Question about Garden
I have a craftman yard vac with a tecmseh 4.5. She has failed to
She has failed to start even after replacing spark plug and filling up with fresh gas. She attempts to accelarate but shuts down after several second. Can u help.Model # Craftman 247770110
    An expert whose answer gotĀ voted for 100 times.
  • 185 Answers
Hi gr2954;
Lots of the starting problems with 2 cycle engines (weed eaters, blowers, chain saws, etc) are caused by leaving them stored for long periods of time with the oil/gas mixture left in them. what happens is that a residue forms on parts in the carb.
Try the following: empty the fresh gas out of the blower. add a gas stabilizer to the existing gas you plan to put in the blower. You can get this stabilizer at any auto parts store. While you are there get a can of spray start fluid. Put the fresh, modified gas in the blower. Take the spark out and spray some starter fluid in the plug hole.Replace the spark plug and try to start the engine.It will probably take a few cycles of doing this to get the blower to stay running.
when you put the blower up for a long period, empty the remaining gas out then start the engine and run it till it stops. this gets the remaining gas out of the carb.
Posted on Nov 30, 2008
I have a new[purchased last summer] Yard Man Mdl.: YM320BV 2-stroke, 31cc, blower/vac that will not start. Fuel is fresh, has new spark plug (what should the gap be?) original plug was...
If the plug is black then either there is too much two - stroke oil in the mix or the gas / air mix is too rich due to e.g. dirty air filter. Have a look at these tips for starting weedeaters, they apply also to blowers:
Jun 09, 2011 | Mtd #TB4SC 25CC 4-Cycle Gas Blower
I need a manual for my elnita 250 by elna. It hasn't been used in 20 years so I want to make sure i'm maintaining it properly before I use it.
There are a few things I would recommend; get some Marvel mystery oil, remove spark plug and fill cylinder with the marvel. allow to sit at least overnight before draining and pull the starter a couple times to free up the piston rings. While you are waiting, remove the carb and fuel tank - flush both with starting fluid first then fresh fuel. If you are familiar with carburetors and air / fuel jets, count the turns on each respectively to bottom then remove. Soak in starting fluid for at least an hour and flush out respective ports with starting fluid then carb cleaner then fresh fuel. Use non - lubricated starting fluid as you want the highest concentration of Ether to break loose the varnished fuel.Flush out fuel lines and primer bubble ( if equipped) with fresh fuel and spark plug out. You can best do this by re - installing fuel tank and filling with fresh mixed fuel, adding the fuel stabilizer at double the recommended strength - this will not harm the motor, just help it start and stay running. Place an air hose blow nozzle in the mouth of the tank, wrap with a clean rag and gently blast air into the tank until 1/4 of fuel in tank has passed through. Cap tank and turn saw over to drain the fuel out of the cylinder, giving it at least 10 minutes to drain. Now replace spark plug and follow starting procedures - you should have it running strong now!! If it refuses to start or sputter in the first 5 pulls, remove spark plug and shoot a 2 second blast of lubricated starting fluid into the cylinder. Install plug and start. You may have varnish issues due to the lengthy storage time and you may be better served by getting a rebuild kit for the carb and rebuilding it or even replacing carb. Fortunately 2 stroke carbs are much easier to rebuild than a 4 stroke.
Good luck!!!
Nov 19, 2010 | Garden
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 19, 2009 | Craftsman 4 Cycle Blower/Vac
Lawnmower wont start
Possible Causes Corrective actions
Unit will not start Control handle is not engaged Engage control handle spacer.gif spacer.gif
Spark plug wire is disconnected Connect spark plug wire spacer.gif spacer.gif
Fuel tank empty or stale fuel Replace with clean, fresh gas spacer.gif spacer.gif
Air filter filled with dirt or debris Replace or clean air filter
May 23, 2009 | Mtd 22" Yard Machine Push Mower
My string will not pull its like its stuck need help thanks
it might have vapor lock, try removing the spark plug and spray a little penetrating oil into the cylinder, let it sit for a couple minutes and try pulling the cord again with the spark plug still off.
Nov 18, 2008 | Craftsman 4 Cycle Blower/Vac
Craftman 205 mpg 2 cycle gas blower 40:1 raito will not start.
Similar experience with the same blower. I cleaned the carb checked for spark but I still can't get it to start
Nov 13, 2008 | Craftsman 4 Cycle Blower/Vac
Leave blower and vac
I don't mean to over simplify this, but are you using fresh gas? Gas blowers and string trimmers are extremely ticky when it comes to gas. They like it SUPER fresh. Not just fresh from the can, but fresh from the pump! And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with string trimmers and blowers, and it fixes the problem 75% of the time. Also make sure your spark plug is clean. If you are not sure, a new plug couldn't hurt.
Hope this helps!!
Sep 04, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
338 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
