Question about Lands Phones
Storing name number inmemory - Lands Phones
    Problem Solver:
  • 18 Answers
Names,options,add new contact,key in info & save.
Posted on Nov 30, 2008
Need to program new phone numbers
The manual is available here: www.uniden.com/pdf/CEZ260om.pdf. If you search google for "uniden cez260 corded phone manual" it is the first result.
You can find the instructions in the fourth column of text under "Storing a Name and Number in Memory"
Here is the text from that section, but I can't promise the copied text is accurate. Check the pdf at that address if anything doesn't work.
1. Press STORE. LOCATION? shows in the display.
2. Press the desired memory location (0 to 9 or quick call buttons A, B, or C.) NOTE: Press LEFT or RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C to select a location.
3. Press STORE again to con? rm the memory location. NOTE: Use Delete to erase existing memories or to correct errors.
4. Use the number keys to enter the telephone number (up to 32 digits) and then press STORE to save. (The unit will not dial a phone number in this mode.) The cursor automatically moves to the text line for name entry.
5. Use the number keys to enter the name of the person associated with the telephone number you just entered. More than one letter is stored in each of the number keys. Press the keys multiple times to scroll through the letters for that key. For example, to enter "B," press "2" twice. Press LEFT two times to create a space. NOTE: The ? ashing cursor automatically moves to the next position or you may press LEFT or RIGHT to move the cursor to the next position.
6. Press STORE to save the name.
7. To enter another name and number in a di erent memory location, return to step 1 and repeat this process.
Storing a Pause in Memory
The REDIAL/PAUSE button has dual functionality and becomes a pause button when pressed in sequence after the STORE button. It is valid only when storing a number into memory locations. Use the REDIAL/PAUSE button to insert a pause when a delay is needed in an automatic dialing sequence (for example, when you must dial a 9 to get an outside line or when you enter codes to access your long distance company).
NOTE: A pause is 3 seconds in length and you can store more than one if a longer pause is needed. Changing a Stored Number Repeat the storage sequence under Storing A Name and Number in Memory, and press DELETE to delete the old number before entering the new number.
Erasing a Stored Name & Number
1. Press STORE.
2. Press the memory location (0 to 9 or quick call buttons A, B, or C) to be erased.
3. Press DELETE.
Copying Caller ID Memories to User Memory
1. Press LEFT or RIGHT to view the caller number and name you want to copy.
2. PressSTORE.
3. Press the memory location (0 to 9 or quick call buttons A, B, or C). The number ? ashes if there is a number already stored in that memory location.
4. Press STORE to enter Edit mode, and then pressSTORE again to edit the name. NOTE: Select a di erent memory location by using LEFT and RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C.
5. Press STORE to con? rm and save. Wait three seconds to exit.
NOTE: If the name you want to enter is longer than 12 characters, only the ? rst 12 characters will be copied into memory.
Storing a Redial Number to Memory
1. Press STORE.
2. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If a number is already stored in the memory location, it will appear on the display. Use LEFT and RIGHT to select a di erent location.
3. PressSTORE again to con? rm.
4. Press REDIAL/PAUSE, and then press STORE again.
5. Enter the name, if necessary, and then press STORE to con? rm.
Copying a Redial Number to Memory
1. Press REDIAL/PAUSE while on-hook. Redial number will display along with PICKUP PHONE.
2. Press STORE.
3. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If there is a number already stored in the memory location, it will appear on the display. Use the RIGHT or LEFT buttons to select a di erent location.
4. Press STORE twice.
5. Enter name, if necessary, and then press STORE again to con? rm and save.
Dialing Numbers Stored in Memory
1. Press DIAL.
2. Press a memory location button or use LEFT or RIGHT to scroll through stored memory locations to ? nd the desired number. The number in that memory location displays.
3. Press SPEAKER or pick up the handset to dial the displayed number.
OR
1. Lift the handset or press SPEAKER.
3. Press DIAL again to dial the stored number.
Jun 11, 2015 | Uniden CEZ260 Corded Phone
Needs to reprogram fax machine, has old fax numbers in
1. Press Menu/Set, 2, 3, 1.
2. Press the One Touch key where you want to store a number.
The LCD shows the location you selected.
3. Enter a number (up to 20 digits), and then press Menu/Set. If you want to enter a pause in the dialing sequence (for example, to wait for an "outside line"), press Redial/Pause as you're entering digits. A dash appears on the LCD. Pressing Redial/Pause enters a 3.5 second pause when the number is dialed.
4. Use the dial pad to then enter the name (up to 15 characters), and then press Menu/Set. You can use the chart on page 4-2 to help you enter letters-OR-To store the number without a name, press Menu/Set.
5. Return to Step 2 to store another One Touch number-OR-Press Stop/Exit.
When you dial an auto dial number, the LCD shows the name you've stored, or, if you haven't stored a name, the number you've stored.
If you loose electrical power, auto dial numbers in memory will not be lost.
(For USA Only) One-Touch key 1 has been pre-programmed for the Brother faxback system. One-Touch key 2 has been pre-programmed for the CallManage long distance plan. You can override them if you wish.
Note If you need to store a pause longer than 3.5 seconds, press Redial/Pause two or more times.
Note - You can store Groups (for Broadcasting) on the One Touch keys.
Dec 11, 2010 | Brother IntelliFax-2820 Laser Fax
We lost our manual and I am trying to reload our speed dial numbers. I have tried everything but can't seem to figure it out. Help?
