifics. Good luck.
Nov 07, 2010 | Computers & Internet
How Can I Get My Ps2 To Go Online What Parts Are Needed
You need the Network Adapter and you have to sign up and pay money/ month
f you are hooking it up to a DSL cable/modem,
1. Remove the sticker covering the network connector on the Network Adaptor and
plug your Ethernet cable in the connector labeled NETWORK.
2. Plug the AC power cord for the PlayStation2 system into an electrical outlet.
3. Turn on the PlayStation2 system and start the Network Adaptor Start-up Disc.
If you are hooking it up to a router:
1. Remove the sticker covering the network connector of the Network Adaptor.
2. Connect an Ethernet network cable from the NETWORK connector of the Network Adaptor to an available LAN port of the router.
3. Connect the WAN port of the router to the DSL or cable modem.
4. Connect a personal computer (not pictured) to an available LAN port of the
router. Use a web browser on the PC to set up the router to reach the
5. Follow the specific instructions that come with the router. There is no additional installation for switches.
If you are hooking it up to a LAN:
2. Connect an Ethernet network cable from the NETWORK connector of the Network Adaptor to a wireless Ethernet bridge.
3. Connect the WAN port of the wireless router to the DSL or cable modem.
4. Connect a personal computer to the router. Use a web browser on
the PC to set up the router to reach the Internet.
For pictures, see the thread here:
May 20, 2010 | Sony PlayStation 2 Slimline Console
How do you hook up a Dynex Ethernet Hub
If your hub has 4 or 5 connectors, connect one port to your router. This device will NOT work when connected to your cable modem, as the hub does not manage IP addresses like a router does. Hope this helps ... the remaining ports will feed internet, but not provide Internet addresses to a computer.
Nov 08, 2009 | Dynex 4-Port 10 Mbps Ethernet Hub
Computer cabled to Dynex enhanced G wireless will not connect
Unplug the router for ten seconds and plug it back in, it needs to reset. Some routers have a reset button. I often wait longer than ten seconds, I find a beer is usually the right amount of time. Sometimes the modem needs a reset also; unplug everything, then plug back in sequence, with the modem first, the wait, then the router, wait, then turn on your computer. That system works for any brand modem and router.
Jun 09, 2009 | Dynex Enhanced-G Wireless Broadband Router
Can't stay connected
Might I suggest checking out this site, . I think that the Linksys router is having issues keeping the connection alive on your PS3. You should also consider setting a static IP.
Feb 22, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Changing from DSL to Road Runner Turbo
I'm sorry to say but you cannot bypass the modem capability of the DSL Westell Modem/router because that is really made to function as a DSL modem and a router at the same time, so the best way to make everything work here since you change from DSL to Cable internet just need to get a wireless router like a Linksys WRT54G that can make everything work again like before.....
Nov 05, 2008 | Westell Wirespeed VersaLink...
Wired dynex router suddenly started interfering with my internet connection.
Verify your router is connected to a standard grounded outlet. Check that the Internet cable is connected to the WAN port on your router, and check the WAN light on the front of your router is illuminated. Check that the LAN lights are on.
Power cycle your router by unplugging the DSL/Cable Modem from the power, then unplug the router and power off your computers. Then, plug in the DSL/Cable Modem to the wall and wait until all the lights are on and none of them are blinking. Power on the DX-E401 router and wait until all the lights are on. Now, power on one computer and verify the Internet connection.
You can verify your router is working properly by sending an echo request to it and verifying the response you get.
If you are a Windows user go to Start, select the Run option and in the dialog box type in CMD. Once there, type in ping and you should get 0% loss as a response.
If these do not help, the router is likely to have malfunctioned, requiring repair or replacement.
Jul 29, 2008 | Dynex DX-E401 Router
Dynex wireless modem
Your expert Geokohler helped me fixed the problem and soved it for me. I sent an evaluation giving him a "fixit" rating.
Jul 21, 2008 | Dynex DX-E401 Router
Can i connect a 2wire 2701hg-b with roadrunner cable internet ? I had the 2wire dsl with at&t but recently disconnected the service
It is possible but it may not work as a router (2 wire 270). The 2wired router only has a phone port and ethernet/usb for computer connection. So if you will connect the roadrunner modem to the 2wired, you can connect it to the ethernet port of the 2wire, but the 2 wire will not function as a router any more. It will work just like a wireless bridge. This one setup that you can.
May 02, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
Dynex DX-ESW8 Logo
294 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