1 Press Menu/Set, 2, 3, 1.
2 Press the One Touch key where you want to store a number.
3 Enter a number (up to 20 digits), and then press Menu/Set. If you want to enter
4 Use the dial pad to then enter the name (up to 15 characters), and then press
press Menu/Set.
5 Return to Step 2 to store another One Touch number-OR-Press Stop/Exit.
Dec 07, 2010 | Brother IntelliFax-2820 Laser Fax
When someone calls my nokia 5230 nuron the name doesnt show up just the number
there may be 2 reasons for it
1.I hope you stored the caller name and number in your mobile.
If you haven't stored it please store the name and number in your phone and it will show the caller name when he/She calls you.
2.Even though you stored the caller name and number and still you get only the number,Then please check weather the same number is stored twice in different names.If this is the case also the mobile shows only the number when the caller is calling you.
Thank You
Aug 14, 2010 | Nokia 3120 Cellular Phone
I've just bought Samsung M7600 but the problem is that when somebody's calling me, it doesn't show me caller's name, only a number of a caller. Can you help me please?
Thank You
Aug 13, 2010 | Samsung M7600 Beat DJ - black Cell Phone
When i receive a text it only shows the contact number and not the name but sent texts show the name?
if the number is stored twice or thrice you wont get the name you will get only number may be you stored one number in diff names suppose................my number is +919704788855 you stored my number in the name of Ramesh once and Ram for the second time.......like that you store the number, you will get only number sorry if i was wrong..........
Dec 05, 2009 | Sony Ericsson Satio Cell Phone
How do I save telephone numbers to a uniden powermax 5.8 ghz cordless telephone
Phonebook (Storing Phone Numbers, Names, Distinctive
Rings and Speed Dial)
You can store names and numbers in your phone’s phonebook, search for names
alphabetically, and dial phonebook entries with just a few key presses. You can
store up to 100 numbers in the base and up to 100 additional numbers in each
registered handset.
The phone uses the same memory to store phonebook entries and Caller ID
messages. If the shared memory is already full, the phone will not store any more
phonebook entries. You will have to delete some of the Caller ID messages before
you can store a new phonebook entry.
1) When the phone is in standby mode, press phonebook.
2) Press the STORE soft key, S t o r e / E d i t N a m e appears.
3) Enter the name (up to 16 characters) by using the
number keypad (see the "Steps for Entering Names and
Special Characters" on page 44).
If a name is not required, go to step 4. <No Name> will
be used as the name.
4) Press the OK soft key to store the name;
S t o r e / E d i t N o . appears.
5) Use the number keypad, */tone/<, or #/> to enter the
phone number (up to 20 digits).
If you make an error, use the DELETE soft key to erase
the incorrect digits. When you are finished, press the
OK soft key to store the number.
6) If you store the phonebook entry from the handset,
D i s t i n c t i v e R i n g appears. Press volume up/down to
move the pointer to one of the Distinctive Ring options
and then press the OK soft key.
7) S p e e d D i a l appears. Press volume up/down to move the
pointer to select the Speed Dial location (10 locations:
SPD1-SPD0).
8) Press the OK soft key. You will hear a confirmation tone, and D o n e ! appears in the
display. EASY DOES IT! :)
Jul 08, 2009 | Uniden TRU9466 Cordless Phone
Extensions don't ring
you will need to access system program mode to change ringing inmemory block 4-12
Mar 10, 2009 | NEC DTU 8-1 Corded Phone
Storing #s in memory
Try this. Memory The handset can store up to ten 24-digit numbers with up to 15-character names in memory for quick dialing. This memory feature is in addition to the CID memory log, which stores up to 40 CID records in the handset. Storing a Name and Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the mem button. 3. Press the desired memory location (0 through 9) or use Caller ID/vol (+ or to scroll to the desired memory location. NOTE: If the memory location is occupied, the memory location number and its contents show in the display. 4. Press the mem button again. The display shows ENTER NAME. NOTE: If you don?t want to enter the name, skip step 5. 5. Use the touch-tone pad on the handset to enter the name (up to 15 characters) and press the mem button to save. More than one letter is stored in each of the number keys. For example, to enter the name Bill Smith, press the 2 key twice for the letter B. Press the 4 key 3 times for the letter I. Press the 5 key 3 times for the letter L. Wait for one second. Press the 5 key 3 times for the second letter L. Press the 1 key to insert a space between the L and the S. Press the 7 key 4 times for the letter S; press the 6 key once for the letter M; press the 4 key 3 times for the letter I; press the 8 key for the letter T; press the 4 key twice for the letter H. 6. Press the mem button to save the name. The display shows ENTER TEL NUMBR. 7. Use the touch-tone pad to enter the telephone number you want to store (up to 24 digits). 8. Press mem again to store the number. You will hear a confirmation tone. NOTE: If you make a mistake press the del/chan button to backspace and erase the wrong character(s) or number(s). If there are any further questions or comments, please post here. Please rate this solution through fix-ya.com Thank you
Jun 18, 2007 | GE 25836 Cordless Phone
STORED NAME NOT SHOWING WHEN INCOMING CALL
You have stored the persons name and number in the SIM memory, that is the fault- if you want to see their face and number, then store to phone memory..
Mar 25, 2006 | Motorola Mobility RAZR V3
Lands Phones Logo
35 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
